Eagleeyes Posted October 20, 2019 Share Posted October 20, 2019 (edited) Item: A few AV products from Denon, HSU, Yamaha, from Receivers and some small bookshelf rear speakers etc Location: PERTH Price: As below Item Condition: various but mostly good pm for me info Reason for selling: Older gear needs a new home , has not been used in years. Some with very little use. Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: See Below. Samsung Blue ray player with remote BDP1400 -$120- now $100 DENON Blueray Disc Transport DVD 2500BT with remote high end when released needs DAC as HDMI out only. Higher end Blueray transport $400 now $250 Kenwood Audio video stereo receiver KR-v6050. $100 great entry amp/ receiver for someone. ------------------------ Speakers Axis Ls28 bookshelf speakers black great sound and perfect sonically , scratched boxes. $200 awesome for rears on SS set up. Xavian Bonbonus book shelf speakers in light ash wood great actually very good condition $350 same as above for as rears or smaller Receiver Yamaha rxv3800 with remote Receiver 2nd highest in range i think was $4000 or more new. Very nice sound from Yamaha. Winner of top sounding receiver. Bargain ONLY $500 due to HDMI issues and 3 work at least so who needs more than that otherwise would be listed at $1200 Hdmi board, 2-3 inputs work , 1-2 don’t for some reason and all other inputs work perfectly goes very well with Denon transport above. Conclusion When dealing with an AVR in this price class, you go in with very high expectations. The Yamaha RX-V3800 has the specs to please most any enthusiast with excellent power, ample HDMI inputs, and internal decoding of the new HD audio codecs. The only personal letdown for me was the AVR's inability to process certain video signals to 1080p; instead it simply passes them through. Even with this shortcoming, this is an excellent product and is worthy of your consideration when looking for an AVR in this price class. Highs Four HDMI Inputs Onboard Decoding of Dolby Digital Plus, Dolby TrueHD, & DTS-HD Master Audio Clean and Dynamic sound from all channels Lows Video section only upconverts analog signals YPAO setup set monitor speakers to "Large" when they should be set to "Small" Read more at https://www.soundandvision.com/content/yamaha-rx-v3800-av-receiver-page-3#J6zIyjGDCUEpSVmh.99 Specifications 7.1-channel surround sound receiver 140-watts minimum continuous power per channel, 8 ohm loads, two channels driven from 20Hz-20kHz with a maximum total harmonic distortion of 0.04% Analog audio input sensitivity and impedance: 200mV, 47kohms (line), 3.5mV, 47kohms (phono MM) Analog output level/impedance: 200mV/900 ohms (REC Out) Speaker impedance: 6 ohms-16 ohms Analog audio inputs: Ten L/R (line), L/R phono (MM), 5.1-channel analog Digital audio inputs: Three coaxial, four TosLink optical Analog audio outputs: Four L/R (2xL/R record, L/R Zone1, L/R Zone2, L/R Zone 3), one 7.1-channel preamp out, headphones, Eleven pair speaker terminals Digital output: One TosLink optical Video inputs: Seven composite or S-video, three component, four HDMI Video outputs: Two composite or S-video, one composite-only zone 2, one component, one HDMI Other: Setup microphone, two 12V trigger, RS 232, IR in/out, IEC power connection, antenna (AM/FM/ XM), iPod Dock input Dimensions: 17-1/8" x 6-3/4" x 17-1/4" (W x H x D) Weight: 38.4 lbs Edited November 18, 2019 by Eagleeyes Link to comment Share on other sites More sharing options...
