HiFi-Man
Trevor Lees Audio Valve Preamplifier - Looking for info
I was searching for a valve preamplifier  to match with my McIntosh 240. Recently found this odd looking unit with someone I know . He was using it only very occasionally and was happy to sell it. Anyway I decided to give it a try. Seller said its a Trevor Lees Audio valve preamplifer. Unfortunately he don't have much detail info about this unit.
- There are only very few switches on the front panel without any labels ( Separate volume controls for left and right channel & two switches with unknown functionality)
- It seems like there are four AUX inputs and one Phono input.
- Caps I could see are Sprague, Seimens, Wonder Cap (Ultima series with Danor).
- Valves from right to left - Zaerix ECC88, Sylvania 6SL7, Zaerix 6DJ8, Zaerix 6DJ8, Zaerix 6DJ8.
- Not sure which make is the volume pot.
- It has got a separate power supply unit ( Power supply unit is a bit noisy when switched on ).
Anyone else here using the same preamplifier (Will be helpful for me to gather more info on this) ?
Pictures
I tried connecting it to my McIntosh 240 and it sounds good. I'm sure it has got a lot of space for further improvement.
____________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Edited by HiFi-Man
I owned this model from Trevor Lees for some two decades and was very happy with it. It is his version of a classic 4-tube preamplifier circuit, using 6DJ8/6922/ECC88 tubes (interchangeable); dual-mono construction (2 separate channels); massive power supplies and premium tubes. I had the model with the clear black acrylic top--you could meditate at night on the glowing valves within. Allen Wright had a FVP (Four Valve Preamplifier) preamp too at this time which was popular. Simple circuits, well-executed.
In this era I remember that Trevor L was attempting to duplicate/clone classic pieces of hi-fi gear, such as the Proac Response 2 speakers and ribbon speakers, and some electronics. This preamp was one product of this drive. He certainly had a lot of enthusiasm and flair. I thought of the result as the poor man's high end in Oz. His shop was where the fun was.
The 2 knobs are L and R volume controls. One advantage there is that you can do a little channel balancing if you have a weird room. The phono section accommodated my Sumiko Blue Point (high output MM) and had plenty of gain. I can't recall which switch engaged the phono but there's very few switches to choose from...
The tubes in the photos look original; I ended up using all Telefunken NOS in my model as these were the best sounding ones I had tried up to that point AND in the 1980's were not too expensive! I recall that the Zaerix type came with the preamp--and sounded very good. It's a great platform for tube rolling but that expensive hobby has its limitations and diminishing rewards, as I discovered. Nevertheless you can pick up this tube easily even today (I prefer NOS types myself. Especially Mullard and Brimar).
I recall the sound fondly. It was clear and clean without any gross sins of commission (doing things wrong) and resembled the 'Audio Research house sound' to me (at that time). It did great tone and timbre so I didn't feel like I was missing anything in my system. I forgot about hifi and just listened to the music (remember those days?). It certainly got the best out of my Perreaux 2200B amp running into Celestion 600 speakers. Later I upgraded to the VTL 75/75 running into the Martin Logan CLS. I replaced the preamplifier in due course with a Kebschull 150 model--and that was a real upgrade. Nevertheless, I spent many, many happy musical hours thanks to this Trevor Lees preamp. It was reliable and I ran it for many thousands of hours.
There was one incident when the system was playing and a certain retailer was poking around in the innards of the preamp checking something. He received a nasty electrical shock but I don't think it was a fault of manufacturing. Just noting.
The power supply is not noisy at all--so obviously a service is in order, with attention to the caps (some of which may need replacing by now) and contacts. You *don't* want nasties coursing through your system.
On another occasion I schlepped the massive box containing the power supply and the preamp together to the Mascot airport check-in as I was taking it to Melbourne from Sydney for a service. I didn't want to entrust the delicate innards to the tender mercies of a courier. To give you an idea of the times prior to strict airline security, I actually talked my way onto the flight as there was an empty seat next to me that would hold the box!!  Try that today...now I'm feeling old.
Hope this helps.
