LWA Staff
Arcam A19 Integrated Amplifier
Item: Arcam A19 Integrated Amplifier
Price: Was $750 SN Special $665
Item Condition: Excellent Secondhand Condition.
Shipping: Anywhere in Australia, POA
Payment Method: Credit Cards, Cash, Bank Transfer, Paypal, ZipPay with up to six (6) interest free.
Extra Info: Performing and presenting in excellent secondhand, this A19 integrated amplifier,
was build to  the same very high standards as the company's other FMJ series products. Arcam engineers chose every critical component using careful measurement and years of design experience. The A19's audio circuits are combined with an ultra-low noise power supply built around a muscular toroidal transformer. These state-of-the-art electronics are encased in a resonance damped chassis which exudes quality.
Specifications:
Continuous power output (20Hz—20kHz at 0.5% THD), per channel
    Both channels, 8Ω, 20Hz—20kHz: 50W
    Single channel, 4Ω, at 1kHz: 90W
    Harmonic distortion, 80% power, 8Ω at 1kHz: 0.003%
Inputs
Phono (MM) cartridge
    Input sensitivity at 1kHz: 5mV
    Input impedance: 47kΩ + 100pF
    Frequency response (ref. RIAA curve): 20Hz—20kHz ± 1dB
    Signal/noise ratio (Awtd) 50W, ref. 5mV input: 80dB
    Overload margin, 50mV at 1kHz: 20dB
Line and AV inputs
    Nominal sensitivity: 1V
    Input impedance: 10kΩ
    Maximum input: 4.6Vrms
    Frequency response: 20Hz—20kHz ± 0.2dB
    Signal/noise ratio (Awtd) 50W, ref. 1V input: 105dB
Outputs
Preamplifier output
    Nominal output level: 630mV
    Output impedance: 230Ω
Heaphones Output
    Maximum output level into 600Ω: 4V
    Output impedance: 1ohm
    Load range: 16Ω—2kΩ
