Arry74
Audessey versus using a SPL meter
I went over to my FIL's today and we calibrated his system using my new SPL Meter.
Question, would you trust using Audessey or the SPL Meter?
To answer this, I think we need to understand a couple of things:
i) what do you call calibrating; and
ii) what is your new SPL Meter and are you using any software with it?
Audyssey does several things,  Sets relative volume levels, sets individual delays for each speaker  and also applies room correction/Eq'ing.  Bad results can be had by not being careful when undertaking an Audyssey Cal.  Excellent results can also be achieved.  There is an excellent guide somewhere for this, though I don't recall at the moment where it is.
If you new SPL is just a $20 Ratshack jobbie, then it will just measure db's and not any of the other things that Audyssey takes into account.  If you new SPL is a UMIK1 or similar and you are using it with the likes fo REW, then you can achieve a far bit more, but you still can not easily apply equalisation (that I recall).
If just setting vol levels, I would rate the order as UMIK with REW then Audyssey, then bottom of the pile a Ratshak or phone meter.  Others experience may be different.
If you want to get real serious, explore UMIK-1 mics, REW and also using DIRAC with a MiniDSP 88A.  This is however not a simple or cheap exercise.  If I find the link for the Audyssey cal info, I will post it here.
I always use a good, calibrated mic and REW or similar. Audessy is a PHD* solution for the average consumer and works well for that. A typical SPL meter won't be as good.
*Push Here Dummy.
https://www.stereo.net.au/forums/topic/248466-audyssey-xt32-help/
http://www.willowville.net/ht/Audyssey%20Setup%20Guide.pdf
I’ve never had an issue with the levels produced by Audessey.
i have.. audyssey xt32. subs too low, centre too low and surrounds/rears too low. just bump them all up by 3db
Cheers guys, I bought the SPL from here: https://www.jaycar.com.au/compact-digital-sound-level-meter/p/QM1589
His system has Audessey xt32 mine only xt as it is an older Denon.
I havent used the SPL on my system as yet however with his we ran the room correction but then used the SPL to set the channel levels.
I wasn't sure to just trust the room correction and not adjust anything or use just the SPL and manually change everything or use both.
I always verify Audyssey's calibration using REW and a calibrated mic - and adjust levels accordingly, and I (and a few others on AVS) have found Audyssey sets speakers 2-3dB hot (so around 77-78dB) and subs usually a dB or so low. I have personally checked this with 3 different AVRs (1x XT, 2x XT32) and 5 different Audyssey Mics (purchased some new ones from Aus distributor and eBay) and using 3 different calibrated mics with REW (1x Dayton , 1x miniDSP umik-1, 1x CSL calibrated umik-1)
Probably not necessary in the grand scheme of things, but I just like to know that when I'm watching a movie at -5MV  that I'm actually -5dB from Reference Level.
as long as you have followed the guide posted above to the letter you will likely all is well. it is usually only when you dont follow the guide decide to go off beaten track you tend to get caught out. I have used audyssey over multiple AVRS and processors over some 15 years.  THE main issue with audyssey is the mic used. in the case with the thrown in one its quite likely 1-3 db out !
however is that a big deal for most not as long as consistent.
XT is basic and in capability. it will still calibrate the same just lacks the sophistication and capability with dual subs. I would go with the flow and see end result. it should get you pretty close :)
things like sub level ... audyssey expect you will "salt to taste" ie adjust a bit up down to preference. keep in mind audyssey is just setup and EQ its trying to make best of the situation. its far more important to get setup and room right in the first place. measurement then is no big deal and eq needed less rather than more.
For what it is worth, when I was running Audyssey, I would normally add about 5dB to the sub(s).  Also, used DynEq, to compensate when running at lower dB levels.
dynamic EQ is an absolute must and audyssey expects you to use for listening below reference. it will do its own boosting of freq to make sure EQ is dynamically adjusted for  volume vs freq. whether OPs FIL AVR has dynamic eq is another thing.
Just to open a can of worms - in some capable AVRs you can turn the 'Midrange compensation' on or off via the Audyssey app.