I've also had one, I agree with all the above comments. From the look of the knobs, the pictured one is an early production, later ones had larger and more aesthetic knobs
Good ol' Trev was a very smart fellow - with an excellent design pedigree.  :thumb:  (Well, maybe more "an excellent implementation pedigree" - given Dougie says this is his implementation of "a classic 4-tube preamplifier circuit ".)
I enjoyed my conversations with Trev.  :)
Hope this helps.
Thankyou very much for a detailed writing. I really enjoyed reading it.
Seems like I should start with fixing power supply, new valves and checking capacitors. Also,  I'm planning to move both the preamplifier and power supply to a new thick aluminium case with all switches  and input/output marked using laser etching. I think replacing those volume pots with better ones will also benefit the sound.
Thankyou very much for your reply Michael & Andy.
There are no markings at the rear panel. I guess the input RCA jacks in gold colour near to the ground terminal is the phono input.  Also, at the front panel one switch on top enables all AUX input together and second switch at bottom enables the phono input.  Its confusing as there are no markings for the switches and input/output RCA jacks.
Looking at inside I think two set of RCA jacks on the left side (in above photo) are two different outputs and all other ones are inputs. If so it should be three AUX inputs and one phono input. Correct me if I'm wrong. Anyone of you remember how it is done with those switches and connections at rear?
Edited by HiFi-Man
Unfortunately I'm guessing but my recall is that the inputs I had were labelled. I was a hi-fi newbie and I had few issues. It won't take much to discover the phono input as it would be the only one to produce sound from the turntable output leads. The rest are 'interchangeable' as I recall.
You have correctly designated the back panel as far as I can remember.
Is Trevor L. still around in the flesh? I saw him in his shop through the window about 10 years ago
Yes, Trevor is still around, he has a shop in Glenferrie Rd, Hawthorn.
Maybe go and see him there, take the preamp and label the inputs/outputs and the switches.
Herby
Unfortunately I don't have a turntable at present to test the phono as I have sold all of them. Thought of going for something special latter.
My be this preamplifier is a very early one from the time he made some sample units and he didn't put any markings on case.
Herby
3 hours ago, Tubularbells said:
Shop has long gone and Trevor now resides in Sydney from what I understand.
Seller of this preamplifier said Trevor closed his shop but its still stacked with heaps of audio gears.
I'm thinking about transferring the preamplifier and power supply into a new case.  Thinking about the case in below link for preamplifier.
https://www.aliexpress.com/item/32794647874.html?dp=5306333fac8a28fce632a2a68c8cd3bf&af=879988&cv=47843&afref=&mall_affr=pr3&dp=5306333fac8a28fce632a2a68c8cd3bf&af=879988&cv=47843&afref=&mall_affr=pr3&aff_platform=aaf&cpt=1573176888062&sk=VnYZvQVf&aff_trace_key=74d106fedbff4ebabaaa6c7926fbf8f5-1573176888062-00406-VnYZvQVf&terminal_id=78b7bcbc3d7641258955c51983b85e10
Will be good if I can get all switches, inputs and outputs marked using laser engraving. The input selector looks odd in this one, so adding a relay based input selector will be good option to make things more straight forward. Will replace the existing volume pots with good quality ones.
Edited by HiFi-Man
A cheap - but very basic enclosure.  You also might like to consider Trev's reason for using a separate case for the PS - putting it all into one case might result in hum/noise?
I use these guys:  https://modushop.biz/site/
They can drill and engrave - but you have to provide them with a '.dxf' file (for their CNC machine).  :)
Thankyou for the modushop link. I will check it.
I will never put both power supply and preamplifier into single case. Sorry,  I didn't mention it clearly in my previous post. Two major factors attracted me to try this unit is i) Separated power supply ii) Left and right volume controls avoiding balance control. Love the minimalistic design for short signal path.
I'm struggling to find a case for this preamplifier. Because the single PCB on which most of the components are mounted is 420mm wide. So the new case should have a minimum of 420+mm width available inside.
