G_goodwin
WLM Gamma Reference Firewire Dac (based on Weiss Minerva)
Item: WLM Gamma Reference Firewire Dac
Price: $1400 (RRP $5195)
Item Condition: Excellent
Reason for selling:: Audio Note
Extra Info: Current retail for this DAC is $5195 http://audioaddiction.net.au/shop/wlm-gamma-reference-da-converter
The WLM Gamma (not the Reference) is up there on the DARKO list http://www.digitalaudioreview.net/the-darko-dac-index/
I have the original box, so am happy to ship at buyer's cost. I'll also throw in a Oyaide NEO 6pin-9pin Firewire cable. This DAC comes with a HiFi Tuning Supreme fuse installed.
The WLM Gamma Reference is based on the prestigious Minerva DAC from Weiss Engineering. It uses the same drivers as the minerva, downloadable from the Weiss website.
This dac has never lost a beat and is in excellent condition. The beauty of a firewire dac is that you don't get the same jitter problems associated with a USB connection.
WLM have chosen to use a high quality Trafomatic power supply to get the absolute best from this configuration.Capable of handling up to 24bit / 192kHZ through a Firewire connection the WLM Gamma Reference is the final piece of the puzzle for many WLM customers
  • The WLM Gamma Reference has the following inputs: 2 x Firewire 1 x SPDIF Coax 1 x SPDIF Optical 1 x AES/EBU
  • Outputs: 1 x RCA Analog 1 x XLR Analog 1 x AES/EBU Digital Out 1 x SPDIF Coax Digital Out
  • The following conversions are possible: Firewire to analogue AES/EBU (SPDIF) to analogue Firewire to AES/EBU AES/EBU to Firewire
  • Jitter suppression: Several signal re-clocking schemes are combined for extremely high jitter attenuation, making the GAMMA Reference virtually immune to jitter over a very wide bandwidth.
  • Converters: Eight times oversampling sigma delta D/A converters are used.
  • Power Supply: A generously dimensioned non-switching type Power Supply is used. All sensitive voltages have their own local regulators. The standby Power Supply leaves the Firewire chip powered, allowing to switch on the GAMMA Reference via the Firewire link. The Firewire bus power is not used by the GAMMA Reference. This allows the GAMMA Reference to be connected with computers that do not supply bus power. The mains voltages can be set to 100 – 120VAC or 200 – 240VAC
  • Software: Drivers for Windows and OSX operating systems.
  • Sampling frequencies: 44.1, 48, 88.2, 96, 176.4 and 192kHz
  • Maximum input wordlength: 24 Bits
  • Frequency Response: 0Hz – 20kHz +/- 0.3dB
  • Total Harmonic Distortion plus Noise (THD+N): < -100dBr (0.001%) @ -3dBFS input level
  • Linearity : @ 0 to -120dBFS input level : less than +/- 1dB deviation from ideal
  • Noise floor @ -20dBFS input: < -110dBr unweighted
  • Crosstalk: < -110dB, 0 – 20kHz
  • Interchannel Phase Response: < +/- 0.5°, 10Hz – 20kHz
  • Dimensions: 430x320x80
  • Weight . 7 kg
    • By caleb
      Item: Tellurium Q Black II Speaker Cable  pair 1.5m Z plug
      Price: $250 plus post
      Item Condition:9/10
      Reason for selling:No longer required
       Unit comes with full packaging purchased from futureshop uk.
      no longer required.
    • By Neo
      Item: Hoya filters
      Price: Hoya Super HMC pro1 UV 67mm- $50
                 Hoya HD UV 58mm - $50
                 Hoya Circular Polarizer 67mm -$30
                 Hoya Close Up set 58mm - $50
                 Hoya special effects filter 52mm -$30
      Item Condition: 9.5/10
      Reason for selling: no longer have the lenses
      Payment Method: Pickup - Cash, Paypal, can post at cost
    • By scribble
      Item: Devialet 400 Mono Amplifiers/ Streamer/ DAC/ PhonoStage.
      Price: $7900
      Item Condition: As New
      Reason for selling: NLR
      Extra Info: Selling a pair of Devialet 400 Mono Amplifiers in As New condition!
      Come with remote and original factory packaging. These amps don’t disappoint and they have an excellent Dac and PhonoStage. Cheers.
      * Even under the unforgiving microscope of the Magico Q7s, the pair of Devialets sounded like much, much, more expensive electronics. This level of dynamic verve, bass authority, clarity, and resolution is unprecedented at this price, in my experience.
