VanArn 526 Posted November 11 The impedance ( plus phase ) correction circuit, consisting of the 4.5 ohm resistor in series with the 36 mFd capacitor needs to be connected across the bass speaker terminals. Put another way, the speaker positive terminal should go to the junction of the 0.3mH inductor with the 9.4mFd capacitor (and the L.H. point of the 4.5 ohm resistor). The attenuator pad needs to be shifted to a position after the capacitor inductor junction. To clarify this, the 1.3 ohm resistor connects from that junction to the ' top' terminal of the tweeter and the 10 ohm resistor is connected across the neg. and positive terminals of the tweeter. It should be noted that it is normal for second order crossovers ( two-way) to have the tweeter connected out of phase with the bass section. I believe your crossover cct. does this , presuming 1 is the positive input and 2 is the negative return terminal 0 Quote Share this post Link to post Share on other sites
davewantsmoore 5,873 Posted November 11 1 hour ago, Lynx4 said: Sorry I'm not very smart I guess lol. You'll get there. A simulator makes it easy to tinker, but doing a good original design takes a lot of experience. Here's how the impedance correction bit of the woofer needs to be (approx values). ie. Both parts across the driver (in series with each other) See how it flattens the impedance out at higher frequencies. This means that if you add a "textbook" crossover filter (which is designed to work on constant impedance) that it will work as expected. As mentioned earlier, it can often be simplified by combining elements of the impedance correct and XO.... but don't worry about that for now. Probably the best advice I can give, is don't fall into the trap of adding parts tinkering to get the response you want, without also looking at the impedance. You want to keep the impedance generally either high, or flat .... if it both low, and with peaks and dips, then it's probably bad. 0 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 11 10 hours ago, davewantsmoore said: You'll get there. A simulator makes it easy to tinker, but doing a good original design takes a lot of experience. Here's how the impedance correction bit of the woofer needs to be (approx values). ie. Both parts across the driver (in series with each other) See how it flattens the impedance out at higher frequencies. This means that if you add a "textbook" crossover filter (which is designed to work on constant impedance) that it will work as expected. As mentioned earlier, it can often be simplified by combining elements of the impedance correct and XO.... but don't worry about that for now. Probably the best advice I can give, is don't fall into the trap of adding parts tinkering to get the response you want, without also looking at the impedance. You want to keep the impedance generally either high, or flat .... if it both low, and with peaks and dips, then it's probably bad. Ok ok I have done this now I think only issue is my SIM won't allow me to place resistor on the other side of the capacitor for the correction. This is what I'm looking at now. Still have a spike in impedance at the top end of frequency is this the crossover network? To me it's looking good and seems to work? 0 Quote Share this post Link to post Share on other sites
VanArn 526 Posted November 11 It does not matter which way, the impedance correction network is connected to the bass speaker terminals. However you have an error in the placement of the tweeter attenuation pad. The inductor should be shifted to connect between the 9.4 mFd capacitor and the return line ( tweeter negative ). The attenuator 'L' pad is for the tweeter to drop its' sensitivity to match that of the bass speaker while keeping the impedance at 4 ohm throughout the crossover region. It can only be connected at the tweeter for it to work as intended. 0 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 11 3 hours ago, VanArn said: It does not matter which way, the impedance correction network is connected to the bass speaker terminals. However you have an error in the placement of the tweeter attenuation pad. The inductor should be shifted to connect between the 9.4 mFd capacitor and the return line ( tweeter negative ). The attenuator 'L' pad is for the tweeter to drop its' sensitivity to match that of the bass speaker while keeping the impedance at 4 ohm throughout the crossover region. It can only be connected at the tweeter for it to work as intended. So should the L pad go before or after the crossover (capacitor and Inductor) 0 Quote Share this post Link to post Share on other sites
VanArn 526 Posted November 11 The 'L' pad is fitted after the crossover components. 0 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 12 1 hour ago, VanArn said: The 'L' pad is fitted after the crossover components. Awesome so this looks 100% better to me at least. Would you agree? 1 Quote Share this post Link to post Share on other sites
