BuzzzFuzzz
The Needle in the Groove
Hey Guys.
Rather than googling an audio question, I tend to post here first 'cos I love this forum.
I always thought that the left and right channel of phono output came from the two sides of the record groove.  Seems to be logical.
My brother was visiting recently and he's a bit of an information and technical guru who has built his own computers and valve, guitar amps, among many other goodies.
He told me that the one channel comes from the sides of the groove, and the other comes from the bottom of the groove.
Any insights here?
Ant.
I just had a 'quick' look on Vinyl Engine.  Seems my bro is wrong.  A stylus will only touch the bottom of the groove when it is worn or damaged.
Will look into it further.
The groove walls are cut in a 90 degree 'V' shape. One side of the V contains the left channel and the other side the right channel.
A quote from Vinyl Engine...
  "kuan: Well, I guess you could easily imagine an arrangement with one channel inscribed laterally and the other vertically and one needle reading both at the same time, but feeding two sensors for the two planes (up/down, left/right). Problem with that would be mono to stereo compatibility. Hence the clever trick was to rotate the whole affair by 45 °, so that the two planes are now left&down/right&up and vice versa right&down/left&up. Now you just need to change the sensor arrangement accordingly, the rest remains the same - and thus you get a solution that is stereo capable and mono compatible at the same time."
My bro is sort of correct, there are lateral and vertical readings.
I'm still a little confused, can anyone explain it simply and comprehensively???
Stereo records have a 45/45 degree configured groove (kinda like a V), so stereo playback requires lateral, rather than vertical, movement. Each side of the V groove corresponding to one channel - left and right of the stereo content.
78rpm records use a mono stylus/needle that reads the mono information vertically.
Yes, but they are old mono recordings.  All modern records are 45/45, one channel per groove side..
@davm already has!  The groove walls are cut in a 90 degree 'V' shape. One side of the V (the inner side) contains the left channel and the other side (the outer side), the right channel.
Not really!  The music comes from the horizontal wiggles in the sides of the grooves.
Copied from a link provided on Vinyl Engine...
http://www.vinylrecorder.com/stereo.html
There are two possibilities to modulate a groove:
Simplified presentation
Vertical
Modulation
Stereo Groove
vertical modulation
Horizontal Modulation
Mono Groove
horizontal modulation
Both modulations together:
Two
Channels
hor.gif stereo modulation
Stereo Groove
2 channels
But:
Horizontal modulation is better than vertical !
Vertical modulation:
More distortion !
Large amplitudes, not possible !
One channel always would be better !
The compromise:
All gets turned 45°
hor.gif 2 channels, 1 groove
Each channel half vertical, half horizontal !
A compromise
Right ChannelCutterhead topCutterhead left channelright channalCutterhead right channel
Right Channel Groove
right channel
Left ChannelCutterhead topCutterhead left channelleft channelCutterhead right channel
Left Channel Groove
left channel
MonoCutterhead topCutterhead left channelMonoCutterhead right channel
Mono Groove
mono
StereoCutterhead topCutterhead left channelStereoCutterhead right channel
Stereo Groove
stereo
Maximum Stereo or
Mono and 1 channel 180° phased
Cutterhead topCutterhead left channelExtremest Stereo: Mono 180° phasedCutterhead right channel
Stereo Groove
mono 180 phased
No-one has really done vertical modulation since the old mono Edison gramophone  discs.
