Kafunis
FS: Vinyl for sale Brisbane
Item: Various LP's
Price: As Listed
Item Condition: NM-VG+
Reason for selling:  Excess
Payment Method: Pickup - Cash, Bank Transfer, COD Only
Extra Info:  Pick Up Or can post any 3(Three) or More . Most are in excellent condition and have only been played once of twice .
Them-Them Again MONO 2016 remaster VG+  $22
Them-Angry Young Them MONO 2016  VG+$22
Paul Simon-One Trick Pony AU 1980 VG $12
Paul Simon-Still Crazy After All These Years 2013 remaster NM  $29
Neil Young-Songs For Judy 2 LP's NM, played once  $35
Dire Straits-Love Over Gold Chris Bellman remaster VG+ $20
Lucinda Williams-This Sweet Old World 25th Anniversary 2 LP's PINK  played once $35
Bob Dylan-John Wesley Harding Mono reissue EU M still sealed $29
Feist-Metals-VG+  $20
Nils Frahm-Spaces 2 LP VMP reissue exclusive artwork NM $35
John Murry-A Short History Of Decay  VG+ $20
Vampire Weekend-Modern Vampires Of The City incl Poster VG + $20
Phosphorescent-To Willie VG+  $25
Matthew E White-Fresh Blood VG+ $20
Father John Misty-Fear Fun VG+ $23
Shawn Colvin-Steady On AU 1989 VG+ $10
Hurray For The Riff Raff-The Navigator VG+ $25
Donny Hathaway-Extension Of A Man,  Rhino Remaster  $25
Pick Up Tarragindi or can post any 3 or more for $18 to East Coast , a little more to SA/WA  PM for price
Hi
Could i have the following 5
Nils Frahm
John Murry
Shawn Colvin
Lucinda Williams
Donny Hathaway
Would require shipping to Melbourne  3000
Could I get these please?
Also, would you be visiting the Brisbane CBD anytime?
Thanks,
Ananth
8 minutes ago, Ananth said:
Thanks,
Ananth
Hi PM'd
4 hours ago, Demondes said:
Hi
Nils Frahm
John Murry
Shawn Colvin
Lucinda Williams
Donny Hathaway
PM'd
Could i grab-Matthew E White-Fresh Blood VG+ & Father John Misty-Fear Fun VG+ pick up Plz
12 hours ago, souljay said:
Did donny hathaway go?
Hi Yes, that's gone .
    • By LWA Staff
      Item: NAD 302 Amplifier
      Price: Was $299 StereoNET Member Special $250
      Item Condition: Very Good Secondhand Condition
      Payment Method: Bank transfer, credit cards, cash, Paypal, ZipPay
      Shipping: Anywhere in Australia - POA
      Extra Info: A classic in great condition - circa 1993. European amplifier of the year 1993 and 1994. The NAD 302 delivers 25 watts per channel (8 ohm) and features include a phono stage, tone control, pre out and main in.
      Specifications:
      - Phono, CD, Video, Tuner, Tape 1 (In / Out), Tape 2 (In / Out), Pre out, Main in, Tone Control
      - Power output: 25 watts per channel into 8 (stereo)
      - Frequency response: 20Hz to 20kHz
      - Total harmonic distortion: 0.03%
      - Damping factor: 60
      - Input sensitivity: 2.7mV (MM), 165mV (line)
      - Signal to noise ratio: 77dB (MM), 90dB (line)
      - Dimensions: 420 x 108 x 320mm
      - Weight: 6 kg
    • By beetle-audio
      Item: Gigawatt PC-3 EVO (Black) (AU Plugs)
      Price: $2700
      Item Condition: Used but perfect condition, do not have original box but will be well packed for delivery if needed. Bare in mind this is the previous version.
      Reason for selling: NLR
      Payment Method: Pickup or deliver at cost - Direct Deposit, Cash or Paypal + charges.
      3 different banks of 2 outlet for digital, analogue and high current.
      Below info taken from Gigawatt website:
      PC-3 EVO is a technologically advanced power conditioner, designed to power and protect HI-END audio-video systems. This conditioner not only effectively protects from any kind of interference and overvoltage in the power grid, but most of all warrants visible improvement of the sound and picture quality in the powered devices. The unit excels with a solid construction, usage of selected components and high quality and aesthetics of workmanship.
      In the construction of the PC-3 EVO we resigned from using separation transformers and applied a worked out, multi-stage, parallel filtration instead. The conditioner is equipped with three independent filtering branches, separate for each pair of output sockets. Due to this solution the filtration of each of the branches was adapted to the character of the load, that will be used on those sockets, different for each kind of devices – digital, analog or high current draw units. The autonomous passive filters allow for isolation from interference generated by devices connected to a common power line.
