Claudio71
Technics SL1210 MK2
HI Guys,I'm looking for a good place in Melbourne for my SL1210 MK2 need a service.thanks
Hi Claudio - Why don't you try to do it yourself? It's not hard, you just need a few tools, a couple of hours, and some patience, and if you are going to replace the leads you need a soldering iron and some soldering skill. Just yesterday on mine I replaced the RCA cables and earth, put a new longer power lead on, lubed the bearing and did a general clean up and vacuum out, and finally added new hinges and a new lid.
The only drag is the number of screws you need to remove to get it into a state to work on it. The power lead however can be replace without a tear-down, you only need to remove the under platter cover (5 screws).
it's also easy to go further and pull out the tonearm and clean up the arm height adjuster if it has become stiff. Then you will have $200 or whatever saved to spend on some more vinyl. You will probably also be more satisfied knowing the job has been done properly.
I wouldn't recommend installing new tonearm Litz wires unless you are familiar and confident as its fiddly and takes a fair while.
There is a lot on the web about it.
Cheers, Norm
Thanks Norm.i prefer to pay for the job to avoid damages.im very busy at work and i dont have time for this job.i think the turntable need new rca and eart cables.the performance is not realy good,i try whit my stanton wos100 and my ortofon 2m black but im no happy.is 30 ears old im the first owner.
I had mine serviced by Earle, out of Stereophonic. He is a Technics tragic with a lot of experience, and will treat your turntable like he's rehabilitating an endangered animal. Highly recommended.
https://www.stereophonic.com.au/service-repairs/
As per the info at the link above, you can contact him directly via mobile.
Tony at Audio Dynamics could do the work.
    • By russell66
      Price: $350 Item Condition: Very Good Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Kardinya State: Western Australia Payment Method: Paypal Cash Bank Transfer Credit Card Reason for selling: NLR Further information:
      Project RPM 1.3 Turntable and Ortofon 2M Red Cartridge
      Excellent turntable, very good condition, If you're going to produce turntables at a good price as project do, then you need a good design, leave out what you don't need and focus on the parts that matter, and in my opinion Project do that great.
      I am not the first owner but when i purchased it the previous owner had hardly used it and the same has been true for me, so the cartridge has had little use and appears to be in good condition when studied with a magnifier. Sorry for the close up it is next to useless.
      The Deck is designed to have a round belt (about $25 to replace) It has a flat belt at the moment which is perhaps not right for the motor but i prefer the way it sits on the platter. I can't locate the round one.
      The cartridge is the Ortofon 2M Red MM, a really great cartridge.
      The whole package sounds very good, the turntable itself would suit further upgrades to the cartridge, despite the hype around spending more on an arm or turntable.
      I have the original box so postage should not be too difficult, it will be at your cost and risk. I would prefer local pick up for obvious reasons.
      A personal opinion: I have had and compared many, many turntables over the years and in my experience the matching of the cartridge and phono stage is by far the most important part of getting a good sound. The arm comes next. The actual turntable is the least important part. I could offer so many examples of this. We likely would never put an expensive arm and cart on this deck because we would tell ourself that the price of the deck does not warrant it. If you did though the difference between this and something more expensive would be minimal. It's a turntable and by nature of the vinyl you put on it they are musical.
    • By anthony vinyl
      Item: Micro Seiki BL 91 turntable with SME 309 tonearm
      Price: 3400
      Item Condition: very good
      Reason for selling: a very reluctant sale but want funds for another project  .
      Payment Method: cash ,  PayPal +% , transfer
      Extra Info: a very special combo. the SME 309 should need no introduction - see online reviews. superb in styling and a breeze to use.   the micro seiki is simply a beautiful turntable both in form and function.  from vinyl engine specs site it
      "Features a massive, thick, 12.2 inch platter, employing special alloy bearings machined and polished with techniques usually reserved for turbojet engines.
      Micro Seiki engineers devised an exclusive oil-bath damping system to support the entire rotating assembly in complete isolation from all mechanical resonances.
      A precision-ground drive belt connects the rotating assembly to the brushless, servo-controlled motor with total isolation from motor generated vibration.
      In fact, the BL-91 (L) is probably the smoothest, most vibration-free device of its kind ever built. the plinth is multi-laminar natural wood finished with hand rubbed natural ebony... 16 kg"
      all original handbooks for SME and micro seiki. . please note the benz cart is NOT included in sale price .  please also see blemish on tonearm where it sits in holder ( common )and blemish on plinth. also the wire connectors on the tonearm head shell to cartridge have shabby insulation that is unnoticeable from above and does not affect performance. would prefer a pickup but will consider postage. preference for pickup.  will consider seperating - although the unit is functionally and aesthetically outstanding as it is. .
    • By MGO
      Item: Technics Direct Drive Turntable SL Q2 Quartz
      Price:  Reduced to $195  $250  Prefer pick up
      Item Condition:  Very good for age
      Reason for selling:  Leaving vinyl
      Payment Method: Pickup - Cash, Paypal, COD
      Excellent TT!  Sounds good doesn't miss a beat.
      Auto arm lift and return.  Very convenient, doesn't go round and round wearing the style.
      Hinges of perspex cover gone.
      Comes with Shure SC35C cartridge, cork mat and damping.
      Could pack and send but prefer pick up in Sydney 2036.
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 Price Drop $2850 inc shipping Australia Wide, can do a little less if you can collect in person to save packing and freight.
      Item Condition: Excellent, Used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the external motor PSU and controller with a samurai silver coin from WA mint. So the turntable is dubbed "The Samurai"
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
    • By thejt
      Item: Linn LP12
      Price: 1600 ono
      Item Condition: good
      Reason for selling: small child is now almost ready to destroy everything I own. Best it go somewhere safe.
      Extra Info: Early Linn LP12 for sale equipped with Rega RB300 tonearm and Linn Asak moving coil cartridge. I am told that I am the third owner of this beauty with the original owner having it for many decades. The second owner got a newer Linn rather than upgrade. The fluted plinth is in pretty good condition with a few small nicks as seen in the photos. Lid is crack free with only minor swirling. Hinges replaced by myself so are almost new. No idea about the hours on the cartridge but it plays without a hitch and stylus looks very straight. I've put on less than 50 hours personally having only got it right before our child was born. It has been well looked after by all owners and I even have the original documents. Bonus shim for the tonearm in case you need to raise the height to accommodate a different cartridge. Happy for inspections for anyone in Perth.
