Solar PV. Anyone here applied for the Victorian solar rebate or solar rebates for other states?
  • Replies 149
Popular Posts
I did mention you have to ask AGL for this higher feed in rate of 20 cents it doesn't show up on the web data guys, but it is switchable for free as many times as you like, so its easy to switch betwe
Goodaye all   Ours system,s best day was 42kw here in Melbourne, with a average summer day being 32kw. 6.6kw of panels into a 5kw invertor.   Last year they sent us a $1k cheq
@Addicted to music Peter My partner applied for the earlier rebate late last year.  She eventually received the rebate after many months of anguish.  The process was 10x worse than pulling t
Guest rmpfyf
1 hour ago, ArthurDent said:
  Enphase microinverters + Envoy-S is fully DRM compliant isn't it?
DRM compliance under AS/NZS 4755 simply means the inverter (or solution) complies with demand response requirements to turn itself off when asked by a grid operator. All inverters have needed to support this for a while.
What  Enphase can't do is control 'other stuff' well.
F'rinstance Fronius has a smart relay in their inverters which is programmable. Solar does x, you can set something else to do y.  They've also a nice hot water controller.
SolarEdge has a very complete suite of solutions from hot water controllers, dry contacts with and without measurement, etc.
Some other home energy management solutions do even more - the unit at my place does battery, hot water, car charging, HVAC, all sorts of intelligent control relative to PV generation.
The key is to have a solution that generates value by using as much of your solar generation as possible in a high-value way such that you get more from using it than exporting it. (For a rare few still on premium feed-in tariffs, this obviously doesn't apply).
We don't need all the other stuff.
What we do need is to generate as much power from our LG Neon 2 panels which are physically limited in terms of numbers, placement and tilt angle and also have some shading issues which simply cannot be avoided.
String inverter(s) would have been really inefficient but micro inverters work well in our situation and Enphase make very good ones.
Guest rmpfyf
I'm at the other end, also NeON 2. We have heaps of energy and may put in more just because we can - we're allowed 30kW on three phases - it's important for us to use it as best possible with tons of generation but also most major loads being electrical (only the cooktop is gas). I've worked in the industry enough to try a few solutions on the house - bit of a lab, really - the CET gateway we have is awesome. It could work with your PV in a generic way.
I prefer SolarEdge over Enphase for various reasons though as far as power conversion goes they're both excellent if correctly installed. You didn't do it cheap with LG and Enphase though that makes for a top end system that should last a very long while. Well done.
Biggest benefits of Enphase micro inverters for places that have shade issue.  There is also a safety benefit to convert DC to AC at the panel.  Safer to have AC routes than HVDC running everywhere.
Yeah, not a fan of having high voltage DC running everywhere. AC is way safer and with less losses.
On 21/04/2020 at 11:18 AM, rmpfyf said:
Solahart Powerstore - no pumps, thermostats, water on roof, nothing. No flames, no gas piping.
Higher efficiency, more energy.
You'd love it.
Had that quoted today, it isn’t exactly cheap,  $5k is a lot of money!    Fully installed with all the power management and monitoring set!
However if anyone wanna go down this route definitely see if you can have this priced in with panels installed....  I’d like the idea of excess FIT being used on site and be able to managed what the system is capable of.
Me neither,
High voltage DC is scary stuff,  it puts demand on the quality of connections and installation, then there’s inspections....   if you ever seen 7KV -10kV on a high voltage wire in the dark?   There’s a purple halo around the wire,  and the distances required to stop arcing is critical,  I’ve seen leaks through solid insulation at that voltage,      not that you’ll see that up to 1000VDC....  for a PV..
i did have an Enphase quote but ended up ditching it,  as you can see it wouldn’t have benefited cost wise as I have no shade issues....apart from that evaporative unit....
Guest rmpfyf
That's a fallacy - why is it safer?
26 minutes ago, ArthurDent said:
DC isolators were the issue.  There were severe manufacturing defaults that required recalls...
Also we are the only place in the world to put an isolator close to the panels and we are the only country in the world to suffer from fires with PV caused by faulty DC isolators.
There is a lobby trying to have these removed to minimised the possibility of a fault.....
I actually put a lot of these links in another thread on solar for the host,
Edited by Addicted to music
Guest rmpfyf
23 minutes ago, ArthurDent said:
Great, so you've pointed out a problem with DC isolators, not with DC.
Arc fault protection is a known thing. Australia might not have standards to suit but many countries do, and firmware is duly implemented.
