Nick73
FS: KEF Reference Series Model 105 Series II w/ Spare B110 Mid Drivers
Item: KEF Reference Series Model 105.2 with spare B110 midrange drivers (matched pair)
Price: $2,300
Item Condition: Drivers, Excellent. Mid and tweeter housing, Excellent. Wooden cabinets, Some blemishes but generally good
Reason for selling: Downsizing
Payment Method: Pickup - Cash
Extra Info: Beautiful example of top end British 70s laid back HIFI sound. I have had some wonderful moments with these speakers. Need a lot of juice to get those massive bass units under control. Had it paired with McIntosh MC7300 which I have also listed for sale. Found a pair of brand new old stock mid drivers which I had installed (drivers alone cost me $400). Will include original matched pair of mid drivers. To my ears I couldn't tell the difference when I installed the new mids. Bass drivers were rebuilt by previous owner just before I bought them. Ordered a crossover kit upgrade but to my surprise found that the crossovers had already been upgraded so will include all the new caps from crossover kit. These speakers sit on removable casters which are in perfect working order but I would recommend removing the casters and placing on low stand. I have also used sorbathane half spheres instead of casters on floating floorboards with great results. Also have a thin layer of sorbathane between the Mid and tweeter housing and bass cabinets which I will include which I feel help give more clarity. One mid dustcover is missing. Have enough original spare dustcover cloth to redo bass covers if you ever feel the need.
Specification: Model 105.2
System type: Three-way, floor standing
Enclosure type: Closed box
Size: 965 x 415 x 455 mm (38 x 16.3 x 17.9 inches)
Weight: 36kg (80 lb)
Input Impedance: 8 ohms
Rated maximum power: 200W programme
Amplifier Requirements: 40-200 watts per channel into 8 ohms
Frequency response: 38-22,000Hz +/-2dB at 2m on measuring axis
Sensitivity: 86dB at 1m for 1W, anechoic conditions
Crossover Frequencies: 400, 2500Hz
Maximum output: 107dB on programme peaks under typical listening conditions
Finishes:  Walnut, teak, rosewood and black ash veneers
Grille: Black or brown cloth
System: SP1118 (up to SN2965)
Drive units: B300 bass unit (SP1071), B110 midrange unit (SP1057), T52 tweeter (SP1049)
Crossover: SP1119, SP1131, SP1134 and SP1135
System: SP1118 (from SN 2966 to SN4490)
Drive units: B300 bass unit (SP1071), B110 midrange unit (SP1057), T52 tweeter (SP1072)
System: SP1118 (from SN4491)
Crossover: SP1119 and SP2012
I had a pair of these from 1988 to 2002 and loved them. Rich sound, great for LP as not too prone to showing every bit of surface noise!
Used to run them with Phase Linear Pre-power.
    • By Bunno77
      Price: $2500 Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Brisbane Coorparoo State: Queensland Payment Method: Bank Trans, Paypal, Cash Reason for selling: Not being used Further information:
      Unfortunately this just isn't being used anymore. Absolutely fantastic amp in surround or 2 channel. Heaps of info about these here and online.
