SoundGuy
FS: [Relist] Mark Levinson 531H
Price: $12,000 $10,500 $9700
Main Features
Gain 26.8dB
Power Consumption 300W
Width 17.75" (45.1cm)
Depth 19.83" (50.4cm)
Tags: Krell, Mcintosh, audio research, luxman, accuphase, esoteric
ml3.jpg.7871e6d8eee39790410a667d0c837a88.jpgml2.jpg.1d879c364d0b9ce237a8c8144afd41a8.jpgML1.jpg.ce6a6162caf6d5d025c44cf6150a5f51.jpg1086003115_MarkLevinson-1(2).thumb.jpg.5b25eb274554f50037672aa1010b9a05.jpg925874140_MarkLevinson-2(1).thumb.jpg.efc4617e250e944f5389c179d10a9b48.jpg1064134261_MarkLevinson-1(1).jpg.4f49020b404ff710d67a37576b500687.jpg938817766_MarkLevinson-3.jpg.478d0f04072f2db3159109feb5ef9aa7.jpg1352468835_MarkLevinson-4.jpg.ffcfce770282fe5d87900fe6dd99f2cf.jpg110960688_MarkLevinson-2.jpg.bc13d05eceaac69adbc54ce8acf41e5e.jpg793595469_MarkLevinson-5.jpg.7d61300bb2cd288c626a5dd5a56fd411.jpg1852775615_MarkLevinson-1.jpg.241555ee10fd86478aa88c1f4eff7b8b.jpg
If only I had the money to buy these beauties..
If only i had the money to buy the Mark Levinson transportation cases  :D
.......................................................GLWS...........................................................
Edited by Electrovoice Interface.
About the only thing I think I could afford are the speaker outputs - whatever brand they may be.
Absolutely stunning amps !!
GLWTS
Did you buy April this year or April 2018?
GLWS
Sorry. April 2018. They’ve been in their carry case since new. Thanks.
    • By kelossus
      Item: Mcintosh C2300 Tube Preamplifier
      Price: $5000 FIRM - No offers
      Item Condition: Excellent
      Comes with NOS Telefunken ECC83s in the linestage. Factory tubes in the MC/MM phono section. Has the new Mcintosh replacement remote which looks a million times better than the old and the plastic doesn't go sticky.
      IMO the C2300 and C2200 are far better preamps than the newer models.
      I don't have the original box so shipping local pick up only.
      Apologies for the smudges on the glass face plate, these were not visible when I was taking the photos. In near new condition.
      Specifications
      Frequency response: 10Hz to 100kHz
      Total harmonic distortion: 0.08%
      Gain: 60dB (MC), 40dB (MM), 15dB (line)
      Input sensitivity: 0.45mV (MC), 4.5mV (MM), 450mV (line)
      Signal to noise ratio: 80dB (MC), 80dB (MM), 93dB (line)
      Output: 2.5V (Pre out), 8V (Pre out Max)
      Dimensions: 444 x 152 x 457mm
      Weight: 13.41kg
    • By palexsia
      Item Condition: New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Templestowe State: Victoria Payment Method: Cash pickup , eft . Reason for selling: Selling for friend Further information:
       As photo
    • By jakeyb77
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: St Kilda East State: Victoria Payment Method: EFT Cash PayPal (you pay fees) Reason for selling: Too many TT Further information:
      Pictures form the description.
      Plinth has seen better days due to an accident. Just a couple of chips that could be filled and stained again. It’s still a straight plinth.
      This table has been used about 4 hours since I put it together.
      These parts were brand new with 4 hours on them.
      Mober bearing and inner platter and cross brace. Mose PSU. Premotech motor.
      Brand new belt and springs and grommets.
      Old parts- plinth, top plate, sub- chassis and hardware. Linn rubber mat. Linn Masonite base.
      Doesn’t come with arm but I also have a Wand Tonearm for sale. Also have a Zu Audio Denon 103r with less than 300hrs
    • By MGO
      Item Condition: Very good for age: 60 + Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Little Bay State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR Reduced $$$:
      Western Electric 10GA Tinned Copper with Cotton covering.  Twisted Pair Speaker Cable
      The price is for a stereo pair of 3 metres.
      This is the wire Duelund copied "A wire originally born of the desire to improve upon legendary studio vintage cabling."  The legend is this WE cable!
      This is great speaker wire especially for bass and mids.
      It is twice as thick and has 4 times the cross sectional area of the famous WE16GA as featured on Jeff's Place
      https://jeffsplace.positive-feedback.com/the-vintage-beat-western-electric-we16ga-speaker-cable/
      NB. Other lengths available - to be listed.
    • By christos540
      Item Condition: Mint - approx 10 hours listening time Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: PALMVIEW State: Queensland Payment Method: Paypal, Cash on Pickup Reason for selling: Great sound but I have fallen in love with something Hi everyone,
      I'm am selling my new Master & Dynamic MW65 Wireless Headphones. These are in mint condition & they sound great, however there's another set of cans that I have
      fallen in love with, so I am putting these up for sale. Everything is in perfect working order. Comes with original box, packaging, cables etc. They have a great 1970's industrial look to them
      & IMO are a reasonably neutral headphone. Supports AptXHD as well. PRICE is NEGOTIABLE. Specs below.
      MODEL
      MW65
      ACTIVE NOISE-CANCELLING
      Feed-forward and feed-back (hybrid) active noise-cancelling technology
      MATERIALS
      Leather, Anodized Aluminum
      DIMENSIONS
      165mm x 190mm x 66mm
      CABLES
      1.5m Standard 3.5mm Audio Cable, USB-C to USB-C Charging Cable (with USB-A Adapter)
      HEADPHONE CONNECTION
      Optional 3.5mm Passive Audio Input, Two-Prong Flight Adapter
      MICROPHONE TYPE
      Beamforming Noise Reduction Mic Array
      VOICE ASSISTANT
      Google Assistant built-in, voice assistant enabled
      DRIVERS
      40mm Beryllium
      WEIGHT
      245g
      EAR COUPLING
      Over-Ear
      IMPEDENCE
      32 Ohms
      EAR PADS
      Replaceable Lambskin-Wrapped Memory Foam
      BLUETOOTH PROFILE
      Bluetooth 4.2 Supporting AptX, AptX HD and SBC.