Again - why is AC safer in rooftop PV?
Not having a specific go at you though this one gets used a lot by microinverter types and it's not quite correct. System safety is a function of risks and controls. If risks are known and controls are properly implemented, appropriate and/or equivalent levels of safety can be reached.
DC is harder to switch, it’s self explanatory on the links...  whether it’s DC isolators or DC itself it doesn’t matter, the reality is that we are in DC domain...
Eliminate the risk by not implementing the system and you have no need for controls.....  simple...
The other advantage of AC systems which could also be considered a safety issue is line losses.
Our power grid to our homes is AC for a reason even though that opportunist Edison wrongly went for a DC system with a power plant on every second block.
And who knows what these are?
Edited by ArthurDent
It’s basically ohms law that applies.  Resistance (ohms) increases with distance...hence the losses. .  Because of the characteristics of AC,  it can be applied to longer distance safer than DC.
Guest rmpfyf
Not a safety issue per se.
You have different risks with AC reticulation, not eliminated risks. If you want to get rid of DC, don't have solar.
Not a safety issue and AC is neither immune. No reasonably strung system is likely to suffer line losses of any significance.
If the components are well over rated and care in installation is taken, no, but the possibility is there even all this ticks all the boxes.
You eliminate the possibility of DC arcing,  not exactly present in AC.  HVDC will find its way through well rated insulation in time, I’ve seen it in multiple times in the application I work in.
Dont have Solar?
Not a possibility for clean energy is it?    Single Panels producing 40-60VDC max isn’t an issue....  that’s why microinverters is such a great option.  Connecting panels in series where there’s hundreds of DCV become an issue,  have those connection run down behind a brick wall with both wires super close together, then you have 2 isolator switches is a real issue, if they end up being discovered “unfit for purpose “ where they are known to to start fires and a recall finally announced, now that’s a real issue.
Like I said we are the only country in the world that makes it a requirement to have a isolator next to the panels, we are the only country in the world to suffer multiple PV Solar fires....  No where in the world, even with extreme climates suffer the same rate in PV fires.
Guest rmpfyf
No offence though this shows a gross misunderstanding of electrical risk. It is not a function of voltage as in 'lower voltage equals lower risk' is incorrect. Many, many industrial accidents arise from this very incorrect assumption.
Again, that's an isolator problem. And isolators that work do also save lives in making roof work safer. There's no doubt that making a DC isolator fit for purpose is a more robust exercise than same rated current AC. There is no doubt that designing a switch to sit on the roof is not a trivial task. There is no doubt that emergency services hardly ever climb onto the roof and flick the switch.
This points to a review of the necessity and specification of DC isolators. It does not mean that microinverters are a 'better' or 'safer' option.
  • 9 months later...
Extremely happy with what we have, 20 330 Qcells and a 5kw SMA inverter.
We haven’t had a hot summer but when the sun does shine it’s producing better than expected.  I wish we were allowed a bigger capacity inverter as it looks like the power from the panels have been capped by the 5kw inverter.   And all on 2 sides Nth and west facing.   For such a limited system we are achieving 40kwh on a sunny day.  Even with $0.10 Feed in we are now profiting.
Goodaye all
Last year they sent us a $1k cheque and last bill was already in credit of $350
We get a small bill in winter.
Paid off in 2 years not the 3.5 l had predicted.
Would like a battery but its just not worth it.
regards Bruce
@sloper
Right at this time, if you have a electric hot water service the state government is pushing to have old heater element types that taxes you’re electricity use with incentives  to install a heat pump type water storage unit simular what @rmpfyf has.   It’s limited to the smallest capacity around the 170lt.   There are brands with tanks that goes up to 270-330lts max but that’s added costs but well worth if you have a large family. If you’re headed this route it’s better than a battery as it will manage the solar usage and not feed it back to the grid.   Excellent idea, the only limitations is the quality of the tanks used.  Theres a push from a particular brand that I won’t name here are pushing cheap heat pumps with 130-170lts no out of pocket expense, where a lot of high volume builders are taking up this scheme,  just beware that all is not what it seems,  the warranty is limited which is the 1st warning signs, the next signs is check and do your research as some are totally unreliable.   No good if you spend $4-8k on a system where the tank leaks in a few years.  The other issue is not many of these units are out there long enough to prove reliability.  If I were to go for one it must have a stainless steel tank that’s maintenance free that can cope with all hardness of water, but that’s just me!
