PRAGON
Bi-wire amp to speaker.
i have Denon pma-2500ne and proac db1..
my denon amp has A+B bi-wire socket..if i conect bi-wire to speaker
Is really bi-wire make sound better?
Going by the kit you've got, you've got sufficient funds to just try it, and see if it does or not. Look forward to your observations. In my experience, the answer is no. In fact, the best option is no crossover and just go full-range.
Unlikely that you are going to notice a difference. There is potentially a small benefit in bi-amp a passive x-over. One amp for LF and one amp for MF/HF.
Bi-wire is still using a single amp for LF and MF/HF
It is just a marketing gadget/naming. If you read the info on your amp, it isn't even mentioned in their sales pitch.
Weeeelll - that's if you're happy listening to a max bandwidth of 100Hz to 10kHz.  :)
Guest Muon N'
deleted...
Sorry, was way off topic.
Edited by Muon N'
If you used both the A+B terminals at the amp you will get worse sound.
If you used only 1 set of terminals (either A only or B only) and use 2 runs of the same speaker cables from that 1 set of terminal to connect to the speakers' upper frequency input and lower frequency input you will get much improved sound.
Running 2 sets of amplifier may get you slightly greater dynamic power, but you may run into 2 issues:
1)  If the 2 amps are not fed directly from the wall mains, but from a distributor, there might be impediments to speed of the current flow, and unequal dynamics/sound quality from ac receptacle to receptacle.
2)  the 2 amps placed next to each other will exert a detrimental magnetic field interference over each other - affecting soundstaging, dynamics and timbre correctness.
To answer this question in "aussie lingo"... Won't make one iota of difference to the sound.
    • By olegau
      Item: HiFi stereo system
      Price: 1200
      Item Condition: very good
      Reason for selling: too many stereo systems
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and then change the OP-Amp you like.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562. Many other OP-Amp suits for this amp..
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Sold.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By Karel
      Item: Cambridge Audio Azur 540A
      Price: $100
      Item Condition: Very good
      Reason for selling:  No longer used
      Payment Method: Pickup only
      Old favourite, great sound for little money.  No remote. Very good condition.
      Manual & specs:  https://techsupport.cambridgeaudio.com/hc/en-us/article_attachments/205263809/Azur_540A-640A_User_Manual_-_English.pdf
    • By mttel
      Item: myryad z40 headphone amp
      Price: $270 ono
      Item Condition: BNIB
      Reason for selling: no longer required
       Purchased to use with some HD700s and never got taken out the box.
      Can post if required.
    • By Siriosys
      Item: Quad 909 Amp and matching Quad 99 PreAmp
      Price: I'm open to reasonable offers around NZ$2.5k for both units.
      Item Condition:  Excellent Condition including, original boxes, cables, manuals, and remote for the Pre.
      Reason for selling:  Audioenz member from a long way back, when I had the time and space to really enjoy my Hifi.    However, I'm regrettably needing to downsize and also now don't have the time I once did to enjoy good listening sessions.
      Payment Method: Pickup - Cash, Bank Transfer.   Can be shipped, but given the total weight and size, it would need to be at buyers expense.
      Extra Info:  Included is the Quad-link cables, 2 power leads, remote, manuals (see photos)
    • By Cafad
      Item:  One Technical Brain TB-Zero/Int (integrated amp)
      Price:  $14,600 (including postage within Oz)
      Item Condition: Very good, no obvious scratches or marks.  Fully operational.
      Reason for selling:  I'm trying to consolidate my gear.  Thought I had a buyer for this amp but unfortunately that sale didn't end up happening so I thought I would list it officially and see what happens.
      Extra Info:  I have the original box.  Please note this amp does not have a remote control function.
      More information available in the links below.  Note the Technical Brain website is in Japanese and will need translation.
      https://www.stereo.net.au/forums/topic/251642-technical-brain-tb-zeroint-review/
      http://www.technicalbrain.co.jp/products_tb_zero_int.htmls
      https://www.stereo.net.au/forums/topic/263126-terry-o-and-cafads-integrated-amp-challenge/page/4/
      Pics:
