Krispy Audio
Shunyata Venom Halloween Specials!
Our Halloween Special is now LIVE! The first shipment of the brand new Shunyata Venom noise reduction power cables has landed and you'll save 10% from now until Sunday. For under $600, the NR-V12 offers a 12-gauge cable that surpasses inferior cables with its >12dB measured noise reduction @1MHz, high quality connectors, Fluorocarbon dielectric, techflex protection, and the security of serial number identification. https://krispyaudio.com.au/categories/specials-ex-demo/
No special on the NR-V12 with IEC C19 connectors?
Also, how does the new Venom NR range compare to the Delta in terms of noise reduction? Any chance you could measure with the Blue Horizon like you did in
Hey, we can offer the same discount for the C19 version, no problems. It would just need to be ordered in because usually for a feed cable people would go with the larger gauge V10. Please let me know and I can get it happening.
I haven't got the ability as yet to test the cables with my noise analyser (and I've loaned it to a customer), but the NR tech is similar to the Delta. The separator now between Venom and Delta is the VTX geometry of the Delta. I'm using a Delta as a feed cable, and will shortly be running a mix of V10/V12 after my conditioner.
Do you have pics of the V12 and V10 side-by-side to show thickness between the two? Also how stiff are they?
Trying to work out if routing a V10 would work behind my cabinets
They are close in terms of flexibility, very little difference in it. Overall diameter of V12 is roughly 12.5mm vs 14mm on the V10. V12 on the left, V10 on the right. The V10 as a feed cable is doublely important to have the wire gauge, also for amps V10 is the best.
They are far more flexible than equivalent sized cables I’ve had here so I don’t think it would present an issue in a tight spot.
We have one left in stock of the V10 with C19 btw!
Edited by Krispy Audio
