Standards
Sampling rate vs output question
12 hours ago, LHC said:
"Studies cited as contrary evidence did not address the physiological brain response to high-frequency audio, only the subject's conscious response to it." The new 2017 study adds to the 'physiological brain response' evidence,
Yes, I agree, this and other studies combining a behavioral and neurological response suggest perception has occurred. This had previously been demonstrated for "resting" or inactive subjects.
As noted in the 2017 study increased alpha activity is seen during a relaxed attentional state and thought to be a signifier of enhanced processing, and Beta activity has been shown to increase when arousal and vigilance level increase.
Kuribayashi and Nittono (2014)  found that "the difference between full-range and high-cut sounds appeared in the right inferior temporal cortex,  whereas  the main source of the alpha-band activity was located in the parietal-occipital region."
"The finding that the alpha-band activity difference was obtained in specific but not whole regions is suggestive that this increase may reflect an activity related to task performance rather than a global arousal effect (Barry et al.2007)."
In the 2017 study they felt that EEG and Event related potentials supported  high-resolution audio with inaudible high-frequency components "enhances the cortical activity related to the attention allocated to task-relevant stimuli."
