Grizzly
FS- Linn LP12 with Mission 774 arm
Item- as above
Location- Adelaide Hills
Price- 1600
Condition- Excellent
Reason- Floorboards, plus too many TTs
Payment- EFT, Cash, Paypal
More- Very clean with an almost flawless plinth. Some minor marks on the dustcover and the trim strip is lifting slightly at one end. Arm is fitted with a Mission 773 MC cartridge which sadly has no cantilever any longer (long story), might be worth professional attention as it suits the arm perfectly. From what I can gather it's around 1979 vintage and not modified at all. Also fitted with a UK plug, I used it with an adaptor but it could be just as easily rewired.
I'll be driving over to Melbourne mid October, so for any interested parties there that would be a far better, cheaper and safer freight option.
20190912_111708.jpeg20190912_111653.jpeg20190912_111810.jpeg20190910_143333.jpeg20190910_143322.jpeg20190910_143438.jpeg20190910_143427.jpeg
Edited by Grizzly
Looks in fantastic condition - I'd love to buy it, but just got some Magico speakers, so the bank is closed for a while!
Do you have the original packaging?
GLWTS!.
M
fantastic combination of arm and TT, i had this arm fitted to my Linn in 1983 , MM or MC work well, only sold it due to finances a couple of years ago, GLWTS,,
Edited by wen
GLWTS!.
M
No packing sadly, that would have made things far easier!!
THis brings back so many memories.Had one in 1983 as well but with a Supex 900 feeding Naim 12S/110 and Linn Kans. Loved it, but sold the system to go skiing in Japan.
Would love to get this again but hard to justify with the boss.
Good luck. Its a fine setup.
    • By o2so
      Item: Audio Authority 4.1 digital switch
      Price: $70 including shipping (RRP $199 US)
      Condition: 9/10 - one of the toslink plastic caps is missing
      Reason for selling: NLR
      Additional information:
      Thus is a hifi grade digital switch.
      I purchased this from Cable Solution in the US a couple of years ago (paid $291 AU) and used in my previous system.
      It basically provides 4 toslink or coax inputs and one toslink or coax output. It can switch automatically between inputs when it detects a signal, or it can be done manually.
      Works flawlessly.
      https://www.audioauthority.com/product_details/1177A
    • By Eagleeyes
      Item: Various power cords for sale- All Australian
      Price: See below including postage
      Item Condition: all excellent or better
      Reason for selling: changing to US cords
      Payment Method: Pickup - Cash, Paypal, COD Only delivery and postage
      Extra Info: all cost include postage Aus wide
      STILL FOR SALE......
      2) Isotek evo premier x1  (c 19) 1.5 metres each  rrp $225  SOLD
      3) ISOTEK G2 optimum x 3 ---x 2 metres. about 600 UK pounds each or $1200 Aussie new so  SOLD - the new versions are about $1800 each cable.
      The Isotek GII Optimum Mains Cable is a double-shielded OFC cable with 2.5mm conductors, rated at 20amps and includes IsoTek's® high-performance 24ct gold IEC connector Isotek GII Optimum Mains Cable 2.0 The Isotek GII Optimum Mains Cable is a double-shielded OFC cable with 2.5mm conductors, rated at 20amps and includes IsoTek's® high-performance 24ct gold IEC connector.
      Isotek GII Optimum Mains Cable can be used with all IsoTek products which feature a standard IEC mains inlet, or independently for other high current devices, for example power amps.
      High quality 20amp OFC cable with double shielding
      5)analysis plus power oval ten 1 x1.5 metre $600 plus rrp only $420
      Our new Green Oval 10 is a 10AWG 600 Volts CL2 UL approved power cable.
      Although Oval 10 is the best choice for high current applications, it performs equally well with low current analog and digital equipment too. WattGate 320 IEC and WattGate 5266 connectors are used with this power cable.
      Why You Need the Power Oval
      When people design power cords they use massive cable to reduce the noise voltage on the cable. The noise voltage that occurs on the cable is related to L (inductance) and di/dt (the rate of change in the current). You can reduce L by using larger gauge wire but you don’t get much bang for your buck because it is a log function. What this means is that as you keep increasing the gauge of the wire you do not get much improvement for your effort. This is why you see people using very heavy and stiff wires in power cords. I have seen some power cords that are so big and stiff that the CD player connected to them is lifted off the ground.
      What we have done at Analysis Plus is use computer simulation to optimize the design of a power distribution system. What we discovered is our patented hollow oval design provides a low L cable without having to use stiff and bulky cables. Our cables have a super low noise voltage to reduce the background noise to a minimum. This is extremely important during quiet passages, if you want to hear subtle details (this is very important for classical music fans and for other lovers of live music).
      The other thing people don’t realize about low frequency noise is that the thin aluminum shield found on many power cords does nothing to reduce this problem. The best way to reduce low frequency noise on cables is to reduce loop area. From our computer simulation and measurements we found our patented hollow oval cables does a great job at this. We have the lowest noise voltage we have seen with our hollow oval design.