      Compared to lower models of conditioners, the PC-3 EVO is based on a new architecture of filters and uses a variety of new components. Due to the increased efficiency of the new filtering circuits they were mounted using silver solder on massive PCBs with eight-fold content of copper compared to standard PCB. The two layered PCBS have very wide conductive traces made from 280 micrometer thick silver plated copper. Damping of the interference is made in RLC type filtering blocks, built using, among other things, metallized polyester capacitors with low inductance and Super-MSS (Sendust) core filters.
      In this conditioner we also resigned from using traditional protective elements, like wire or thermal fuses, which throttle the free flow of current to the protected circuits and by this have a negative influence on the sound. The overvoltage protection of the conditioner is guaranteed by the start block, which contains plasma spark gaps, next-generations of UltraMOV varistors and an initial filter. Those elements, working together with a well designed, modern power grid, warrant a complex protection against overcurrent and overvoltage.
      The effective input voltage (True RMS) is indicated by a precise, digital voltmeter with a red LED display mounted in the front panel. This voltmeter is characterized by resistance to distortion and measurement errors caused by higher harmonics, and does not generate any interference on its own, which could worsen the quality of power filtered by the conditioner. On special order other colors of the display are available: green and blue. The conditioner is also equipped with an additional circuit, signaling problems with its connection to the power grid. A red LED mounted on the back signals improper polarization of the power fed to the conditioner or bad connection of the grounding.
      The PC-3 EVO uses an innovative, two stage current distribution system, being a proprietary development of the company. It is based on massive power distribution bars of 2nd generation, made from polished, high purity, cathode copper slabs (Cu-ETP). The first stage allows for lossless and equal distribution of power to the individual filtering branches. The second stage supplies power directly to each pair of output sockets, using crimped and screw-tightened connections and cabling made from silver plated OFC copper wires in FEP Teflon insulation with a cross-section of 4 QMM. The use of the star wiring topology and the high conductance and massive cross-section of about 30 QMM of each of the bars warrants an equal and stable power distribution regardless of the load on any of the conditioner’s outputs.
      To allow for the highest possible impulse response the PC-3 EVO is equipped with a double buffering circuit with compensation cells with enhanced capacity. This circuit improves the impulse response with non-linear loads, like for example power amplifiers, and levels the difference between input and output power of the conditioner, allowing for almost unlimited impulse capabilities.
    • By Spirit07
      Item: Cambridge CXN V2 Network Music Player.
      Price: $1,145.00
      Item Condition: As New, 2 days old.
      Reason for selling: Upgrade to NAD M10 for Convenience.
      Selling a Cambridge CXN V2 Network Music Player - Bought New only 2 days old to listen in my bedroom, though having issues setting it up within a smallish area, I don’t really want to purchase another Hi Fi cabinet, and to move my speakers. Looking at moving up to the NAD M10 instead to avoid the number of seperate components, and for the convenience.
      Of course I still have all the original boxes, invoice etc. and happy to courier it at the Buyer’s cost.
      I have used the unit for only a couple of hours as it only arrived yesterday, and have performed a system reset, and for your convenience I have installed the batteries in the remote.
    • By jdc_aussievinyl
      Item: Various LPs
      Price: $140 the lot or individual prices below.
      Item Condition: Variable (see below)
      Reason for selling: Cleaning out some space.
      Payment Method: Pickup - Cash, Paypal, Bank Deposit
      5% of all sales will be donated to the forum
      VARIOUS VINYL
      Grading = Sleeve/Vinyl
      $150 for the lot OR
      Brian Fallon - Painkillers LP - NM/EX - $20
      The Joy Formidable - The Big Roar 2LP - NM/EX - $45
      Keane - Strangeland - NM/VG+ - $40
      Stranger things - music from the original series 2LP - EX/NM- $30
      Stranger things 3 - music from the original series 2LP (purple splatter) + 7" and (6) playing cards - VG/NM (has a cut and crease on the back [see pics]) - $30
      Postage available at cost
    • By MixedBag
      Item: 18 LP’s
      Price: $30 + pp
      Item Condition: at least VG+
      Reason for selling: the thinning continues
      Payment Method: Pickup - Cash, Paypal or bank transfer.
      As pictured (there’s that carpet again...) any questions just ask.
      Anywhere in Australia (Post) <5kg so around $20
