Honreekea
Suitable Interconnect for SME arm and Thorens Turntable
Brains trust:
Looking for a suitable RCA cables for my suspended Thorens TD160 Super and SME 3009 series III arm, where the interconnect won't't interfere with the "bounce" of the table.
Budget:  Can't pay stupid prices. (Would love 2nd hand)
thanks
You will need to get "phono" RCA cables, as regular RCA cables generally have too much capacitance.  And phono cables can be relatively expensive.  They might come up on the SNA classifieds, and certainly the auction site has many.
It also depends on what's under your SME arm...
- Many tonearms have a standard socket for plugging in phono cables, and use a RCA to Phono Socket cable.  It's often called a "mini-DIN" due to the appearance, but actually isn't a mini-DIN socket.
- However, some tonearms don't use a plug, and the RCA cables are soldered to the tonearm's wires, usually via a tagstrip.  This would use a RCA to bare wire phono cable.
- Some turntables take the tonearm's wires and solder them to RCA sockets mounted on the rear of the plinth, so a RCA-RCA phono cable is used.
A photo of under your arm could help with responses.
Edited by audiofeline
10 hours ago, Honreekea said:
Looking for a suitable RCA cables for my suspended Thorens TD160 Super and SME 3009 series III arm, where the interconnect won't interfere with the "bounce" of the table.
If your 3009 is the same as @djb's 3012 ... the connector is not a standard arm DIN plug but instead is a weird "4-wires-in-a-row "  SME-only plug (which has 2x thick pins and 2x thin pins, to force correct orientation).
If you don't have a cable for your SME3009, surely SME sells them?  But if you do have this cable - and think the SME-supplied cable is too heavy for your Thorens - then one option is to buy a Linn / Thorens arm cable and get a tech to replace the DIN plug with your SME plug.
Alternatively, I might be able to help you.  If you can supply the plug and the instructions (from SME) as to which pin belongs to which cart wire ... then I could fit this plug to a cable that I had made up for my LP12 (so the arm end is light) ... but no longer use.  But you would need to tell me how long the cable needs to be - in case mine is not long enough.
The old SME cables are indeed heavy, and both my original ones are looking a bit tarnished perished.      They do use the 4 pins in a line connector as standard, but you can buy conversion kits on eBay that replace the one on the tonearm with a plate that has standard RCA sockets.   Soldering required though.
Even though my main table isn't sprung, I still replaced the cable on the SME 3009 that I have installed in it anyway.  I opted to just permanently wire it, and soldered the cables behind the old connector (from memory you can just use it as a tag strip).   You'll want to source some nice light flexible cable for your suspended Thorens though.  I am sure there will be recommendations forthcoming.     I just used thin standard shielded cable from Jaycar IIRC.  Doesn't measure too badly, and for short runs with MM carts , it's quite good enough IMO.
Quote
Yep, that's why I posted....I want recommendations for phono cables.
a pic of under the hood....RCA all the way baby!
Quote
Thanks for the offer.....It RCA all the way, as far as I can tell.  When I googlled  i was hoping to find some sort of  Litz cable arrangement, ie won't interfere with bounce and low capacitance
here's hoping ;)
I have a MC mounted on this SME
Aah - if you had posted this first ... we would all've understood your setup.  :)  How long does the cable need to be?
And, btw - 'litz' is certainly feasible ... but the litz wires have to be inside a braided shield ... which adds some stiffness.  :(
Edited by andyr
I have been pondering this, and whichever cable you select, I would constrain it near the turntable end (zip tie it to a weight that sits beside the turntable, or something else fixed), and bend it into a loose loop before attaching to the SME arm RCA plugs.  This way there is little weight pulling on the suspended tonearm and maximum flexibility of movement.
You could go as far as attach (solder to the back of the SME arm RCA plugs) a short, super light set of wires, just twisted litz might be OK if noise pickup isn't a big problem, and terminate them at a pair of RCA plugs on the fixed part of the turntable.  Then the thickness of the interconnect would not matter.
Guest Muon N'
Geoff at Aurealis Audio could likely make you up some nice Litz cables suitable.
Only issue is he uses very high quality Litz, and good connectors.
I'm not sure what stupid money entails, as it seems what defines 'stupid money' is different for each person.
The R3i AgL  and R3i CuL are the high quality Litz, UPOCC  Silver or Copper.
https://www.aurealisaudio.com.au/rca-interconnects/
Edit: he also seems to have a hybrid using copper and silver Litz.
https://www.aurealisaudio.com.au/r3i-shielded-interconnects/
Be very hard pressed (if at all) to find this high level of quality for anywhere near what these are listed at.