My max per day was in e December as you would expect but as you notice we have had sunny days
Guest rmpfyf
I don't have a heat pump, I have an electric hot water tank with built-in high-response diverter, two elements connected to a dedicated HEMS.
One of these https://www.solahart.com.au/products/battery-storage/solahart-powerstore/
We now have 17.6kW of PV on 16.4kW of inverter. Maximum generation ever 125kWh/day. Self-consumption favours hot water first, there is very little boosting offpeak and we don't pay for hot water in a net sense.
I didn't want a heat pump. Sorry. I've played with a lot before - the Chromagen/Midea units are complete crap - I've had Stiebel Eltron units pack up and replaced them with nicer Glen Dimplex units, there's Sanden and Reclaim (Chofu) out there as well however we're talking about stuff with a lot of moving parts, very little aftersales, noise and poor thermal resistance in the cold. I have zero moving parts in my electric tank and though it's around 3x less efficient, I have a silly amount of PV, low-flow heads and when the tank is full it gets used for other stuff anyway.
The only heat pump system I've ever done which I'd recommend are whole-of-house units, literally one big unit that does space heating/cooling and water (Glen Dimplex out of the Euro parts catalogue - very impressive) or LG Electronics (now these are properly in market). You'd be very committed to do one as an add-on though, these are best reserved for new builds.
Doing some occasional work for a company developing a nice battery storage system in Australia; I might add a battery next year, might go a third phase of PV :D
@rmpfyf
your post saids it all and sums it up about the renewable industry. 😃
Anything the heats reduces reliability,  complicate it with moving parts and you compound the issues, it’s just the nature of beast....  Yep agreed with you on that brand, not very environmentally friendly when you are out laying $4k and it needs to be binned around the 5 yr mark and that’s if it gets to 5yrs...  I’ve heard a whole development block with 35 units using the same brand and all the apartments had hot water leaks, change it to something well known and it’s all good.....  I think it went to VCAT but still high volume builders will use it, great sales pitch for the bliss young couples/families who wants a new home!
I also had your unit priced; $8k so I’m not going there 😂.   The figures at that price doesn’t work out!   I believe you can get a module that manages the hot water tank if it’s electric for $1k but that’s not in the current State Government incentive....  Right now I’m sticking to something I know that has lasted 30yrs plus; 135lt Aquamax that has a stainless steel maintenance free tank!  This is now 3 yrs old, but my parent and my brothers units are still going over 30yrs..   I’m sticking to what I know is reliable....👍
Guest rmpfyf
25 minutes ago, Addicted to music said:
@rmpfyf
$4k sounds exxy, I paid a lot less than that. Think your dealer might be taking you for a ride.
Plenty of options out there - Glen Dimplex was selling the Free-E system for around $700 that you could retrofit with ease and works really well. There are others.
Your tank has a natural gas appetite, I'm trying to get rid of it.
The whole-of-house heat pump units are very, very robust. Have a mate doing 7 thermal zones with one including the pool and domestic hot water on a 10kW PV system, and I don't think he's paid for energy in a good while now. Nor run out of hot or cold anything.
Only regret I have with the Powerstore is not getting a second tank and running some hydronic heating with it.
  • 2 weeks later...
 Can you expand upon this...? I haven't been able to google anyone company that combines to two
thanks
Edited by Honreekea
Guest rmpfyf
thanks
What do you need to know?
A few have alluded to some issues, beyond the obvious ridiculous minefield of mess that is rebate systems (designed by the same people who design the system you navigate to claim on any insurance), which I reckon are really important here.
- I think it is really important to consider the embodied energy cost of the gear you are considering.  Time and time again, cheap PV solar panels have been shown to output less than advertised, dropping rapidly over a few years, or failing outright.  If they have not exceeded their produced energy compared to the energy it took to make them, then they are a burden, not a benefit.  Listen to expertise here, read proper reviews including data on testing, and save for the best you can manage.  If you can only afford the cheap stuff, it is likely you’re best to save and wait!
- I researched and had installed a combined gas hydronic heating system (22 panels) with a combined solar hot water 550lt stainless tank, where the heating can use a heat exchanger in the tank to circulate its hydronic heat.  All sounds fine, and make sense to me, but my experience has always been the same.  Most (I say most, not all) tradies go into headspins over anything that deviates from routine.  I was recommended an installer, and from day 1 he had no clue, then began avoiding the job, then disappeared, then declared bankruptcy.  Moral  is that, if you’re a researcher like me, you may know more than a supplier!!  Do your homework and use a proper expert.....
thanks for getting back to me.  Already have the info I need. cheers
