Hawk66
Best value MM cartridge upgrade
17 hours ago, nkoulban said:
I'm glad you are enjoying your AT95 cart, I know I am.  I have also just posted a vinyl needle drop of a Dire Straits track using this cart and stylus.
Thanks for sharing this, I enjoyed the 'needle drop' and your video editing skills.
May I ask what software do you use for editing?
PS: You got a new sub :-)
PS: You got a new sub 🙂
Thank you for the kind words.  Just checked out your channel, very cool.
I use a DSLR with a 50mmm F1.4 lens for the video, iMovie for video editing and Audacity for the audio recording via an Xtel Inport.
On 31/12/2019 at 2:07 PM, Colin Rutter said:
Just a note on AT cartridges
They are generally underrated
I have Stanton 681 EEE, Grado Black and Blue and the top one of about 20 years ago, Shure v15 IIII, At VM95E and AT
150MLX.
I have had MCs as well as many others Grace,Ortofon etc. etc.
The ATs are up with the best of them
The advice is good going to a ML or Shibata on the 95.
I wonder could you offer some thoughts on the At150MLX - i always thought i wanted one. I runs DL110 now. I also have an AT95E but hardly used.
Different body to mine, which is in the pic on the first page. My cantilever sticks out prominently in the front. I cut the plastic body away and just use'd the plug.  I have the VL stylus .
I can't offer thoughts really other than I like it.
The tech. behind it is interesting but "the proof of the pudding is in the eating"
I have listened to the AT150MLX, its a good cart.  I find it a little bright, but that can be tamed with with a bit of parallel resistive loading. I think the new VM740ML may be a more balanced sounding, however, I have not heard it.  I'm also keen to try the LP Gear The Vessel R3SM, this runs a microline stylus on a ruby cantilever, however, at around $1,000 AUD its more than I want to pay right now.  The reason I went with the AT95 with the Jico Hyperelliptical was to get to a good level of performance without spending too much.  My modded AT95 owes me $250, however, it is so good that I no longer listen to my $1,000 moving coil and it has the lowest surface noise of all of the carts I have used.
I also use the DL-110 myself, for the money I think it is good value. Have not felt the need to upgrade. I have a DL-103 which I seldom use as I've got a feeling it does not match well with the MC loading from my current amplifiers.
Have a read of this Kavi Alexander describes the ML-170 as very close to the sound of the master tape.
http://www.regonaudio.com/Stanton881AudioTechnicaATML70.html
What loadings do your current phono stages offer, W?
Specs for the D103 say:
  • output impedance 40 ohms - by which I understand to mean the coil impedance is 40 ohms.
  • load impedance 100 ohms - which I take to be the minimum  you should use!  So anything from 100 ohms to 4K ohms (100x coil impedance!) is feasible, as the optimum loading.
That was the 70, not the 170.
Review was done 30 years ago.
Note which cartridge I own😎
Edited by Wimbo
