Alanpartridge
FS: relist - Sonique 5.5 SE Speakers (Perth)
Item:  SONIQUE 5.5SE speakers
Price: $700
Item Condition: Excellent
Reason for selling: I am trying out bookshelves and Sub
I am moving to bookshelves so I'm having another go at moving these on.
I have used these speakers for two and a half years and they remain in excellent condition.
Floor spikes with original plus upgraded Binding post connectors are included.
Manufacturers description below followed by previous owner - SNA member Mirvapet's modification description and wonderful photos :
The Sonique 5.5SE is a Special Edition loudspeaker that reflects Sonique Audio's commitment to build high performance accurate loudspeakers that represent unprecedented value for money.
The standard Sonique 5.5 is in itself a remarkably successful loudspeaker that was the winner of the 1996/97 "Sound & Image Award" for Loudspeaker of The Year.
For some manufacturers, awards like this means the end to engineering and refinement of a product, but at Sonique our engineers saw a challenge to improve the Sonique 5.5, this has led to this Special Edition.
The resultant Sonique 5.5SE redefines many of the limits for such a product. In fact, the New Sonique 5.5SE has already won accolades from the HI-FI industry, winning the 1998 AVL Best Buy Award.
Features
SPECIAL WIRING: No compromises was the demand, so Sonique designers incorporated special wiring throughout, to minimise its possible effect, and maximise performance.
CABINET CONSTRUCTION: Our designers went back to the drawing board (CAD System), and the New Sonique 5.5SE cabinet was developed. Additional features include finely finished cabinets with exposed timber fronts. Further refinement includes new flush fitting integrated grilles.
LEAD LINING: The New Sonique 5.5SE is exactly that, a Special Edition. To reproduce music from a loudspeaker the way it is meant to be heard requires an inert cabinet that doesn't contribute sound of its own. To do this, the New Sonique 5.5SE is fabricated from MDF up to 43mm thick, internally braced and Lead Lined to produce a very rigid and inert cabinet.
CABINET DESIGN: Sophisticated designs such as the Sonique 5.5 requires precise internal proportions and volume. The New Sonique 5.5SE has been modified for improved performance by increasing the width and height, but still incorporating a minimised baffle design to avoid unwanted reflected sound. This modified cabinet has also permitted a mineral filled base cavity to be incorporated for further rigidity, stability and improved sonic performance.
CAST SPIKES: The New Sonique 5.5SE is supplied as standard with adjustable cast spikes, and protective bases to locate the speaker exactly without damaging any floor surface. These spikes further isolate the Sonique 5.5SE from the room and environment to further improve performance.
CROSS OVERS: All Sonique loudspeakers incorporate high quality components throughout. The New Sonique 5.5SE is given even more attention, by utilising the best of the components available. Providing exactly matched pairs of loudspeakers to provide precise musical reproduction.
INTERNAL DAMPING: Sonique's uniquely designed Acoustic Pyramid Foam is used exclusively in the Sonique 5.5SE, to stop internal reflections, that ensures this is a truly high performance loudspeaker system.
SPECIFICATIONS
Frequency Response: 46Hz-20kHz
Impedance: 6 Ohms
Sensitivity: 89dB
Rec. Amplifier: 20-250watts
Weight: 24kg each
Dimensions (cm): 97Hx19.2Wx27D
REVIEWS
http://hometheaterhifi.com/volume_7_3/sonique-55-se-speakers-8-2000.html
http://maddmogg.com/Sofa/reviews/speakers/Sonique/sonique_5-5.htm
http://www.stereo.net.au/forums/topic/73346-sonique-audio/
Description below from original owner:
I have also upgraded the crossovers in these speakers, replacing the standard Solen capacitors with the much better Mundorf MCap capacitors.  The tweeters have been upgraded also to electrically equivalent but sonically much better SEAS Prestige 27TDFC tweeters.  The original Vifa D27TG tweeters are also included.
Price: $700
Features
SPECIFICATIONS
Impedance: 6 Ohms
Sensitivity: 89dB
Weight: 24kg each
REVIEWS
If these are anything like the Whatmough 201 lead lined monitors l heard 20 odd years ago. These will sound absolutely stunning. For the price, these are an absolute bargain. GLWS.
A lot of speakers for not a lot of money.
Also have bought itemsfrom from the seller without issue
glwts
Better then the Whatmoughs IMO.
How so?
11 hours ago, Rhien23 said:
How so?
I reviewed the 201's when Collin bought them up and found them to be cold and hard. Also, found the integration between bass and midrange to be disjointed lacking flow or rhythm . I nearly bought a pair of 5.5's as I found they disapeared fairly easily and their tonal balance was to my liking and not overblown in any particular frequency area.
I didnt particularly like the bass in the 5.5SE but that was IMO, my only criticism of these speakers for the price.
