zydeco
FS: MSB MVC-1 Multi-Channel Pre-Amp
Item:  MSB MVC-1 Multi-Channel Pre-Amp
Item Condition: Good (8/10) – fully working with minor cosmetic blemishes on top (but front panel in excellent condition)
Reason for Selling: No longer being used
Price: $400
Payment Method: Cash, Bank Check, Electronic Funds Transfer
Additional Information: One of the few solutions for multi-channel analogue volume control. I've used in this fashion for active DIY speakers safe in the knowledge that I'm not reliant on digital volume control to protect the speakers in the event of an unexpected failure of the music computer source. Also support bi-, tri-amp and mono subs via switch configuration
MVCManual.pdf
    • By Selby Thornbury
      Item: AMC XAi 2-Zone 4-Channel Power Amplifier
      Price: $649 (RRP$999)
      Item Condition: Brand new x 2
      Payment Method: Pickup - Cash/Card
      Extra Info: For more info please call Selby Hallam
      AMC XAi 2-Zone 4-Channel Power Amplifier Rack Mountable
      Key Features
      - 45W x 4 or 90W x 2 Channel (Bridged) Amplifiers
      - High Efficiency Power Amplifiers for very low heat decipation in XA
      - Input sensitivity adjustment for each input
      - IR input as interface from outside to XA internal microprocessor
      - IR output for cascade IR signal path
      - RS232 interface in order to link XA to Ethernet System through USB or Ethernet Adaptor
      - Auto turning on / off feature control by Audio signals or 3~30V AC/DC Voltage
      - 12 V DV Trigger Output
      Item: AMC XOi 4-Zone 4-Source Stereo Multi Zone Amplifier
      Price:  $1039 (RRP$1099)
      Item Condition: Brand New x 1 (Hallam), Ex Display x 2 (1 - Hallam, 1 - Thornbury)
      Key Features
      - System for total 4 zones
      - System with 8 Sorecs 4 Local / 4 Remote mixed sources
      - Only RJ45 & speaker wires used for installation form XOi main unit to all zones
      - Two way AMC proprietary digital data communication system between XOi main unit and keypads in all zones
      - Designed with cascade feature for keypad XK1
      - Volume control & tone control for each zone
      - Four 38KHz and four 56KHz IR outpurs on rear panel of XOi main unit
      - Doorbell and telephone mute system (PDM1) - option
      - With RS232 to digital link with other systems - option
      - IR remote control receiver on each zone for controlling XOi main unit and remote soutces in the zones
      - RCA, 3.5mm mini jack and RJ45 remote source input jacks in each zone
      - Designed to work with the XK1 Keypad wall mounted zone controllers (available separately)
      - Designed to work with the XS1 Keypad wall mounted remote source units (available separately)
      Item: AMC X86i 6 Zone 8 Source Smart Home System
      Price: $1499 (RRP$2299)
      Item Condition: Ex-Display x 1
      Features
      System for total 6 Zones
      With 8 Sources – 4 Global Sources & 4 Remote Local Sources
      Only RJ45&Speaker Wires used for installations
      Two ways Digital Data Communication System between XO main unit and keypads in all zones
      Designed with cascade feature for keypad XK1 (required and extra)
      Two All Zone Connectors for making installing XO like 123 in seconds
      Volume Control&Tone Control for each Zone
      four 38KHz and four 56KHz IR outputs
      With RS232 to digital link with other systems including lighting controls via RS232 interface
      IR remote control receiver on each zone for controlling XO main unit and Local Sources in other zones
      RCA, 3.5mm mini jack and RJ45 Remote Local Source input jacks in each Zone
    • By Gwhitten
      Item: Synergistic research Rel Reference subwoofer cable 3.0M
      Price: $400
      Item Condition: Very Good
      Reason for selling:
      MPC 240V shielding cable
      Item: AV81c – Audio & Video Pre-Amp
      Price: $499
      Item Condition: Brand new x 1
      Extra Info: Please call Selby Hallam for more info
      FEATURES
      The AMC model AV81 Audio Video Control Center, is designed for control A/V system.
      Eight stereo audio inputs, four composite video inputs.
      Audio and video outputs.
      Remote volume control, source selection, audio mute, power.
      Record switch to record any A/V sources to any Cassette Decks or VCR‘s.
      Buffered video outputs.
      THD less than 0.01%.
      Audio S/N better than 95 dB.
      Video bandwidth from DC to 18MHz.
      75 OHM output impedence for all audio and video outputs.