Or else the next option is to separate the valves and big capacitors from the PCB,  get them mounted separately inside. Then the remaining components needs to be incorporated into a more compact PCB layout. Doing this way it will be perfect. But my worry is the labour cost of a tech to get this done :o .
What is your opinion on adding a relay based input selector to the unit?  If it will degrade the sound quality anyway?
Aah - not sure any Modushop cases are that wide.  ('Slim Line' are only 415 wide.  :( )  But just looking on their web-site at the 'Pesante' - they are (internal) 430mm!  :)
I can create the .dxf files for you, if you're not confident doing them yourself.
I think it would be an excellent idea.  Using gas-filled relays such as the NAIS DS4E will give you a much better connection than any rotary switch.
Edited by andyr
The Lee brothers are still trading as I bought from them just recently & they sent it to me in Adelaide from Hawthorn.
They are also still selling audio on ebay as they have always done under Christopher's, name  "christophersaudiophilestore", & currently have a number of items listed.
Trevor's amps have always been rather agriculture in appearance but that in no way indicates their performance which in my experience has always been exceptional.   Labeling  was commonly just pieces of Dynamo tape so has probably come unstuck & lost over the years.
Edited by Rockman
Thankyou very much for your support Andy. It will be a great help if I could get your help in preparing .dxf file.
Now I'm preparing for the move from Melbourne to Adelaide. Will PM you once I got the the plan and a rough sketch is made.
Thanks again :)
Sorry for the late reply. I was a bit disappointed  last few days as two of my other units got into some trouble as it went into the hands of a wrong person.  Was trying to get them all done before moving to Adelaide.
Edited by HiFi-Man
Yes, they are active in ebay but I'm not sure if their shop is open in Hawthorn. I agree, its appearance has no relation to its performance, love this unit.
Initially I sent a message to Trevor through his facebook page asking more info on this preamplifier and received reply from him yesterday.
He sent me the info saying those switches in front panel does switching ON/OFF for AUX and Phono.  This preamplifier has got a moving coil phono input with a high level stage.  Out of two outputs one is for power amplifier and the other for tape. He asked me to give him a call for more information.
NP. HFM!  :)
Quote
To Adelaide:(  My commiserations.  :winky:
Tell him you've got Andy Redwood assisting you.  :)
Edited by andyr
On 13/11/2019 at 3:34 PM, andyr said:
NP. HFM!  :)
Sure :)
Talked to Trevor and finally met Chris from Trevor Lees Audio at their office in Hawthorn,  Melbourne.
- This unit has got 3 high level(AUX) input and one MC phono input.
- Input impedance is set at the terminals with a fixed resistor ( Can be anything from 10 ohms and up to suit the cartridge. .3mv and up is a suitable output for the MC stage)
- Two switches on left are for selecting the input. Centre position is off, up and down positions on each selects different inputs.
- 12AX7 valve can be used instead of 6SL7 valve by using an adaptor.
- Originally there is a front panel and it is missing in the unit I have. They may have the front panel in their storage.
Will get this unit and power supply fully checked and serviced by Trevor Lees Audio :)
Edited by HiFi-Man
I w
21 hours ago, HiFi-Man said:
- Originally there is a front panel and it is missing in the unit I have. They may have the front panel in their storage...
I was going to suggest rather than getting an entire new case to consider getting a front panel made and fix it to the front.
For the back panel I would update the rca's with good quality new sockets.  Get a piece of perspex and cut holes to match the rca sockets.  Laser print a sheet of paper with the rca socket names in position (white text on a black background) , cut to the size of the perspex and cut the socket holes, and fix this sandwich to the chassis with the rca sockets (I hope I've explained this OK).
Here's a pic of one of Trevor's other preamps (from an SNA ad).  The design of all his amp cases was similar - a bit clunky and never truly reflecting the quality of the electronics.  Even if they can find an original front plate, you might be better designing and making your own.
Edited by audiofeline
I had a few of his preamps over the years and they are fantastic. The positive Vibrations and the later ZFB1. I also had some front panels remade out of Milled Black Aluminium or reverse engraved plastic. Trevor may have a few lying around, I gave him 3-4. Had many fun hours at both his Kew places aswell as Hawthorn. His speakers are also fantastic value.
