Guest jwalker Posted August 25, 2019 Share Posted August 25, 2019 (edited) Hey guys, I'm a bit of a novice.... My kid tripped over a cable and broke one of these surround speakers. Seems like she completely buggered the speaker inside it, I can hear it flopping around when i pick it up. Spoke to Denon distributor here in Brissy and says can't get replacements for these as too old. It's a great system though. What should I do? Can I buy some other speakers, perhaps pick up a pair of used different speakers to replace the two rear ones (I'm guessing just replacing one with something different wouldn't be smart). What do you think? Any other suggestions? Edited August 25, 2019 by jwalker It's a Denon DHT-500SD system. The speaker model no is SC-A500SD. Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 25, 2019 Share Posted August 25, 2019 What speakers? Need more info' in what they are and the damage that occurred. Link to comment Share on other sites More sharing options...
Guest jwalker Posted August 25, 2019 Share Posted August 25, 2019 (edited) It's a Denon DHT-500SD system. The speaker model no is SC-A500SD. The magnets on each of the speakers have ripped right off and are flopping around inside Edited August 25, 2019 by jwalker Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 25, 2019 Share Posted August 25, 2019 (edited) If they are like normal speaker drivers....., they can be glued back in place but need to be aligned well..is all. But I can't find a good pic of inside these speakers. Edit: other option is to search ebay and gumtree, but that costs more and might be hit n miss. Edited August 25, 2019 by Muon N' Link to comment Share on other sites More sharing options...
Guest jwalker Posted August 25, 2019 Share Posted August 25, 2019 what if i pickup say a pair of bookshelf speakers and use these for the rears instead? Can you bung any old pair of speakers in place of these or do they really need to be something quite similar to the originals? Link to comment Share on other sites More sharing options...
Martykt Posted August 25, 2019 Share Posted August 25, 2019 @jwalker, another option may be to just replace the drivers rather than an entire pair of speakers. If they have a model number on them they should be pretty easy and affordable to source. If they don't have any model or part number on them it may be worth contacting Denon to source replacements. Link to comment Share on other sites More sharing options...
Martykt Posted August 25, 2019 Share Posted August 25, 2019 7 minutes ago, jwalker said: what if i pickup say a pair of bookshelf speakers and use these for the rears instead? Can you bung any old pair of speakers in place of these or do they really need to be something quite similar to the originals? I'm not a cinemaphile so take my advice with a grain of salt..... I would say for surround speakers any old pair of speakers would probably do the job especially with auto-calibration to tune them into the system. 1 Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 25, 2019 Share Posted August 25, 2019 (edited) To replace you will need to know the specs of the original speakers, so, no...can't just bung in any speakers if looking for it to work well. Edited August 25, 2019 by Muon N' Link to comment Share on other sites More sharing options...
Guest Posted August 25, 2019 Share Posted August 25, 2019 Those types of systems really only work well with the gear they are bought with. IMO, time to buy a new one. Link to comment Share on other sites More sharing options...
Madaxle Posted August 26, 2019 Share Posted August 26, 2019 Why dont you use one of the fronts as the rear and buy some new bookshelve front speakers Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 27, 2019 Share Posted August 27, 2019 5 hours ago, Madaxle said: Why dont you use one of the fronts as the rear and buy some new bookshelve front speakers And what spec'ed speakers does he need? Link to comment Share on other sites More sharing options...
Madaxle Posted August 27, 2019 Share Posted August 27, 2019 (edited) 22 minutes ago, Muon N' said: And what spec'ed speakers does he need? Found old manual here - page 35 shows the current specs. Maybe take the base unit into a hifi shop and see if you can plug in some speakers and test to see if they work. http://theatresystemmanual.com/image/catalog/denon/Denon_DHT-500SD.pdf Power amplifier Output power (6 Ω/ohms, 1 kHz, 10% THD, 100W) – TStereo ................................2 x 100 W Output power (6 Ω/ohms, 1 kHz, 10% THD, 100W) Front left/right ....................2 x 100 W Center ...............................100 W Surround left/right ...............2 x 100 W Subwoofer ............................100 W Edited August 27, 2019 by Madaxle Changed wording from show to shop Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 27, 2019 Share Posted August 27, 2019 @Madaxle that's helpful, I didn't find anything when I searched yesterday, you has good google foo Pity it doesn't state the sensitivity, but helpful still Link to comment Share on other sites More sharing options...
Guest Muon N' Posted August 27, 2019 Share Posted August 27, 2019 On 25/08/2019 at 8:14 PM, jwalker said: It's a Denon DHT-500SD system. The speaker model no is SC-A500SD. The magnets on each of the speakers have ripped right off and are flopping around inside I'm am not sure of the construction of those drivers, but if you want to try and repair it check out some guides to it. Link to comment Share on other sites More sharing options...
John_at_wormcount Posted July 29, 2020 Share Posted July 29, 2020 Did you ever replace these? If not I am interested in buying them from you as I am in Brissie as well with one broken out of five. Link to comment Share on other sites More sharing options...
