Audio Connection
Musical Fidelity M8PRE preamplifier in excellent condition
Item: Musical Fidelity M8PRE preamplifier in excellent condition
Price: $3,500.
Item Condition: Pre owned
Reason for selling: Clearance
Payment Method: Pickup - Cash, Credit Credit on pick up, Direct Deposit
Extra Info: Can freight at extra cost
The Musical Fidelity M8 is a pre-amplifier without limits. From its performance to its connectivity, via quality fit and finish, the M8 makes a superlative centrepiece for almost any system.
The M8 has a wide array of inputs including a low noise MM/MC phono stage, 2 balanced inputs (1 with home theatre bypass option), 3 line inputs (one with home theatre bypass option) and a fully configured tape in/out loop.
The M8 Pre-amp has very high input overload margins. This means that it has a completely stress free sound. The outputs are very low impedance and high current so that it can drive virtually any power amp in existence through any length cable (balanced or single ended).
Technical measurements are testament to the M8’s exceptional engineering: from ultra-low distortion to virtually perfect frequency response, and ultra low noise.
M8 Preamplifier specs:
Genuinely fully balanced preamp
Eight versatile inputs – 1 XLR Balanced, switchable MM/MC Phono, CD, Tuner, Aux 1, Aux 2, Tape
Single ended and balanced outputs as well as a fixed output for tape record
Home theatre bypass available in both single ended and balanced inputs
Outstanding cutting edge performance
Amazing load driving ability, will easily drive any power amplifier with any cable of almost any length
Excellent design, he-man build quality
Comes with remote control and manual
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
    • By bdavis84
      Item: KRIX Concentrix Centre Speaker
      Price: $220
      Extra Info: Great Australian made centre speaker. Barely used over the past 5 years.
    • By bdavis84
      Price: $220
