leqt1969 Posted September 10, 2019 Share Posted September 10, 2019 SOLD Item: Roksan Caspian M1 Power Amplifier Location: Bexley, NSW Price: $750.00 ONO Item Condition: Excellent used condition Reason for selling: NLR Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: Advertised on behalf of a friend in Sydney. This is in excellent used condition. Caspian M series-1 Power Amplifier Spec Input Impedance: 38 kΩ Input Sensitivity: 700mV RMS Signal Inputs: Left & Right channels Signal Outputs: Chain Output L & R Channels Power Outputs: Loudspeaker, L & R Output Power:> 85 Watts continuous, into 8ohm; both channels driven; 120 Watts continuous, into 4ohm; both channels driven Power Supply: 330VA Ultra Low Noise Toroidal Transformer Current Output: 50 Amps Peak to Peak Damping Factor: & gt; 140 (8ohm) Frequency response: -3dB, <1Hz -> 100kHz Gain: 30.7dB Harmonic Distortion: <0.003% 1 kHz - 8 ohm <0.003% 1 kHz - 4 ohm Signal to Noise Ratio:>116dB (ref 70W, 8ohm) Dimension: 432 x 330 x 70 (W x D x H) mm 432 x 330 x 85 (including feet) Weight: 10 Kg Photos: Advertisements without photos of the actual item will not be approved. 1 Link to comment Share on other sites More sharing options...
leqt1969 Posted September 15, 2019 Author Share Posted September 15, 2019 SOLD Link to comment Share on other sites More sharing options...
