olegau
FS: Luxman L-509U Integrated Amplifier
Item: Luxman L-509U Integrated Amplifier
Price:
$5900
Item Condition: as new
Reason for selling:
need money
The highest-class model of LUXMAN  Integrated Amplifier.
I am one only owner. Bought new for $8000 in 2012
The amp has never been repaired, works very well. No issues, can give a week warranty.
The unit has never been loud more then 9am because I live in a flat and I like my neighbors.
Continuous effective output: 120W + 120W -8ohm   240W + 240W  4 ohm
reproduction frequency: PHONO: 20Hz ~ 20,000Hz  0.5dB) LINE: 20Hz ~ 100kHz (+ 0, -3.0dB)
SN ratio: PHONO (MM): 91dB or more PHONO (MC): 75dB or more LINE: 107dB or more
Dimension: W 467 x H 179 x D 435 mm
Weight:  28 kg
Preferably Pickup
Also look  another my amp Sansui AU-a607DR amp for sale on this site.
Edited by olegau
Hi Oleg, you mentioned in another thread that it was running hot and good for keeping the house warm in winter. Is this class A or AB? I can only find info on the 509x but not o 509u ?
This is AB, the class A is only 30w, and different colour meters
The photos are definitely showing the  507u which is A/B.
It's VU metres are blue illuminated and really should never run so hot as to warm the room.
I have a Class A model and it gets warmish, but never hot.  When I owned the 507 it was never more than luke warm even after being on for hours.
Edited by rantan
The 509u is an older model.    The x is the latest model that replaced the 509u in 2018.  If you look at the back panel of each, they are very different.
https://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=157:luxman-l-509u-integrated-amplifier&catid=34&Itemid=146
ps - no idea what @rantan is talking about. It is a 509u, not a 507u. he must be back on the turps xD
Edited by metal beat
2 minutes ago, metal beat said:
The 509U is an older model.    The X is the latest model.  If you look at the back panel of each, they are very different.
ps - no idea what @rantan is talking about. It is a 509U, not a 507U. he must be back on the turps xD
Nope, not a drop, just a good old fashioned typo😱
I meant it is running hotter compare to Sansui, Rotel, Cambrige Audio and so on I have had.  My old Luxman LV-105u is getting hotter than 509u.   Luxman Class A amps getting even more hotter.
This is AB amp.
Actually initially I bought  507U but after a couple of days I decided to pay extra to replace it with 509U. Then I was happy.
Wow, that is one nice amp, I am just doing some more research, it certainly has WAF :)
    • By ssb102
      Item: 4x Fanless ROON ROCK Servers
      Price: Varies, see below
      Item Condition: Excellent
      Reason for selling: Surplus!
      It's 2020 and it's high time i cleared my backlog of projects.
      I have FIVE Fanless Roon Rock Boxes for sale.
      All totally silent with SSDs running the latest version of ROON ROCK
      Small enough to fit on a bookshelf and use far less power than a full PC or laptop so you can really leave them running.
      Your wife/girlfriend/dog/cat wont even notice.
      3x WYSE Zx0
      (2 Units) 8GB + Ethernet + Wifi $120 ea
      (1  Unit) 16GB + Ethernet + Wifi $150 ea
      (1 Unit left! ) 8GB + Ethernet + Wifi $120 ea
      1x Dell Optiplex FX160 with 32GB SSD
      $200 $150 PRICE DROP
      Intel Atom platform
      Gigabit Ethernet  (via USB 3.0 adapter, FREE)
      Wifi optional extra
      ALL BOOT INSTANTLY AND WORK FLAWLESSLY.
      These SSD sizes are more than adequate to hold the ROON database because with ROON your music is stored elsewhere.
      Priced fairly these are an excellent way to get started with ROON.
      Reasonable offers considered. Discounts for multiple purchases or pickup.
      Lowballers and timewasters will be sent a copy of the Betoota Advocate.
      ARSE mug not included.
      Shipping available just DM me for a quote.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By russell66
      Item: Klipsch Synergy Home Theatre Speakers
      Price: $600ono
      Item Condition: Very Good all working well, some minor marks.
      Reason for selling: No Longer Required
      Excellent sounding home theatre package. Klipsch are well known for their cinema speaker designs.
      Fitting out many cinemas and shows with these speakers.
      They excel with soundstage, dynamics and detail.
      Package consists of ...
      2 x Synergy F10 Floor-standers
      2 X Synergy B20 Bookshelf's
      1 X Synergy C1 Centre
      1 X SW 350 Sub Woofer
      Post is available at your cost and risk.
    • By fffastfaz
      Item: Chord Shawline USB Cable 1M
      Price: $275.00 incl postage
      Item Condition: Brand new
      Extra Info: Cable is brand new and cost $350.00
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 Price Drop $2850 inc shipping Australia Wide, can do a little less if you can collect in person to save packing and freight.
      Item Condition: Excellent, Used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the external motor PSU and controller with a samurai silver coin from WA mint. So the turntable is dubbed "The Samurai"
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