On 27/11/2019 at 5:00 PM, audiofeline said:
I w
Thankyou everyone, from your posts I realised the unit is missing the front panel :)
Anyway, I have contacted Trevor. He was happy to give all info about this unit and get the unit checked.
Met his brother Chris in Melbourne....Yes, Trevor Lees Audio office store is still open in Hawthorn near Glenferrie. station.
Chirs helped me to get the unit fully checked and serviced. Also provided a front panel for both the preamplifier and poser supply.
They have got one more same unit sitting in their storage. So if anyone interested do contact Trevor or Chris.
Compared the sound from power supply and found its same on both the units and he said its normal.
At home it was a bit noisy because there was no bushes at the bottom. Chris suggested I can try 12ax7 valve in the place of 6SL7 by using adaptor to get it fitted.
I think it will be good if I'm replacing those two volume pots with good ones. I'm planning to stay with this case for now and plan for a new case slowly in future. Will post photo of the unit here
And it sounds nice.
Edited by HiFi-Man
When upgrading the volume pots I'd also consider replacing the RCA sockets with good quality ones (I have used Rean/Neutrik, but you can get more exotic/expensive than those).  It's an easy and relatively affordable upgrade.
    • By Yogus
      Item: Bottlehead Crack with Speedball Upgrade and Tube Upgrades (Chatham 6080WA, Brimar CV4003)
      Location: Melbourne, VIC. Will ship ($20AUD Australia wide)
      Price: $700 ono
      Item Condition: Excellent
      Reason for selling: Upgraded to Crackatwoa
      This headphone valve amp was built by myself in December 2018. I've used it up until November 2019 when I upgraded to a Crackatwoa. An excellent amp for high impedance cans such as Sennheiser HD650/600, Beyerdynamics and ZMFs.
      This will come with the stock tubes (RCA 6080s and GE input tubes) as well as tube upgrades for both the output and inputs: Chatham 6080WA and Brimar CV4003, all NOS when purchased. This combination of tubes gives a punchy and musical sound with a little bit of sparkle, yet losing none of the rich mids that valve amps are known for. The Chatham 6080WAs are sonic equivalents of Tungsol 6080s, which are ridiculously hard to find and are one of the most popular tubes used on Bottlehead Cracks.
      The finish is a Scandinavian Oil with a spray painted dark grey metal top plate. (There are some imperfections in the spray painting).
      I have other tubes that can be sold either together with the amp or separately (not included in the purchase price). All NOS and used briefly for testing.
      GEC 6080 - +$200 - a much warmer, sweeter tube than the Chatham 6080WA Tungsol 5998 +$200 - enough said...  Tungsol 6080 +$100 - punchy, musical
    • By AJL999
      Item: Copland CVA306 Preamp
      Price: $1,050
      Reason for selling:    NLR
       This seems to be a pretty rare beast.   6-channel valve preamp by well know Danish HiFi company, Copland.      I’ve had it for a few years – it’s a great performer, and built like a tank.       To be honest, I can find very little about this model on the Net, but it seems it’s still available from at least one US outlet – for US$ 3,995!
      I’ve used this in straight 2-channel mode, using the Stereo output L&R + the multichannel  Sub output.  But the intriguing aspect is that it will handle 5.1 surround inputs, and run them to a 5.1 power amp.    If you have (say) a Blue-Ray player that will decode and has analogue 5.1 analogue outputs, then this Preamp is way to put some “tube sound” into your system.  But at the same time you could use a 2-channel DAC / streamer (as I did) into the stereo inputs.      The unit has 6 Sovtek 12AX7LPS valves – all working fine, so far as I can tell.     So I guess a good opportunity for some level of tube-rolling.