What is this setting for and should you leave it on or off?
it is one of best things can do with audyssey. its the BBC dip... they have it in by default and if running pro or very latest app version you can remove the dip
https://audyssey.zendesk.com/hc/en-us/articles/212347863-Midrange-Compensation
I have always preferred to remove the dip...
Thanks ... do you actually notice a difference with it turned off? I'm struggling to hear any difference on or off.
perhaps with your speakers there is no real difference anywise :)
Audyssey can sometimes get the channel levels wrong for various complicated reasons (nothing to do with it's microphone being "not accurate enough") .... so it can be good to give it a check.
With my SPL Meter it has C weighting, slow etc then has a setting for low which is 30 - 100db and a high setting which is 60 - 130db. I have tried both and there is a difference of about 2db when using high v low etc
Anyone know which setting should be used?
Set up my new 3500 yesterday. Just turned DEQ on and.......WOW
    • By EricL
      Item Condition: Mint condition (9/10) Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Greensborough State: Victoria Payment Method: Cash on Pickup, EFT, PayPal + 3% Reason for selling: NLR
      Further information:
      This is an award winning integrated amplifier from Denon with Australian power specifications. It is made in Japan.
      You can read the summary review: https://www.hifichoice.com/content/awards-2010-amplifiers-£1000
      The Denon catalogue also featured it as an award winning amp from EISA 2010-2011.
      It works beautifully and even has MM/MC phone stage.
      It can drive my Audio Technica MC flagship OC model AT-OC9XSL cartridge (0.4mV) and sounds great via my Paradigm Studio 20 speakers.
      It can be used as integrated amp, power amp and pre-amp. See photos for various setup in the manual.
      Specifications of the amp: Refer to photo.
      I bought in early 2011 (RRP - Around $1700) and used it for a year and then upgraded to Luxman amp.
      It has been sitting in the Hi fi room all this time.
      There are two very minor hairline scratches on the front. They are not noticeable unless you examine in close scrutiny. Please see photos.
      This amplifier is rather heavy -15.5kg so I prefer local pickup.
      It comes with the original manual, power cable, unused remote and original box.
      Will include the Denon catalogue featuring this amp.
      I can ship interstate if buyer is keen and there will be additional shipping costs.
    • By bard61
      Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Marrickville State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Not being used Further information: I bought this a couple of years ago. Sounds great, I put about 40 hours on it then got a good deal on a Garrott P77i. I was keeping it as a spare, but as the Garrott has a replaceable stylus there’s no need to hang onto it, so out it goes.
    • By nedrum
      Last minute edit - I haven't tested if it still works or not, but am happy to do so for straight stereo if that matters
      Item: Denon AVC-A11SR (a beast back in it's day!) - review here
      Price Range: Free to a good home! StereoNet donation appreciated
      Collection Option: In-person pickup from Thornbury (Victoria) with limited personal contact
      Item Condition: Used
      Served me well for quite a while, until I moved onto a newer amp and it's been collecting dust ever since. A few things to note:
      Sound turns on and off in what appears to be the amp continuously engaging/disengaging the headphone jack. Might be an easy fix but who knows?!? as per the photo's, the two main caps are bulging. Not sure if that's an issue or if they are easily replaceable for someone in the know.
      Comes with remote, power cable and manual (of which the English part is a whopping 42 pages). Shipping isn't an option as it weighs 20.5kg. From what I remember, it's a typical Denon sound - neutral and smooth. Somewhat better than my mid tier surround amp, but without the room correction.
    • By peppy
      Price: $580 Item Condition: USED Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Castle Hill State: New South Wales Payment Method: Any Reason for selling: This room a part of Zone2 in HT that I setup , so this item became redundant Further information: Near new condition. In warranty until 2022. This is the latest HS2 version of this speaker.
      Big sound, it replaced my SONOS Play 5
    • By peppy
      Item: SPL Phonitor 2 Headphone Amp
      Price Range: Neg
      Item Condition: New or Used
      Extra Info: Based in Sydney , but can cover postage.