Edited by Muon N'
metre or less
Planning on doing that with a cable which is thin enough.
Nah....not me...won't do that, but thanks for the suggestion
I'll investigate, thanks!
    • By Dawso8
      Item: Thorens TD160 Turntable
      Price: $800
      Item Condition: Used, but very good for it's age. Original dust cover is almost perfect. Small superficial marks on the top plate (see picture) that do not effect performance.
      Reason for selling: Surplus
      One of the classics from the classic era, this is a tweakers' dream.
      Presents very well in mostly original condition. Serviced, set up & upgrade of required components; summary of work completed:
      cleaned inside & out motor oiled tuned and dialed in TP16 tonearm new hinges installed for dust cover new Ortofon OM10 cartridge installed and set up  Thakker belt included new feet installed upgraded Mogami RCAs installed
      Plenty of information on the Internet that best sums up this classic deck.
      Performs admiringly next to my heavily tweaked Thorens TD125
      Pick up in Melbourne western suburbs, happy to demo. Could deliver locally if not too far.
    • By oztayls
      Item: Linn Sondek LP12 / Valhalla / SME 3009 S2 Improved / Shure V15 Type III with original Shure stylus
      Price: $2500
      Item Condition: Excellent
      Reason for selling: Not getting much use as I have other turntables
      Payment Method: Pickup - Cash, Paypal, Bank deposit
      Extra Info: Time to move this beauty on as it's not getting much use, but I have this niggly feeling I will regret selling this! Lovely condition, recently serviced. Has a new damped base but will supply the original one as well if wanted. From memory, the stylus is an original from Shure and I still have the box it came in. The SME arm is in perfect condition and comes with the original box also. Lid is shiny, has no cracks or scratches and the hinges are perfect.
      The platter bearing is perfect and there is no platter wobble. You won't find a better one in this model.
      The Valhalla power supply is in as-new condition, working perfectly with no signs of overheating that your normally see with these boards.
      I would prefer pick up, but can ship it competently for the cost of shipping and materials. (Approx $50)
    • By GavL65
      After several years of very pleasurable listening to vinyl on my Thorens TD160B MKII (purchased off StereoNet and pictured below), it's time to start to add my own personal touches.  My 160B came with the TP11 tonearm.  I'm thinking of changing it out for an SME 3009 or similar to start to see how far I can push the TT!!  Any advice on the first of my mods would be greatly appreciated.  I'd also be keen to hear from other Thorens owners on what they've done to their TD160's!!
    • By Tobes
      I'm thinking of replacing my VPI TNT with a final turntable to see me into the foreseeable future.
      The TNT (upgraded series one with integrated motor/flywheel, ball suspension pods and series 5 bearing) has a Graham Phantom II with a SME base and my new table would be something to exploit that tonearm.
      I've decided to limit my spending to ~$10K, which will hopefully ensure a reasonable upgrade over the TNT.
      Anyway, the SME15 appeals to me from practicality and build quality standpoints. The reviews seem very positive about SQ too.
      Many SME owners seem to love their tables, but there is a portion of vinyl enthusiasts who describe SME as detached and un-emotional - CD like, perhaps.
      I am seeking a neutral platform to hear what's on my records, not a stylised sound - but of course I want it to be enjoyable.
      Apparently there are a few SME 15's in the wild and I was hoping owners would  chip in with their longer term impressions. Still loving it?
      Actually any SME impressions would be useful - or if you switched from SME and why.
    • By mlinvpp
      Item: SME Tonearm Stainless Steel Armboard for Technics SL 1200 MK2 G 1210 1200G 1200GAE
      Price: $75
      Item Condition: As new
      Reason for selling: NLR
      Extra Info: I have a SME Tonearm Stainless Steel Armboard for Technics SL 1200 MK2 G 1210 1200G 1200GAE for sale,  it works well and very easy to install. I bought it from eBay, shipped from Greece, made to very high quality.
      https://www.ebay.com.au/itm/SME-Tonearm-Stainless-Steel-Armboard-Technics-SL-1200-MK2-G-1210-1200G-1200GAE/162756678070?hash=item25e50dd1b6:g:Ut4AAOSwpDdU4MrB
      Local pick up welcome.
      Please send PM if you have any question, happy to answer what I know.
