glenm64 Posted September 15, 2019 Share Posted September 15, 2019 I am (slowly) setting up my lounge system again, this time staying 2 channel. I recently purchased some B&W 705 s1 speakers, and am now looking for an integrated amp. It will be primarily for music, eventually I will add a music streamer, I can see a turn table in the mix, and also like the ability to stream direct from a mobile device for casual listening( and that will be easier for the good wife as she is a technophobe). Also in the mix will be 2 channel speaker duties for movies etc on the TV. The cabinet I have to fit it into isn't the biggest, so size wise I dont want anything higher that 150mm. Not planning on adding a sub at the moment, but I would like to leave the door open on that. Budget is 2k, but havent told the wife that yet So far I have ROTEL RA-1572, PEACHTREE AUDIO DECCO 125 SKY, and NAD C368 in the mix. What are your thoughts on these integrated's? Are they suited to my purpose, and is there anything else you could throw into the mix? Thanks in advance for you assistance. cheers Glen Link to comment Share on other sites More sharing options...
