GreatSouthernTime
Advice: Replacing Bookshelf’s
Hey Guys.
sadly my cleaner just dropped and  broke my bookshelf speakers, a trusty set of Jamo e610.
I am wanting to replace them but before I do I wanted some advice on models to look at.
I am running a modest set up made up of a REGA P1 into a vintage Technics SU-2500 Amp.
I usually play fairly chilled music and don’t blow the volume so a natural sound would be preferred.
Appreciate any help.
welcome to SNA, usual questions, budget, room size, placement, the Technics looks like a good amp, looking at the RRP of the Jamo, i would recommend Monitor Audio Bronze B2, front ported and more efficient than the Jamo, i have a pair of earlier BX2, great sound for the money, there is a pair in the classified's but you would need more posts to access, good luck, i'm sure others will post with their ideas, the choice is always yours, a demo is always good , you could take your amp with you when auditioning
Thanks for the reply Wen.
Room size is approx 30sqm.
budget second hand between 200-400.
placement is centre of room backed on wall.
the monitor are something I was considering when buying these. I’ll take a look.
I liked the Q Acoustics Concept 20 which are in your budget. They do like to be a bit out n the room though so not sure how they'd go back against the wall.
Trusty Usher S-520 are in your price range.
There are two or three Jamo bookshelfs on Facebook if you want a direct replacement the Ushers are great in a small room.
these speakers are rear ported, would be concerned about placing them against a wall, specs are 60hz - 20khz, the MA Bronze 2 are 42hz - 20khz, one review i read said they used a sub below 60hz for the Castle, i suspect you would have to upgrade your amp and look at a different placement for the castle's, i have only heard bookshelf Castle's with a tube amp, sounded wounderful
Thanks for the tip.
On 23/11/2019 at 8:58 PM, wen said:
@GreatSouthernTime, how is the speaker replacement going?
Picked up a pair of Castle Richmond Anniversary bookshelfs. Beautiful speaker but prob a little light for the large room they are in.
I’ll look to add a sub to fill in the bottom end or replace them with a different bookshelf with a little more depth.
6 hours ago, lemarquis said:
Good to hear. A sub is definitely on the cards I feel :)
Yeh. Although I’m running a stereo amp which is sounding awesome but doesn’t have a sub output, I assume.
thinking I’ll have to update amp so will have to do some more research.
and so the fun begins. Haha
You can run speaker cables out to the sub if it also has high level speaker inputs along with the RCA.
That’s great advice. And no sound quality is compromised?
Not at all.
    • By olegau
      Item: HiFi stereo system
      Price: 1400
      Item Condition: very good
      Reason for selling: do not need
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and just do this.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562.
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By Midget
      Item: ELAC FS 247 Floorstanding Speakers
      Location: Terrigal Central Coast NSW (Will ship Australia wide)
      Price: $2400 $1985 + Shipping (includes $20 donation)
      Item Condition: Used. Smoke, pet, child free owner. Very minor micro abrasions on top surface and minor fading to fabric grill, excellent condition.
      Reason for selling: Downsized to a smaller apartment
      Extra Info: Each box is 110x40x30cm with a weight of 20.2kg, Made in Germany
      System type 2.5-way Enclosure type Bass-reflex Frequency response ± 3dB 30 - 50000 Hz Nominal impedance 4 Ohm Amplifier Requirements 30 - 250 W Sensitivity (2.83V/1m) 89 dB Tweeter JET III Woofer 2 x 150 mm (6 in.) AS-XR cone Dimensions (H x W x D) 1022 x 170 x 270 mm / 40.24 x 6.69 x 10.63 in. Weight 17,8 kg / 37.4 lbs.
    • By ajricho
      Item: Richter Wizard Mk II speakers
      Price: $190 negotiable
      Item Condition: Good. Tweeter and mid-range drivers replaced-details below
      Reason for selling: These were my parents speakers-selling on their behalf. They have moved into a retirement home and no room for them. Unfortunately also too big for my house
      Payment Method: PayPal, Cash - Pickup
      Extra Info: As mentioned, these were my parents speakers - they bought from new in 1996. They had problems with them in the early years of ownership, with the tweeter and mid-range drivers replaced on each by Richter under warranty. The original drivers may not have been available as they are different. The tweeter in each is a Vifa TC20TD05-06. Mid-range in each is a Vifa P17WJ-00-08. The Woofers weren't replaced and still original Audax HT170G2. The speakers are fully functional and the cabinets and covers are in very good original condition
    • By Rock Robster
      Item: Neat Mystique floor standing speakers
      Price: $600
      Item Condition: Very good
      Reason for selling: downsizing
      Extra Info: I am the first and only owner of these speakers.
      These are very accurate UK manufactured two way speakers. They  are very balanced and have a surprising amount of bass. They sound great with solid state or valve amps.
      I have really enjoyed listening to these speakers over the years but financial controller says they must go.
      Comes with a spare neat tweeter that is brand new and never used. (This is due to a young child pushing in a tweeter which was professionally replaced.
      I bought two tweeters just in case)
      Also comes with a set of spikes.
    • By gypr1961
      Item: Avantgarde Zero 1 XD Active Speakers DSP
      Price: $18,000
      Item Condition: Mint
      Reason for selling: Time for a change
      These are the top of the line model, above the pro model and come with DSP, digital and an analogue (A/D card) for turntables etc.
      They are incredibly dynamic! They sound just as good when theyre shaking the house or playing whisper quiet.
      I have all original packing
      As im going to need a complete new system Im happy to look at trades + cash
      Specs can be found here https://www.avantgarde-acoustic.de/en/products/zero-serie/zero-1-xd.html
