Eagleeyes
A few AV products from Denon , HSU Yamaha etc
Item: A few AV products from Denon, HSU, Yamaha, from Receivers to a sub and some small bookshelf rear speakers etc
Price: As below
Item Condition: various but mostly good
Reason for selling: Older gear needs a new home , has not been used in years.
Extra Info: See Below.
Samsung Blue ray player with remote BDP1400 -$120
Denon AVR 2805  Receiver - lovely condition with microphone, books, remote, etc, stunning sound and great older unit, full Japanese quality Only $250
DENON Blueray Disc Transport DVD 2500BT with remote  high end when released needs DAC as HDMI out only. Higher end Blueray transport $400
Kenwood Audio video stereo receiver KR-v6050.  $100 great entry amp/ receiver for someone.
HSU Sub-woofer VTF 2   -- ten years old and works fine, very well respected brand from Dr HSU. $400 good condition has mark on front that will clean off. Great SUB
DESCRIPTION
Built-in 150 Watt amp. 25 Hz bass extension. 30-90 Hz, 24 dB/Oct bypassable low pass filter. "Class A rating" in Stereophile Guide to Home Theater. Reviewer''s Choice Award 2000 in Sound & Vision.
This subwoofer kicks butt for the money. I've had my share of subwoofers over the years,this one sounds great. Of course if I could afford it,I'd get an aerial acoustic,but I digress... I'm one of those "If it dosn't sound perfect,turn it off!" Teamed up with my B&W's 603S,it pack's just the right punch. But I will say this,and all you audiophilies know this. cable's,cables,cable's. If you use a cheap subwoofer cable,your missing out!! I'm using Audioquests Black Thunder,and man the kick drum never sounded better! Not to mention,this is a very good LFE subwoofer.
Speakers
Axis Ls28 bookshelf speakers black great sound and perfect sonically , scratched boxes. $200 awesome for rears on SS set up.
Xavian Bonbonus book shelf speakers in light ash wood great actually very good condition $350 same as above for as rears or smaller
Yamaha rxv3800  with remote Receiver 2nd highest in range i think was $4000 or more new. Very nice sound from Yamaha. Winner of top sounding receiver.
Bargain $500 due to HDMI issues and 3 work at least so who needs more than that otherwise would be $1200
Hdmi board, 3 or 4 inputs work , 2- 3 don’t for some reason and all other inputs work perfectly goes very well with Denon transport above.
Conclusion
When dealing with an AVR in this price class, you go in with very high expectations. The Yamaha RX-V3800 has the specs to please most any enthusiast with excellent power, ample HDMI inputs, and internal decoding of the new HD audio codecs. The only personal letdown for me was the AVR's inability to process certain video signals to 1080p; instead it simply passes them through. Even with this shortcoming, this is an excellent product and is worthy of your consideration when looking for an AVR in this price class.
Highs
Four HDMI Inputs
Onboard Decoding of Dolby Digital Plus, Dolby TrueHD, & DTS-HD Master Audio
Clean and Dynamic sound from all channels
Lows
Video section only upconverts analog signals
YPAO setup set monitor speakers to "Large" when they should be set to "Small"
Read more at https://www.soundandvision.com/content/yamaha-rx-v3800-av-receiver-page-3#J6zIyjGDCUEpSVmh.99
Specifications
7.1-channel surround sound receiver
140-watts minimum continuous power per channel, 8 ohm loads, two channels driven from 20Hz-20kHz with a maximum total harmonic distortion of 0.04%
Analog audio input sensitivity and impedance: 200mV, 47kohms (line), 3.5mV, 47kohms (phono MM)
Analog output level/impedance: 200mV/900 ohms (REC Out)
Speaker impedance: 6 ohms-16 ohms
Analog audio inputs: Ten L/R (line), L/R phono (MM), 5.1-channel analog
Digital audio inputs: Three coaxial, four TosLink optical
Analog audio outputs: Four L/R (2xL/R record, L/R Zone1, L/R Zone2, L/R Zone 3), one 7.1-channel preamp out, headphones, Eleven pair speaker terminals
Digital output: One TosLink optical
Video inputs: Seven composite or S-video, three component, four HDMI
Video outputs: Two composite or S-video, one composite-only zone 2, one component, one HDMI
Other: Setup microphone, two 12V trigger, RS 232, IR in/out, IEC power connection, antenna (AM/FM/ XM), iPod Dock input
Dimensions: 17-1/8" x 6-3/4" x 17-1/4" (W x H x D)
Weight: 38.4 lbs
    • By cafe67
      Item Condition: Like grandma drove it Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Morley State: Western Australia Payment Method: Cash, direct deposit Reason for selling: Trying Nordost Further information:
      Aurealis R3i CuL t/t phono .75cm but might be .80cm - rrp $350
       , bought direct from Aurealis Audio
      RCA at both ends, I thought this as a turntable connection so comes with a ground cable, but can be used for other sources or pre amps.
      have the box.
      PLEASE READ
    • By nzcuriousgeorge
      Item Condition: Used - Very Good Condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Auckland State: New Zealand Payment Method: EFT, Paypal Reason for selling: NLR - Not suitable for my turntable Further information: Totem Acoustic Tribe On-Wall Speakers  *** WITHDRAWN FROM SALE ***
      2 x Tribe I
      1 x Tribe II
      Satin black colour. Used as Left/Centre/Right speakers for home theatre.
      Current RRP over $4,000.
      In very good condition, Tribe 2 is missing removable Totem badge (see photos) and slight nick in paint. Magnetic speaker grille and wall mounting hardware included (see photos).
      Original boxes for packaging (one box is slightly damaged).   These have been in storage for a few years so they need to go to a new home.
      For review see, https://hometheaterreview.com/totem-acoustic-tribe-i-tribe-ii-storm-reviewed/
      For more information see, https://totemacoustic.com/categorie-produit/architectural-custominstallation/on-wall/
      Packaged and ready to ship, shipping costs (est):
      Australia $240
      NZ - North Island $90
      NZ - South Island $190
      PLEASE READ
    • By Ericcklau
      Item Condition: E Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Turramurra State: New South Wales Payment Method: PayPal, Cash on pickup Reason for selling: NLR Further information:  Japanese press with no OBI and insert
      PLEASE READ
    • By Ericcklau
      Item Condition: E Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Turramurra State: New South Wales Payment Method: PayPal, Cash on pickup Reason for selling: NLR Further information: Japanese press with OBI and insert
      PLEASE READ
    • By occxlr8ed
      Item Condition: Used - Fair Condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Preston VIC State: Victoria Payment Method: Cash, PayID, BeemIT Reason for selling: NLR Further information:
      Have upgraded to LS50s, and hence no longer required anymore!
      These are now boxed up and ready for a new home.
      Note cosmetic scratch to one of the speakers, honestly not that noticeable in real life, and tweeter push marks (to my ears no difference to SQ) - both were received like that when purchased.
      Pickup from Preston VIC, can deliver if not too far, and happy to ship if buyer is willing.
      Photos: Advertisements without photos of the actual item will not be approved.
