Headphone amp to pair with Sennheiser HD600's?
Hi all,
I am in the market for a new headphone amp for my pair of Sennheiser HD600's.
Any recommendations? Budget wise I would like to spend less than $400 unless there is something just outside of that price range which is SIGNIFICANTLY better.
Thanks in advance for any help.
48 minutes ago, Bengineer said:
Need a DAC too?
Hi Bingineer,
I did not realise that a DAC would be required. I was hoping the headphone amp would be both the DAC and the driver of the headphones. Please forgive my ignorance, I am new to all of this.
If a dac is a requirement, then chord mojo, would be a must to audition for $599 new. Very hard to beat as a headphone dac and amp package
Neo
Edited by Neo
28 minutes ago, MintThyme said:
Hi Bingineer,
An EL DAC by JDS is good too, Grace SDAC of you're on a tight budget.
Neo
Yeah. More so as unit that can be portable.
It doesn't put out huge power, DAC is clean though. Like a NFB 11.28 puts out whopping power compared, around 4x more power.
Edited by Bengineer
Ok, so I found the mojo  package in a store in town,
https://www.listeningpost.co.nz/Products/Media-Players-Digital-Music-Server-MP3-streamer/Chord-Mojo-Poly-Headphone-Amplifier-Package-DAC-__I.302925__C.27465__N.27756
$2000 is too much.
Also travelling with my HD600's is not a factor / thing for me. I only use these at home with my computer.
No, they are $599 retail.
The Poly is a add on streaming unit.
Can be had $400 or so in these classified forums.
Schiit Stack or a JDS Element would suit you. New in your budget for both I think, used easily.
Mojo will drive the HD600 (Sensitivity 100 dB/mW) to ear splitting levels with ease (and low distortion).
Yes it does. Doesn't mean he will have HD600 forever though :P
Mojo is over his budget new too. So depends how strict he is on that.
Ill be getting a Mojo soon, price is too good now. Mojo and Focal clear for $2000 brand new. World's gone crazy.
On 05/10/2019 at 1:13 AM, MintThyme said:
What do you guys think of this headphone amp / DAC?
https://www.mav-audio.com/base/product/d1p
No idea bud.
Highly likely you'll feel the urge to upgrade within a year, like we all seem to around these here parts. So maybe stick to popular models that hold value ok and sell quick. Schiit fits that bill, buy used, try, if no like (you prob will like) then sell for same money.
I'm running a very old hd600 through a fiio k3. Small device and while it doesnt drive to ear splitting levels, it is loud enough for my wife to complain she can hear everything I am listening too from across the room.
K3 is a solid dac as well and supports windows without a driver which is nice. Plug and play on android as well and has a usbc plug on it.
I run through a balanced cable that I got for around 40 dollars from aliexpress. All round happy with the solution and I think it sounds great to me.
If you like louder then ifi make some nice units or you can chrck out the fiio k5 pro. Unfortunately this isnt a portable option.
I actually starting putting a spreadsheet together for all the headphone amp options in my price range.
Something to keep an eye out for are the new bluetooth dad amps from fiio and shanling. They should put out enough power for the hd600 and they are small and can be used plugged in or wirelwss to other device.
  • Thanks 1
  • 4 weeks later...
Hey all,
So have been researching away and so far these are the headphone amps of interest.
Price range from $300 up to $1000.
Which of these options would you guys go for?
Edited by MintThyme
I was going to say, I have an Atom amp you can try out, but you're on the other side of the ditch! Take your phones and go and have a listen to some amps I reckon! What are you using to power them atm?
I'll be buying a Micro BL soon myself. I had a JDS Element and a Audio GD NFB 11.28.
The element is good. The 11.28 is better. Hoping the Micro BL is par with the 11.28, but benefit of battery powered too!
After fairly extensive reading the Chord Mojo and Ifi Micro iDSD are at the top of the list.
My only reservations / concerns are that I have read numerous comments about the Chord Mojo breaking down after 12 months of use for various reasons but mostly related to the battery.
And the Ifi Micro iDSD looks great but it's also $1000 and comes with a lot of extra connections and stuff I don't want or need. But overall it looks like it could be the potentially the better option as a full time desktop headphone amplifier solution.
Does anyone have much experience with either of these two products? Any thoughts on the above?
I haven't heard the BL. Heard the Mojo. It's great, no doubt. BL is more of a all in one solution. Desktop to lounge to holiday.
Mojo is the portable option. On bus, at uni, in the pocket or hooked up to the laptop.
So for a home desktop setup the BL may be better in the long run?
I plan to do 99% of my listening at home sitting at my desk. Portability is not an important factor for me.
11 minutes ago, flanders said:
Used all the way! You'll get so much better bang for buck. I wonder how much marketing and product design/packaging you're paying for with the Chord and ifi stuff?
But who would sell there Chord Mojo or Ifi Micro?
On 05/11/2019 at 1:01 AM, Bengineer said:
Mojo comes up a bit. They are also very popular.
iFi iDSD Micro BL does not.
Awesome, would be totally up to purchase one of these products second hand.
I do live in New Zealand, Wellington. Is there many peeps here from NZ that sell second hand audio gear?
They may mate. Else just look into couriers. People be more willing to if all it meant was they had to package it up, and someone comes picks it up. Going post office and filling out international shipping form is annoying.
Haha, today I said screw it and went and bought the Chord Mojo. I did extensive testing a week or so ago between the Mojo and the Micro. The enjoyed the Mojo overall a smidgen more and it also costs $300 less. Headphone amp sorted :)
  • Haha 1