      Recently replaced 1 module from Magenta at about $500 (great that this is so easily repaired. 4 screws)
      RRP was about $7,000 USD when new
      I have original double boxes to post and manual. Modules are very easy to turn on and off which is very handy to keep some spare if not being used
      Power Output: 350W RMS continuous into 4 Ohms Distortion THD: <0.007% at 1kHz at all powers up to 350W into 4 Ohms, <0.03% at 7kHz at all powers up to 350W Unbalanced and Balanced Voltage Inputs Thermally controlled forced air cooling Mains Voltage: 190 – 250VAC Remote trigger switch between On & Standby Command Functions: Switch between On & Standby Ability to inhibit individual amplifier modules Amplifier module will indicate Over Temperature condition Halcro Reliability Assurance Service
      SPECIFICATIONS:
      Inputs, selectable
      Unbalanced: RCA sockets
      Balanced: XLR sockets
      Outputs
      Internally bridged: Binding Posts
      Command Functions
      Amplifier module will indicate Over Current condition
      Gain
      Unbalanced and balanced: 29x = 29dB
      Power Supply
      Universal switch mode
      Power factor corrected
      Fully protected
      Compliant in all countries
      Fault Indications
      LED turns red if Heatsink temperature exceeds 78°C
      LED flashes red if current limit exceeded
      Distortion
      THD:<0.005% at 1kHz at all powers up to 350W into 4ohms
      0.02% at 7kHz at all powers up to 350W (typically <0.01% at 350W)
      Noise: <30nV/sqrt(Hz) @ 1kHz referred to input
      Impedance
      Input
      Unbalanced: 10k Ohms
      Balanced: 10k Ohms
      Output impedance at 7kHz
      <80 milliohms
      Power
      Consumption
      Idle: <14W
      350W with 4 Ohm load: <22W heat (>94% efficient)
      Mains Voltage
      100-250 VAC
      Dimensions
      Weight: 25.0 kg
      Height: 7 inches or 169mm
      Width: 17 inches or 438mm
      Depth: 16 inches or 410mm
    • By Eagleeyes
      Price: $2500 Item Condition: AS new Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: Upgrading AVID PELLERE Phono stage 2 box with seperate power supply
      Extra Info: The equipment is 18 months old and all is in perfect working order and has hardly been used comes with original boxes.
      https://hifipig.com/avid-hifi-pellere-phonostage/
    • By Eagleeyes
      Price: $3500 Item Condition: Very very good, one small scratch on top lid Shipping Options: Pickup is available Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: Upgrading   Esoteric E-03 dual input phono stage- run 2 turntables from one phono stage- Esoteric sound and build.
       Very Good one small scratch on top
      No longer required- Krispy sold one for 4000 a week or two ago
      All original packaging & Manual - (power lead missing will supply standard one.)
    • By Sound Station
      Price: $570 Item Condition: New Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Toowoomba State: Queensland Payment Method: EFT, Cash or Creditcard on Pickup Reason for selling: Super Isolation Buy! Further information: Mentor loudspeakers feature the same top-line wide-dispersion soft-dome tweeters and 6-inch drivers as Richter flagship Dragons, offering that extra room-filling ‘oomph’ from a bookshelf model. But the real secret is in the cabinets, whose crossover filter design and cabinet noise reduction techniques culminate in a big, natural dynamic sound.
      The soft-dome neodymium tweeters provide wide dispersion, producing a lively and spacious sound stage with smooth musicality, and a response extending well beyond human hearing.
      The highly efficient 6-inch mid/bass drivers harness composite cones combining the natural acoustic finesse of paper with the strength of modern carbon fibre technology. This produces ideal damping characteristics plus the coherence and timing essential to draw you into the music.
      The awesome bass is rich, deep and firm.
      New crossovers were painstakingly designed with feedback from a large team of audio specialists across Australia to produce emotional vocals, an astonishingly vivid sound stage and a smooth blending of frequencies. The highly stable off-axis response means the Legends maintain realism in a wide spectrum of listening environments – because everyone’s listening room is different.
      The cabinets have been completely redesigned using non-parallel panels to reduce standing waves, and the comprehensive bracing is positioned to minimise harmonics. Double thickness rear and front baffles and new high density damping makes these the most neutral and musical cabinets we have ever produced.
      www.sshifi.com
    • By Sound Station
      Price: $660 Item Condition: New Shipping Options: Pickup is available Suburb or Town: Toowoomba State: Queensland Payment Method: EFT, Cash or Creditcard on Pickup Reason for selling: Super Isolation Buy! Further information:
      Focal's Chorus 705 bookshelf speakers will give you the rich, dynamic sound you need to enjoy all of your entertainment sources to the fullest. The 705's compact, gently curved cabinet design makes it an attractive option for a stereo setup in smaller rooms, or as part of a multi-channel home theater system. The entire Chorus series borrows driver technologies developed by Focal for their sophisticated world-class speakers, giving you high-end performance at very special price.
      www.sshifi.com
      2 pairs available as well as two pairs of stands available.
