Marcdee
JH Turntable advice
I've just acquired a JH turntable for free and could use a steer on getting it sorted and running. The owner bought it new in 1974. Does anyone have any idea what model this is? (obviously google hasn't helped with finding manual).
Keen on getting it going. The owner (my neighbour) is non-techie but he said they'd taken it to Carlton AV here in Melbourne, and they said there was an issue with the wiring in the tonearm. Advice was the cost to fix was too high for the unit.
I've plugged it in and run it through my amp; sounds fine although I had to manually rotate the disc. I'd like to get a manual or something with detail on the internals to see if I can get it living again.
Some questions for the forum (obviously I've googled first with not a great deal of luck on this specific machine):
  1. I need to replace the belt but not sure what the correct size is - any suggestions? The existing belt is really overstretched so I can't use that as a gauge.
  2. I don't get how the 33/45 speed change works. Looks like you pull the spindle up to change speeds, I'm assuming it's moving the belt on to a smaller pulley. Would be great to see an image of how it's meant to look set up correctly so I can sort it once I replace the belt. Here's a vid: https://imgur.com/ivZxmGI
  3. The tone arm lever appears to be out of whack, again any suggestions on how it should sit? At the moment the arm seems to be coming up under the left side and I can't rotate it around without breaking it.
  4. I'm assuming a new cartridge is in order, but can't find a source for info on what is compatible with that tone arm.
Would appreciate any steers to online info (not expecting the forum to do everything for me, but I'm a turntable newbie with 'beginners' electronics skills).
cheers, pics below.
Edited by Marcdee
typo
Yes, the speed change works by moving the belt between the large and small parts of that black plastic pulley.  I would just move the belt by hand on the few occasions you'll need to change it.
That tone arm lever is the anti-skate and it sits on top of the little rod at the back of the tonearm.  You adjust the amount of anti-skate with the weight on the lever by the look of it.
I think this belt may be correct  http://www.decibelhifi.com.au/belt-for-jh-turntables/
if you are into vintage gear, the cost is worth restoring and enjoying a piece of history, the JH is not the best but certainly not the worst by a country mile, many members own such models and may help as well, good luck
PM SENT...TURNTABLE REPAIR
VANCH 😊
Tks guys🤙
    • By mtan002
      Item Condition: Used but Working Perfectly Shipping Options: Pickup available and you can audition. Suburb or Town: Point Cook State: Victoria Payment Method: Paypal, EFT, Cash Reason for selling: Redundant items Further information:
      These are beautiful amplifiers made by Audiolab in UK. They are offered for sale as a combination.
      They might seem dated but they still work beautifully. The 8000C preamp is specially suited for people with turntables as it offers both MM and MC inputs.
      The  8000P power amp is not huge by today standard but it produces enough powers for most speakers. It provides minimum 100W per channel.
    • By Sledge
      Price: $2000 Item Condition: 9.5/10 (only as not new) Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Canberra State: Australian Capital Territory Payment Method: COD or DD Reason for selling: Lack of use, downgrading. Further information:
      Original owner
      Flawless condition
      Done less than 100hrs
      RRP replacement $4,399.
      Review:
      http://www.hifi-review.com/152615-audiolab-8200mb.html
      Specs:
      Rated Power Output 250W rms into 8 ohm / 400W rms into 4 ohm
      Frequency Response 0.1Hz - 120kHz (-3dB)
      Input Sensitivity 1.63V rms
      Input Impedence 20kΩ balanced, 15kΩ unbalanced
      Gain 29.0dB at 1kHz
      Signal-to-Noise Ratio Better than 88dB
      Total Harmonic Distortion (THD) Less than 0.03%
      Inputs Balanced XLR and Single-ended RCA
      Dimensions (H x W x D) 150 x 216 x 379mm
      Weight 9kg each
      Colour Choice Black
    • By Saxe
      Price: $ Item Condition: As New. Excellent 9.99/10 Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: McKellar State: Australian Capital Territory Payment Method: Cash P/U, Bank Deposit or PayPal (+3%) Reason for selling: Changed direction not being used. Further information:
    • By getdisdude
      Item: AUDIOLAB M-DAC with Bonus Analysis Plus USB cable
      Price: $550
      Item Condition: Perfect
      Reason for selling: NLR
      This is a fantastic DAC and i've enjoyed it more than i expected to.  I've used it mostly for USB audio which it does amazingly. I've since got a streamer/dac which i'm also happy with, so don't need this anymore.
      I will throw in a bonus Analysis Plus Purple USB cable with the sale.
    • By Arv
      Item: Audiolab M-DAC
      Price: $550 $450
      Item Condition: Fair (6.5/10) - RCA plug for Coax 1 is missing. See Pictures
      Reason for selling: Trying out the Primare DAC 30
      Payment Method: Cash, Paypal as a friend (or +3% fees), Bank Transfer
      Extra Info: Purchased from a fellow SNA member late 2017. This was the first DAC I introduced in my system and absolutely loved it! Only selling as I am now experimenting with a Primare DAC 30 also purchased via SNA.
      Has been sitting idle in a box for the last 4 months but was running original firmware, however can be easily upgraded.
      Well known DAC with lots of reviews online - just search google.
      Do not have original packaging so preference for pick-up in Sydney NSW, however I can purchase packaging, pack well and ship at buyers expense.
      Includes original power cable and remote.
      UPDATE: The RCA plug for Coax 1 input is missing - I have just updated the price to reflect current condition. Any questions please ask.