VanArn 526 Posted November 12 Bravo, Lynx4! The impedance curve is what I would expect of a crossover designed to suit specific speaker units. In this case the manufacturer's data has been relied on and this information can be inaccurate as there can be production changes and material variability can also effect results. It is a good starting point for your speaker build project . 2 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 12 3 minutes ago, VanArn said: Bravo, Lynx4! The impedance curve is what I would expect of a crossover designed to suit specific speaker units. In this case the manufacturer's data has been relied on and this information can be inaccurate as there can be production changes and material variability can also effect results. It is a good starting point for your speaker build project . Now the only trouble is finding parts to suit i have tried to match everything up best I could but it has slightly changed the impedance will this be much of an effect? Or would it be alright? 0 Quote Share this post Link to post Share on other sites
VanArn 526 Posted November 12 (edited) For prototyping a speaker crossover, especially when you have access to many components, the values can be tightly controlled by selection with the aid of an RLC meter . The better the instrument, the tighter the tolerance limits for the crossover network . If you are prepared to buy a few extra resistors, it is possible to make up or select from a batch, an exact match (at least to within 5% or better) of the calculated design values. For example, two 2.7 ohm resistors in parallel can be used to make up the 1.3 ohm value and you can use the lower cost 5 watt wire wound types , which should be cheaper than a 10 watt rated resistor. The 4.5 ohm resistor can be made up of 10 and 8.2 ohm resistors in parallel and again the 5 watt wire wound types can be used.The 9.4 mFd capacitors can be made up of two 4.7 mFd caps. connected in parallel (Polypropylene capacitors of at least a 250 volt DC rating). I would prefer the inductors to have a lower DC resistance ,but this would mean a heavier gauge wire and of course, a higher cost. What components do you have already ? It is a simple task to adjust to other values by the addition of other parts as shown in the forgoing discussion. In any case, using the values that are shown in your schematic are very close and the results may not be distinguishable from a more rigorous assembly. Edited November 12 by VanArn additional material 1 Quote Share this post Link to post Share on other sites
davewantsmoore 5,873 Posted November 12 4 hours ago, VanArn said: Bravo, Lynx4! The impedance curve is what I would expect of a crossover designed to suit specific speaker units. In this case the manufacturer's data has been relied on and this information can be inaccurate as there can be production changes and material variability can also effect results. It is a good starting point for your speaker build project . ... and the biggest issue, is that it doesn't take into account the response on the intended cabinet shape.... everything > 1 khz is going to look a lot different when mounted on a small box, vs the (assumed) IEC baffle or similar that the datasheet measurements were done on. 0 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 12 That's alright I'm not after an audiophile grade set of bookshelfs this was just a project to introduce myself into the world and already I have learnt a tone thanks to all you guys helping out I can not thank enough! 🥰 1 Quote Share this post Link to post Share on other sites
Lynx4 5 Posted November 12 2 hours ago, VanArn said: For prototyping a speaker crossover, especially when you have access to many components, the values can be tightly controlled by selection with the aid of an RLC meter . The better the instrument, the tighter the tolerance limits for the crossover network . If you are prepared to buy a few extra resistors, it is possible to make up or select from a batch, an exact match (at least to within 5% or better) of the calculated design values. For example, two 2.7 ohm resistors in parallel can be bused to make up the 1.3 ohm value and you can use the lower cost 5 watt wire wound types , which should be cheaper than a 10 watt rated resistor. The 4.5 ohm resistor can be made up of 10 and 8.2 ohm resistors in parallel and again the 5 watt wire wound types can be used.The 9.4 mFd capacitors can be made up of two 4.7 mFd caps. connected in parallel (Polypropylene capacitors of at least a 250 volt DC rating). I would prefer the inductors to have a lower DC resistance ,but this would mean a heavier gauge wire and of course, a higher cost. What components do you have already ? It is a simple task to adjust to other values by the addition of other parts as shown in the forgoing discussion. In any case, using the values that are shown in your schematic are very close and the results may not be distinguishable from a more rigorous assembly. That was the other way I was thinking but space as well as cost is an issue already with the componates listed in the above crossover I'm totalling about 100bucks and I'I'nmot chasing something that is mind blowing just a good sound in a great looking cabinet. Once I have more experience and knowledge behind me then I'll probably attempt to make great sounding set of speakers but most likely a few years away as I do have alot to learn still! Haha. I think I'll go ahead and purchase what I have now at least then I should have some alright sounding bookshelfs by the weekend. 0 Quote Share this post Link to post Share on other sites