      Just to check myself, at the end of the auditioning I switched back to the Berkeley Alpha USB and Alpha DAC reference digital front end, Soulution 725 preamp, and 701 monoblocks, a roughly $230k combination (which I had not heard for about two weeks). This juxtaposition only reinforced just how great a pair of Devialet 200s sound, and what an amazing value they represent. A mono pair is significantly better sounding in all respects than a single stereo unit.
    • By Ericcklau
      Item: MICHAEL JACKSON THRILLER EPIC 25 3P-399 Japaneses Press
      Price: $35
      Item Condition: NM
      Reason for selling: no longer needed
      Extra Info:  with Obi and Insert Japanese Press
      Item: MADONNA LIKE A VIRGIN SIRE P-13033 Japanese Press
      Price: $25
      Item Condition: NM
      Price: $20
      Item Condition: NM
      Extra Info:  NO Obi and Insert Japanese Press
      Item: MADONNA MATERIAL GIRL,ANGEL AND INTO THE GROOVE SIRE P-5199 Japan Press
      Price: $25
      Item Condition: NM
      Extra Info:  With Obi and Insert Japanese Press
      Item: WHAM MAKE IT BIG EPIC 32 3P-574 Picture Disc Japanese Press
      Price: $35
      Item Condition: NM
      Extra Info:  NO Obi and Insert Japanese Press.
      Item: WHAM! MAKE IT BIG EPIC 28 3P-555  Japanese Press
       Turramurra 2074
      Price: $20
      Item Condition: NM
      Item: WHAM! LAST CHRISTMAS EPIC 12 3P-575 Japanese Press
      Price: $35
      Item Condition: NM
      Item: AIR SUPPLY DELUXE PACKAGE '82 ARISTA 20RS-21,22 2LP Japanese Press
      Price: $35
      Item Condition: NM
      Item: SIMON & GARFUNKEL CONCERT IN CENTRAL PARK GEFFEN 36AP 2271,2 2LP Japanese Press
      Price: $25
      Item Condition: NM
      Item: LINDA RONSTADT MAD LOVE ASYLUM P-10799Y Japan Press
      Price: $25
      Item Condition: NM
      Item: ERIC CLAPTON BEHIND THE SUN DUCK P-13069 Japan Press
      Price: $25
      Item Condition: NM
      Item: AEROSMITH GREATEST HITS CBS/SONY 20AP 3129 Japanese Press
      Price: $65
      Item Condition: NM
      Reason for selling: No longer needed
      Payment Method: Pickup or By Post - Cash, Paypal Only
      Extra Info: Japanese Pressing With OBI and Insert
      Item: BON JOVI NEW JERSEY MERCURY 25PP-258 Japanese press
      Price: $50
      Item Condition: NM
      Item: Japanese Pressing KENNY LOGGINS NIGHTWATCH MASTERSOUND VINYL LP
      Price: $15
      Item Condition: NM
      Item: US Pressing MICHAEL JACKSON SCREAM EPIC
      Price: $10
      Item Condition: NM
      Extra Info: US Pressing
      Item: US Pressing JANET I GET LONELY VIRGIN
      Price: $8
      Item Condition: VG+
      Item: Japan Pressing CYNDI LAUPER MONEY CHANGES EVERYTHING PORTRAIT
      Price: $10
      Item Condition: NM
      Extra Info: Japan Pressing with OBI and Insert
    • By Frank Prowse Hi-Fi
      Item: FS: Monitor Audio Gold 200 5G - Satin White
      Price: $4,999 (RRP: $6,990). Free Delivery in Perth Metro - Interstate shipping at buyer's cost.
      Item Condition: Absolutely immaculate
      Reason for selling: Wrong colour!
      Payment Method: Bank Deposit
      Extra Info: These speakers are the brand new 5G Series. We were the first store to get a pair of new Gold speakers in for audition - at the time there was no colour option available. These present as new and are perfect in every way, not a blemish or mark. They have had their typical run in time - I would guess they have had no more of 100 hours use, 90 of which would have been the run-in period. We have had some assistance from the distributor in regard to moving these along to make way for our floor colour option of choice, so take advantage of this one-off special price of a truly beautiful sounding and looking speaker. Full five year warranty will apply.
      Full specifications found here:-
      https://www.monitoraudio.com/en/product-ranges/gold-5g/gold-200/