      I have no box, so would prefer local pickup, but I could probably repurpose another box and mail it, if required – though it’s surprisingly heavy!  I could also leave it Sydney North Shore for pickup.
      http://www.divertech.com/coplandcva306.html
      I also found a copy of the manual online - but it's pretty basic.         https://www.manualslib.com/manual/752864/Copland-Cva306.html#manual
    • By thejt
      Item: Shanling MC-30 Music Centre (Valves)
      Price: $625 or $650 with Logitech Harmony 650 universal remote
      Reason for selling: Too much gear
      Payment Method: Pickup - Cash, Shipped - Direct Deposit
      I am the second owner of this locally delivered 240V unit and I am sure I will regret selling this later. Ask anyone who has ever come across one of these and they will back me up with how they were blown away by this little unit. The build quality is excellent, thick aluminium body and heavy transformers. The design is well thought out with the feet all featuring levelling. The sound it makes is lush and although it seems like it would not create a generous amount of sound at 3W (Class A) I can fill a lounge room with gorgeous sound without even going half way on the dial. This is without even using easy to drive speakers, I had used Quad 11L and Dynaudio Contour 1.32E which are both only about 86dB. It has a pre-out should you want more power, but I tried using a Quad 909 and preferred it direct. The unit actually provided more bass on its own. Feature wise, CD player, FM and AM radio, 3.5mm input and RCA input which should cover everything you could want.
      The original owner lost the remote but the unit can be operated from the controls on the device itself. Volume adjustment is a bit of a chore like that though so I picked up a Logitech universal unit which I can include for an extra $25 (cost $70). A common issue with many Shanling CD players is the occasion pause during cd playback but this is occurs only very occasionally and lasts about 1 - 2 seconds before resuming. The MC-30 has been otherwise faultless. I have the original double box so can ship at buyers risk if desired but note it is fairly heavy. Great chance to get into valves or Class A amplification without too much outlay. Questions welcome and I will try to answer best I can. Donation on sale to SNA. Please look at all the glowey bits in the pictures!
      Praise:
      https://www.stereophile.com/integratedamps/308shan/index.html
      http://www.charismaaudio.com/products/shanling/mc30.htm
    • By Tobez
      Item: Peachtree Audio Grand Pre, original owner since new Oct 2012
      Price: $1400 neg + shipping costs if nec ($3000 new + $750 worth of valves)
      Extra Info: RRP $3000 new + $750 worth of valves thrown in. Includes original manual, remote, 4 pairs of tubes/valves inc EAT Coolvalves with EAT Cool Dampers, Genalex Gold Lion, JJ Electronics and factory originals. Original box damaged in storage but I can pack appropriately for shipping if necessary. Excellent sounding solid state or hybrid tube (selectable via remote) preamplifier with loads of features, ESS Sabre32 9018 DAC, home theatre bypass, trigger in/out for power control, analog RCA and XLR in/out, optical, digital coax, USB type B (streaming from computer), headphone out. See link to manual below for more info.
      Link to manual - https://www.peachtreeaudio.com/media/support/Grand_Pre_Manual.pdf
    • By MJJW
      Item: Plessis Audio Model A Valve Amp
      Price: $2200.00 - Prepared to Neg.
      Item Condition: Excellent (New Cond.)
      Reason for selling: It was passed on to me by my Dad, and being sitting in a Box for a while. (Have two other Amps)
      Payment Method: Pickup - Cash, Paypal, COD, / Could also post at Buyers expense
      Was originally purchased from Len Wallis in Sydney by my farther who used it in his office as a small setup, I inherited it when he passed. Have another Valve Amp (Earle Weston) and a MF, this is just sitting in a box for the last few years seems rather a waste. The current/ original valves have only 135 hours on them. I've just unboxed it and integrated it into my system to test and sounds great. One of the other members (Sir Triode) here did a review of it here back in Feb 2017 (Link below), it goes by the name of a Classic. Whether Plessis rebadged it or Classic did who knows, in any case is sounds excellent. Can operate in both linear mode (40W) or Triode mode (20W) with a switch on the back of the Amp. It has a Bias Adjustment System via 4 dip switches and a dial. Has an Elapsed Time Meter to indicate how long the valves have been in use for.
      Specifications:
      See image of Specifcations from Manual.
