Spider27
Matching Heavy Tonearm with medium to High Compliance Cartridge
In general rule, Heavy Mass to match with low compliance cartridge. Is there a way to make medium to high compliance cart to match with heavy mass tonearm?
Many vintage tonearm are heavy mass and were meant to pair with low compliance MC cartridges such as Denon 103.
Nowadays, most of MM cartridges is medium to high compliance if I understood correctly and might not match well with old heavy tonearms.
I initially thought that putting extra weight on headshell would put more weight on cartridge so it would work but it actually add more weight on tonearm so it will do even worse.
In that case, how about changing  to lighter headshell? My guess is that it will reduce the weight of the overall tonearm so more compatible with medium to high compliance cartridge.
Is this correct?
If not, does anyone know any tweak that can make it work?
No, sorry.  :(
An arm with a heavy effective weight (like my 'Univector' - 23gm) must be used with a low compliance cartridge - like a Benz LP or ZYX Airy3.
If you have a very high compliance cart (like my Stanton WOS CS100 - compliance 30) ... it needs to be matched with a low eff. weight arm (for instance, a Magnepan 'Unitrac' - at 7gm - is a perfect match  :) ).
14 minutes ago, andyr said:
No, sorry.  :(
Thank you. I read below article and it seems that he can reduce effective mass from 23g to 10g by reducing headshell weight, increase counterweight and remove other small parts. Isn't it proving that effective mass can be reduced by applying less on headshell and more on counter weight?
http://web.archive.org/web/20070525031412/www.lenco-lovers.com/forum/viewtopic.php?p=10712&sid=af19534f42772db17ed3615924715046
I always thought that effective mass wasn’t relevant to the counterweight - the CW is there to counterbalance what is already a heavy arm so the cartridge has correct tracking weight.
According to the article, effective mass is all about sum of all the moments of inertia.
I= momentum of inertia=M×d²
M= mass of the considered part of the arm
d= distance to the pivot
Lowering the mass of the headshell causes counterweight is much closer to the pivot.
It is what I understood from the article but I do not know much either hence asking others who are more experienced. :)
5 minutes ago, Gryffles said:
@Spider27 have you tried it? Might sound fine.....
No, have not. I am thinking to get a vintage heavy mass tonearm but do not have one yet. If possible, would like to get feedback first from others who have one and tried it before.
Correct.
Lowering the mass of the headshell causes counterweight to be much closer to the pivot.
Sure - as does using a lighter cart.
The optimum position of the c'weight is right next to the pivot.  I actually went the effort of using a belt sander to grind down one side of my c'weight - to lighten it, so I could move it right up as near as it can be to the pivot.
EDIT:  this sounds wrong - but I have 2 different weights I can use on my arm; this enabled me to use the heavier one.
I haven't yet read the article but I find it difficult to believe you can turn a 'heavy' arm into a 'light' arm just by reducing headshell weight and adding to the c'weight.
And how would you actually confirm that this is what you'd achieved, after you'd done it?  :)
Edited by andyr
Clear something up.
Your original post, here:
suggests you already have a heavy mass tonearm?  (And a medium to high compliance cart.)
No. I do not have one yet. Thinking to purchase one like Lenco TT that comes with the arm that is heavy mass.
I saw some posts that they match with this 23g heavy mass tonearm with Ortofon OM series high compliance cartridge with suggested method on the article.
If it can be done with Lenco original heavy mass tonearm with medium to high compliance cart, can't it be done with other vintage heavy mass tonearm too?
High mass tonearm with Ortofon OM cart - won’t work well. The OM cart is very good sounding in lighter tonearm but was flat sounding on a heavier one. A good match to put on a Lenco is the Ortofon AS212. It’s the correct length for the Lenco and matches the OM for compliance. It’s also very good sounding.
Edited by Mr Thorens
Use the Vinyl Engine site > Tools > Cartridge Resonance Evaluator.
https://www.vinylengine.com/tools.shtml
Put in the know variables of both Arm and Cartridge....see the separate ARM/ CART Data Bases for both that are available at the forum.
If not listed, do a search and find out the spec's then run evaluator.
As Mr Thorens says:
I would suggest the advice you got on the Lenco Forum - which you stated here:
was related to Lenco owners wanting to do the best with the heavy arm they bought with their Lenco.  IOW - not ideal!  :)
So if you want a Lenco TT and an Ortofon OM ... you need to also buy an Ortofon AS212 - as Mr Thorens said.  :)  Or buy some other TT which has an arm which suits the Ortofon OM.
Of course, it's your choice to take the Lenco 'advice' over the advice given here.  :lol:
