mwhouston
Single driver speakers, DIY or commercial
I’ve built five single driver speakers speakers from simple reflex loaded to complex back loaded horns. Fostex 6” and 8” drivers were my early choice but the last pair are with Mark Audio 12P 8” drivers. I consider the Mark Audio drivers superior to the Fostex particular the bass region. But even the mid-range and treble are better than the Fostex.
At this point just single full range  or wide range drivers in any box or baffle to be posted. Love to hear what others have done and why.
Here's another pair of Fostex 8" in  TQWT enclosures.    All glued MDF construction.   The really sound nice driven by a SET amp.  They are connected to a nice example of a Pioneer 3-in-1 in this photo (that subwoofer is not connected).
A very unique tweak has been applied,  two Lambis lambis (spider) shells on top to distract the odd room resonance. :)
30 minutes ago, mwhouston said:
Those back-loaded horns are indeed complicated.  I'll bet that took you a while!
I use full range though augment bass and treble so I guess I've been ruled out  :(
How do you augment them - in external boxes, or do you do it more like a normal 3-way system.  If you don't have a crossover limiting the full-range driver's response, I think you might squeek in :)   (it's not my thread of course)
Fortunately I had a better wood work friend put them together over weeks.
Maybe it should be one driver one baffle.
The full range is run unlimited,  actually so are the bass woofers presently.  Only the super tweeters are limited with some caps.
Replacing the 10" Zenith 49CZ924 drivers with Lii Audio FAST-10S this weekend,  and have already replaced the 15" Magnavox with Lii Audio W-15 woofers.
The woofers have been designed to supplement their full range drivers and seem rather happy without any inductor in the path. I do need to EQ everything using a MiniDSP 2x4HD though as the speaker in the corner sounds louder than the other.
Edited by MattyW
I have designed/built (actuall Chris & Bernie have dnoe the building), many Fostex, many Mark Audio, and lots more.
dave
Over 30 years of building single driver speakers ( hence my user name )
I have built many designs from complex horn loaded cabinets to bass reflex cabinets
Have used 3 or 4 brands of speaker drivers
I always preferred Lowther
The bigger the cabinet the greater the bass output is a rule of thumb
OK, here's one I mentioned before.   I always remembered the "movie" sound from those old Bell&Howell film projectors at school.  They had a detachable box with a 12" speaker in them for the sound.  I eventually acquired one, and a top condition Rola 12PX driver for it. Very authentic.
I then had the idea to set up a mono system, so I used a valve amp - a 6L6 ultralinear 'Playmaster' design with some changes.  The sound reminded me, happily, of an old jukebox.  I put the speaker box on a wall mount bracket above the turntable and amp, angled down to where I sit to listen.  The open back uses the top corner of the room to produce a very full sound.
Precariously holding my phone around behind the box to sneak a peek at the driver and inside of the box.
They were always mentioned with reverence in full range speaker discussions.     I have only heard them in real life once.  Don't know what style of enclosure it was,   but I remember thinking that their reputation for being a bit "shouty" was about right. But that's one example, in a bad situation (shop floor, not a proper listening room).
As with any speaker one should always look at the system that drives them, I encourage a wholistic approach
Most recommend enclosures that use Lowther drivers are well over 100db sensitivity
So what is pushed into them gets faithfully recreated
Other than that changing / experimenting with phase plugs to suit a design or room dynamics is a good idea
Love it.
9 minutes ago, mwhouston said:
Love it.
:) Thanks.    It's an indulgence that turned out well.  I have 2 turntables that play through it, a Garrard 4HF, and a Garrard AT6 changer.  I love playing old 78s on the 4HF , as well as old mono classical LPs, but really also enjoy stacking 45s on the changer.
Reminds me of a doc I saw once on a guy in the us who had the largest known collection of 78s, some umpteen thousand stacked around a room, you know the sort. Anyway, in the middle of the room he had this homemade looking bar fridge-sized wooden box with a platter and arm on the top and a fr speaker in the side and that’s the only thing he ever played them on. No idea what was it was actually made from but a less glamorous playback system you could not have imagined.
Edited by RankStranger
Metronom Speaker with Fostex 126 en full range drivers.
8W SS class A amp.
Why?
Why not!
How does it sound? Bloody good for how little money I spent on it.
The only system I heard where the solo guitar jumps forward by 2m out of the speakers.
No, it does not do bass well. But we all know that.
I have lots of pictures, i expect you’d like to see some?
dave
dave
They are glorious. Did you make all of these? How many do you have now?
8W SS class A amp.
Why?
Why not!
What is the setup inside the boxes, some sort of horn loading?
Of those only the green µFonken at the bottom. They are part of the museum. This was from some time ago. A different set now.
dave
46 minutes ago, Ian McP said:
Ha! I saw that yesterday :) I was over the road at Selby getting some bananas and i dropped in for a look on the way back to the car. Had to rush off though so I couldn’t check it out properly. Sure caught my eye though