These seem like an absolute bargain. Perhaps the brand name has faded away so nobody really knows how much of a player Sonique were at one time. DNA going back to Duntech too I believe.
IMO These things are very nice sounding speakers and image very well.  Quite a bargain.
I used to own a pair of these. They are wonderful speakers. I'm getting old, because I can't really believe you can buy these for $700!
There are a pair of Bookshelf speakers with my name on them!
These have to sell first...
Did these end up selling?
Yes - to be picked up in a couple of weeks.
    • By kelossus
      Item: Mcintosh C2300 Tube Preamplifier
      Price: $5000 FIRM - No offers
      Reason for selling: NLR
      Comes with NOS Telefunken ECC83s in the linestage. Factory tubes in the MC/MM phono section. Has the new Mcintosh replacement remote which looks a million times better than the old and the plastic doesn't go sticky.
      IMO the C2300 and C2200 are far better preamps than the newer models.
      I don't have the original box so shipping local pick up only.
      Apologies for the smudges on the glass face plate, these were not visible when I was taking the photos. In near new condition.
      Specifications
      Frequency response: 10Hz to 100kHz
      Total harmonic distortion: 0.08%
      Gain: 60dB (MC), 40dB (MM), 15dB (line)
      Input sensitivity: 0.45mV (MC), 4.5mV (MM), 450mV (line)
      Signal to noise ratio: 80dB (MC), 80dB (MM), 93dB (line)
      Output: 2.5V (Pre out), 8V (Pre out Max)
      Dimensions: 444 x 152 x 457mm
      Weight: 13.41kg
    • By palexsia
      Item Condition: New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Templestowe State: Victoria Payment Method: Cash pickup , eft . Reason for selling: Selling for friend Further information:
       As photo
    • By jakeyb77
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: St Kilda East State: Victoria Payment Method: EFT Cash PayPal (you pay fees) Reason for selling: Too many TT Further information:
      Pictures form the description.
      Plinth has seen better days due to an accident. Just a couple of chips that could be filled and stained again. It’s still a straight plinth.
      This table has been used about 4 hours since I put it together.
      These parts were brand new with 4 hours on them.
      Mober bearing and inner platter and cross brace. Mose PSU. Premotech motor.
      Brand new belt and springs and grommets.
      Old parts- plinth, top plate, sub- chassis and hardware. Linn rubber mat. Linn Masonite base.
      Doesn’t come with arm but I also have a Wand Tonearm for sale. Also have a Zu Audio Denon 103r with less than 300hrs
    • By MGO
      Item Condition: Very good for age: 60 + Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Little Bay State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR Reduced $$$:
      Western Electric 10GA Tinned Copper with Cotton covering.  Twisted Pair Speaker Cable
      The price is for a stereo pair of 3 metres.
      This is the wire Duelund copied "A wire originally born of the desire to improve upon legendary studio vintage cabling."  The legend is this WE cable!
      This is great speaker wire especially for bass and mids.
      It is twice as thick and has 4 times the cross sectional area of the famous WE16GA as featured on Jeff's Place
      https://jeffsplace.positive-feedback.com/the-vintage-beat-western-electric-we16ga-speaker-cable/
      NB. Other lengths available - to be listed.
    • By christos540
      Item Condition: Mint - approx 10 hours listening time Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: PALMVIEW State: Queensland Payment Method: Paypal, Cash on Pickup Reason for selling: Great sound but I have fallen in love with something Hi everyone,
      I'm am selling my new Master & Dynamic MW65 Wireless Headphones. These are in mint condition & they sound great, however there's another set of cans that I have
      fallen in love with, so I am putting these up for sale. Everything is in perfect working order. Comes with original box, packaging, cables etc. They have a great 1970's industrial look to them
      & IMO are a reasonably neutral headphone. Supports AptXHD as well. PRICE is NEGOTIABLE. Specs below.
      MODEL
      MW65
      ACTIVE NOISE-CANCELLING
      Feed-forward and feed-back (hybrid) active noise-cancelling technology
      MATERIALS
      Leather, Anodized Aluminum
      DIMENSIONS
      165mm x 190mm x 66mm
      CABLES
      1.5m Standard 3.5mm Audio Cable, USB-C to USB-C Charging Cable (with USB-A Adapter)
      HEADPHONE CONNECTION
      Optional 3.5mm Passive Audio Input, Two-Prong Flight Adapter
      MICROPHONE TYPE
      Beamforming Noise Reduction Mic Array
      VOICE ASSISTANT
      Google Assistant built-in, voice assistant enabled
      DRIVERS
      40mm Beryllium
      WEIGHT
      245g
      EAR COUPLING
      Over-Ear
      IMPEDENCE
      32 Ohms
      EAR PADS
      Replaceable Lambskin-Wrapped Memory Foam
      BLUETOOTH PROFILE
      Bluetooth 4.2 Supporting AptX, AptX HD and SBC.
