Batty
Show us your Power Amplifiers.
Precursor to the Soliloquy according to Mr Metaxas.
Edited by DrSK
On 05/12/2019 at 9:33 PM, mwhouston said:
There has been some likes for this amp build. Just one other image of the inside.
What’s the little red parts that sit across the capacitors?
Hi ,
Just like our fellow forum member Ittaku , I also am into ARC . Never tried any other amp & preamp been loyal since 1988 .
Here are my amps
Two names; snubbers or bi-pass. Bi-pass is more correct because snubbers usually have a resistor  also.  Generally they are same polies - 0.1uf.
Large electrolytic caps have some internal noise. The smallest caps help suppress that. Also they provide a better path for the return audio.
That’s interesting, thanks. I’ve got them across the caps of my amps and it was the first time I’d ever seen / noticed them.
The top is current the bottom is some of the past.0ACEA6D4-3519-4BF2-9EF0-A69C12418B52.jpeg
Edited by Yamaha_man
Big HSs on the amps near the speakers. Class A?
That's these infamous beasts:
They are strapped at the back and bolted together at the sides. This is all done by the owner or installer.
Couldnt see in specs etc if they are Class A or not. Could be AB with a heavy bias thus the big HSs.
Sorry, can't agree.
On 04/12/2019 at 11:31 PM, mwhouston said:
Newly built DIY “Precision” - 300W Holton inspired.
I was going to ask how this went after seeing it at your place.
Does it do 2ohm loads?
42 minutes ago, Yamaha_man said:
Just as I thought Class A. Dan, an SNA member, built some spectacular Krell monoblocks Class A amps. He brought them over for  a listen. As with all his amps they are built with high end components and look stunning.
I’ll ask.
Not design for 2ohm speakers but OK if part of the speaker characteristics dip momentarily into 2ohms.
So, not good for Apogee Duettas or Scintillas but fine with any "Normal" speaker that dips into 2 ohm.
I have the stereo version and Wow. The control and dynamics of the Gales is very very good. As well, a clear 3D soundstage with presence.
Edited by Wimbo
Bass, transparency and sound stage. All under control.
