Sound Gallery
FS: Focal Electra 1038Be 2 Floor Standing Speakers
Item: Focal Electra 1038Be 2 Floor Standing Speakers
Price: $6800 (RRP $15750)
Item Condition:
The Electra 1038Be 2 have a mark at one of the back corner and also a dint/scratch at the side of another. They are not obvious when in listening position. Please check out the pictures. Don't have original boxes so prefer local pick up or you can organize your own freight. Comes with original manual and spikes for the speakers.
Reason for selling: Customer upgrade
Payment Method:
Direct Deposit, Cash or Paypal + charges.
Electra 1000 Be 2
A design which suits you
Technophile
The high-fidelity Electra 1000 Be loudspeakers have inherited Utopia’s technology to give you an extraordinary high-fidelity experience. IAL innovation (Infinite Acoustic Load) gives the beryllium tweeter a very wide frequency range which provides astonishing sound.
Home Cinema
Update your new generation home cinema system with the Electra 1000 Be 2 range which has been designed to ensure compatibility with new multi-channel sources. Choose a high-definition set-up for your films with all the loudspeakers in the range.
Generous
The Electra line is the solution for those looking for select and refined aesthetics for perfect integration into your kind of interior. The enclosure and the finish “Made in France” are guarantees of a style which flatters your interior design.
ELECTRA 1038 Be 2
As the whole Electra Be 2 line, the 1038 Be benefits from new components and settings. The awesome strength of the three 7" (18cm) woofers, endless power, is now added to the new qualities gained in terms of sound image and definition. A true weapon of mass seduction.
Type                3-way vented floor standing speaker
Drivers          Three 7" (18cm) "W" woofers
                     6 1/2" (16.5cm) "W" midrange
                     11 /4" (27mm) pure Beryllium IAL inverted dome tweeter
Frequency response - (+/-3dB)33Hz - 40kHz
Low frequency point  - (-6dB)26Hz
Sensitivity - (2.83V/1m)93dB
Nominal impedance -
Minimum impedance - 3.3Ω
Crossover frequency - 230Hz / 2,200Hz
Recommended amplifierpower - 40 - 400W
Dimensions - (HxWxD) 493/16x1115/16x153/4" (1,250x303x400mm)
Net weight - 112.2lbs (51kg)
IMG_7989.thumb.JPG.0c9b99e2e9273ec69b1b5bdb3f4e60ff.JPGIMG_7990.thumb.JPG.cb149c9e179f642ed03fb4a8a66c2d58.JPGIMG_7991.thumb.JPG.f67cdc0a06093b35582815e90a3b266f.JPGIMG_7993.thumb.JPG.6e842c230528ddb77ba02f8dfc6bd251.JPGIMG_7995.thumb.JPG.06676accb4b90a5d21dc60bb2f751766.JPGIMG_7996.thumb.JPG.b200693c2e393daa1d46b3d7358e8093.JPGIMG_7997.thumb.JPG.badec404ce725ffeb07be622bedac68d.JPGIMG_7998.thumb.JPG.c4d19c00f4958c79e9a64fd77cd7ea27.JPG
Great speakers, great price.