      For higher frequencies our silver-plated copper braided shield does a great job. We used an open braid design that works much like the window on your microwave oven. You can see through the window but the radiation stays where it belongs.
      cheaper ones  include postage approx
      7) Gecko  2 metre. $100
      😎 Zion  1.5 metre  SOLD
      9) acrolink cryo  1.5 metre $100
      10) XLO purple reference 2 cable 1 metre $100
      11) brown and white power cable unknown 1.5 metre  SOLD
      SOLD
      1). Isotek evo premier x3  c 15 ( normal ) 1.5 metres each  rrp $225  SOLD x3
      IsoTek is an English company making award-winning power optimisation products for hi-fi and home cinema systems. You can increase the performance of your audio and video components and the IsoTek EVO3 Premier Mains Power Cable is a highly recommended upgrade.
      Overview
      Before we discuss the product details of the EVO 3 Premier mains power cord, lets review some of the reasons why people like us and our friends at IsoTek really believe you need to seriously consider upgrading your mains power cords.
      The standard black mains leads supplied with your audio and AV components is designed to do a basic job at the cheapest price and absolutely no more. It doesn't matter on a kitchen appliance, but they lack the quality of materials and construction needed to protect the integrity of the electricity feeding your system, thereby degrading performance. Outside interference from Radio Frequencies (RFI) and Electro Magnetic Interference (EMI) can't be seen with your eye, but your mains power cable is just like an antenna picking up this unwanted noise. The first rung on the IsoTek ladder is to replace these power cords with products from one of the four different ranges based on the value of your system.
      Of course, you will get the best by choosing the top-of-the-range EVO3 Optimum mains power cord no matter what you've spent on your system, but realising that approach is not practical and would simply have most of you dismiss an upgrade, Isotek have manufactured a range of four mains power cables that all help reject outside interference but to varying levels. As you move through the IsoTek range the performance level increases, with an array of mains cables and power optimisation devices to suit any audio or AV setup.
      Premier: Part of the Discovery Series and for any component priced between A$500 and A$2,000. A simple upgrade that delivers great results.
      Sequel: A step up from the Premier mains power cable and nicely priced. Recommended for any component priced between A$1,500 and A$4,000.
      Elite: Part of the Performance Series and recommended for any component priced between A$3,000 and A$10,000. Extremely high quality materials used for construction given the price. The penultimate product.
      Optimum: Cutting edge in every area and essential when your system is more valuable than your motor car! Part of IsoTeks Ultimate range.
      4)audio Principe x2.  1 metre and  2 metre cables. for 1 metre and  for 2 metres. rrp is $269 a metre SOLD
      As per Audio Principe site:
      The Audio Principe “Signature” is the top of the range reference grade power cable designed to ensure maximum clean power transfer for demanding amplifiers and components.
      Heavy 14mm diameter shielded cable with 2.5mm2 pure copper conductors including mains earth provide extremely low resistance for maximum current flow.
      Braided shielding and inner metal shield give 100% coverage to provide protection against EMI and ensure clean power supply.
    • By Benjet
      Item: Transformer coupled Headphone amp
      Price: $350 $300 $275
      Item Condition: Very Good
      Reason for selling: After a long search have finally settled on my "perfect" setup
      It's been many a year since I ventured into the land of headphones and the DIY journey has been filled with wonderful discoveries. It's time to release some of these into the wild for others to enjoy. All these are at below parts cost and have been built and modified and modified again to obtain what I believe is their best sound.
      This is an interesting amp of which I bought from a fellow SNA member. It used 6j6 tubes configured in push pull driving a output transformer. I always had my doubts about output transformers and this amp certainly changed my views. For people who attended my latest "Brisbane headphone" GTG, this was the amp that was powering my Utopia with great effect. Currently fitted with some real nice Amperex tubes. I have plenty of different other tubes and if bought locally, I will work with the buyer to find a set that suits them perfectly.
       ELECTRICAL DISCLAIMER
      This product has not been manufactured by a qualified individual or company, therefore contains electrical circuits that do not necessarily comply with Australian Standards. I understand that as the seller, I may be liable to repercussions in the event of equipment failure. By advertising and selling this product, as the seller I also agree that I am solely liable, and the publisher of this website takes no responsibility for any injury or death resulting from, whether directly or indirectly, any accident that may happen as a result of the failure of the product being sold. If in doubt, seek the services of a qualified electrician to inspect the product to ensure it is safe for use.
    • By o2so
      Item: Rel T5i subwoofer
      Price: $600 plus postage
      Item Condition: 8.5/10 - some swirls in the gloss, noticeable upon close inspection
      Reason for selling: Upgrading to m8audio sub to match my speakers
      Comes with original cables, booklet, receipt, box and packaging. Shipping can be done easily at buyers cost.
      Donation to SNA included.
    • By Benjet
      Item: Transformer coupled Headphone amp (on steroids)
      Price: $600 $550 500 450 with money back guarantee.
      Item Condition: Excellent
      This is basically the same amp as the other one advertised, apart for some major modifications.
      HT power supply has been totally re done. Far superior layout and power filtration (Rubicon and Russian PIO caps). This amp is whisper quite.
      All components (excluding the toroidal transformer, output transformers and tube sockets) have been swapped out for better ones. Mundolf interstage caps, Rubicon filter caps, Hammond choke, Alps pot and plently more.
      Silver solder used throughout.
      Optimised component layout with internal shielding within case.
      High and low impedance headphone sockets
      A lot of time and effort went into this build with exception results. Currently fitted with some nice Russian tubes and I will supply 2 other sets so the new owner can change if necessary. Really sad to see this one go, but I would prefer it being enjoyed by someone than sitting around being unused. Comes with money back guarantee, if you don’t like like, post it back in original condition and I’ll refund you the purchase price. What more can you want.
