mwhouston
Single driver speakers, DIY or commercial
I suspect the very low moving mass is why it sounds nice.It is very lightly built and that is probably a good thing.
Also good sensitivity at 92db. SETs would love it.
Currently this is the 6L6 SE UL power wine box amp driving my Mark Audios. Sounding far better than I thought possible. Single stage tube preamp before that.
It appears I can’t attach an image. Another member was having this problem. I’ll place a link.
http://retro-thermionic.blogspot.com/2017/02/silver-supreme-6l6-se-ul-amp-in-wooden.html
Edited by mwhouston
That would depend on the impedance curve.
It is likely to drop well below the 8 ohm impedance.
sensitivity is only halve the story.
1 minute ago, aussievintage said:
Well you learn something new every day :)  thanks
Should have warned it’s not for the faint of heart to read too far down the page on UrbanDictionary
So I discovered
I posted I  cannot  upload images. I was informed my attachment quoter was full. I deleted several hundred images and now all good. I think one other member was have the same problem. Go through your members account.
2 hours ago, mwhouston said:
Altronics c0635-100mm
Using an an online box calculator
From that sure looks like a Radio Shack 40-1197 (aka FE103 variant). They only give one of 3 required specs so using T/S won’t work. You’d probably be safe putting it into Frugel-Horn Mk3. Looks like the 92dB comes as the expense of Fs so maybe Frugel-Horn Lite.
It could be a real sleeper.
dave
Who has tried baffle step corrections (BSC).
Yes. I try to avoid using a passive filter in the speaker circuit, trying other remedies 1st.
One has to be careful with BSC, as it raises the on axis below the cutoff it also raises the room response — which is often flat to start.
This needs a bit of udating, particularily #6 on bipoles. It is missing discussion of bi-pole dip.
https://www.t-linespeakers.org/tech/bafflestep/intro-bds.html
dave
Edited by planet10
add link
I can add images now. The 6L6 “Silver Supreme” this morning.
I think this thread has been really well supported. I know I’m pleasantly surprised at the number and variations and types  of the single driver speaker which have been posted.
I think the trophy goes to planet10 though for not only sheer numbers but beautifully crafted speakers. Keep it up.
When I was suggesting this thread on the DIY thread we spoke of coaxials. They have not been included here. Time for them to shine. I’m suggesting now another thread for single driver coaxial speakers. If we get anywhere near the support and enthusiasm of this thread at least I’ll be pleased.
I have only built two coaxials and both based on Spanish Beyma drivers. I’d like to see who is doing what with coaxials. I’ll start the tread and post a link here and on the DIY thread.
Here is a link to the coaxial single driver speaker thread.
10 hours ago, aussievintage said:
The impedance curve is almost to good to be true.
the impedance curve is not atypical of a good FR. Do note the huge scale for the graph.
dave
Inspired by this thread, I am listening to this point source driver system at the moment. Sounds superb and does most things right considering the main driver, a Fostex FE206 cost peanuts. The Fostex is reflex loaded into a vented 25L box and good to about 80Hz, low bass is my favourite Eton 11-581 driver in an 80L BR box yielding bass down to 26Hz +/- 3dB according to WinISD modelling.
I also really like the unusual speaker positioning into a triangulated portion of the room. This creates a 2-3m space behind the speakers (into the apex of the room corner) which results in a 3D soundstage, great depth, spread and incredible bass response in my room ...the music just ‘hangs in the air’ in front of me, too.
Steve
Edited by Steve M
I forgot to mention, the Fostex box has a Baffle Step Compensation circuit design by Martin J King installed which supposedly cuts about 9-12 dB from the Fostex’s hot upper mid-lower treble region.
This definitely tames the driver significantly, but like Planet10/Dave I often (depending on the music) like using the Fostex/Lowther drivers without the BSC, to keep it pure.
Edited by Steve M
I also really like the unusual speaker positioning into a triangulated portion of the room. This creates a 2-3m space behind the speakers which results in a 3D soundstage, great depth, spread and incredible bass response in my room ...the music just ‘hangs in the air’ in front of me, too.
Steve.
I would have had the speakers either side of the gear rack.  Not having heard your setup I may have been missing something. All gear looks pro and well finished. A bit of pride in craftsmanship and ownership goes a long way and doesn’t always take much.
Did I miss something or has there been no commercial single drivers posted. I would have thought maybe a pair of Zu(s).
Mark, my normal speaker positioning is side by side of the equipment rack and you may have seen this in past photos posted by me. However, what I am describing in the post above is that the triangulated speaker position into the corner - works amazingly well in this room. I would almost encourage people to try this speaker positioning, if your room allows it.
I think that is the issue “of room allows” not in my case anyhow.
Never heard it but sounds like it is working well for you.
Yes, and on a variety of speakers. The standard speaker position is sounding a bit flat and 2D now. 😕
