Luke0711
SOLD: Emotiva BasX A-700: 7-Channel Power Amplifier
Item: Emotiva BasX A-700: 7-Channel Power Amplifier
Price: $700
Item Condition:
Excellent
Reason for selling: Moved and changed set up.
Hey Guys,
I’m selling here a great EMOTIVA power amp.
Model: BASX A 700
It is a powerful 7 channel amp.
In great condition and without any issues.
I paid $1399 for it.
Here the like:
https://www.stereophonic.com.au/emotiva-basx-a-700-7-channel-power-amplifier/
Some specs:
The BasX A-700 is a seven channel power amplifier. The BasX A-700 combines classical audiophile amplifier architecture - based on a heavy-duty linear power supply, and a carefully designed high current, short signal path, Class A/B output stage, with advanced, microprocessor-controlled monitoring and protection circuitry, to deliver superb sound quality at a truly reasonable price.
Power Output (two channels driven)
110 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
210 watts RMS per channel; 1 kHz; THD < 1%; into 4 Ohms
Power Output (all channels driven)
80 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
Power Bandwidth (at rated power; 8 Ohm load)
20 Hz to 20 kHz (+ / - 0.07 dB).
Broad Band Frequency Response
5 Hz to 80 kHz (+ / - 1.8 dB).
THD + noise
< 0.02% (A-weighted); at rated power; 1 kHz; 8 Ohms
Signal to Noise Ratio (8 Ohm load)
> 120 dB (A-weighted); ref rated power.
> 100 dB (A-weighted); ref 1 watt.
Minimum Recommended Load Impedance
4 Ohms; which equals one 4 Ohm load or two paralleled 8 Ohm loads.
Damping Factor (8 Ohm load)
> 500.
Speaker Output Connections
Audiophile grade, 5-way binding posts.
    • By :) Go Away (:
      Item Condition: Used - Very good Shipping Options: Pickup available but audition is not available. Suburb or Town: Oran Park State: New South Wales Payment Method: PayPal, Cash on Pickup Reason for selling: Simplifying Further information:
      Up for sale is Emotiva XPA-5 Gen1 5 channel power amplifier in very good condition. This was purchased from another SNA member and was used in my HT setup. Due to its size and weight, I am unable to keep it in my entertainment unit and resolved to keep it on a floor. However, with the arrival of newborn son, I am now simplifying my setup as I hardly get a chance to watch any movies. Choice was to remove this amp or the wife and kids, and given the amp cannot cook, I had to choose wife.
      Please note, one of RCA input is slightly bent as a result of locking interconnect which I attempted to remove to take some photos. However, this does not affect the connection or performance. Apart from this, it is in very good condition both visually and performance wise.
      Specifications
      Power output: 200 watts per channel into 8Ω (5 channels)
      Frequency response: 5Hz to 150kHz
      Total harmonic distortion: 0.1%
      Gain: 32 dB
      Signal to noise ratio: 111dB
      Speaker load impedance: 4Ω (minimum)
      Dimensions: 17 x 7.75 x 19 inches
      Weight: 66lbs/ 30kgs
      Review here: https://www.stereophile.com/content/music-round-51
      At this stage, local pickup only, as I do not have an original box and this amp is really heavy at 30kg. Local pickup from Oran Park NSW 2570. Payment via Paypal as a friend or Paypal + fees or Cash on Pickup.
    • By pasic007
      Item: Power Amp
      Price Range: 10k
      Extra Info:  Prefer Mono's but can be integrated as well.
      If you have Preamp as well my budget is flexible. Must be less than 5 years old and Perth.
      pm me what you have.
    • By Megawolf
      Item Condition: good Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: LONG BEACH State: New South Wales Payment Method: Cash, EFT, Reason for selling: NLR Further information:
                                                          Rotel 1080.  2 x 200w.  Balanced and RCA imputs.
                                               I had planned to use this as part of a 7.2 surround system.
                                                            Middle speaker placement proved to be a massive pain, so I gave up on the idea.
                                                            When I bought it I found that one of the XLR inputs wasn`t working,
                                                           I sent it to rage audio, who found that the balance switch was dirty, cleaned up, presto one good amp.
                                                           The case has a few small marks, the front is fine as is the rear, just the top.
                                                           I can pack for postage, it would have to be insured and signed for.
                                                              Cheers.         Ian.
    • By Marc
      Item Condition: Used, but excellent with original packaging Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Sunbury State: Victoria Payment Method: Paypal (+fees), Cash on Pickup, EFT, Credit Card (+ fees) Reason for selling: Moved to Dante enabled amps Further information:
      This amp is still in the current JBL Synthesis range and is spec'd in many high end JBL Synthesis cinema systems, selling for over $6,000 locally.
      https://www.jblsynthesis.com/products/electronics/amplifiers/SDA+7200-.html?dwvar_SDA 7200-_color=Black Lacquer-GLOBAL-Current&cgid=amplifiers
      Can freight with insurance at cost Australia wide via Sendle.
      Stock photos:
    • By sakabatou
      Item Condition: Excellent, with warranty Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Adelaide State: South Australia Payment Method: PayID, PayPal, cash Reason for selling: NLR Further information:
      2x150W Class A/B power amp
      As new, with original packaging.
      Purchased from Klapp in Jun 2018, and therefore with over 1 year of warranty remaining.
      Used for about 6 weeks while waiting for another amp to be repaired, and boxed ever since (until tested today)
      will post at buyer expense and risk (just over 14kg packaged)
