Standards
Sampling rate vs output question
Greetings,
I have trouble getting my head around a particular question regarding sampling rates and how it's able to be output without losing phase information. I have asked this question with speaker companies, electrical engineers and nobody have been able to give me a solid answer. So embarrassingly I am turning to public SNA forums.
So the question is this, how do my speakers render all the phase information in my high-res file if it has a lower frequency response?
For example, I want to play a high-res file at 96khz but my speakers can only go up to 25khz in frequency (so equivalent to 50khz sampling rate). I do this because I want to avoid reconstruction aliasing in my analog signal after it passes through my NOS DAC, and also to preserve the minimum perceivable phase information in my analog output which is about 10 microseconds (with a femtosecond clock, this is easily doable). But given the limitations of my loudspeakers, are the phase information above 25khz freq lost anyway?
To me it seems like manufacturers care about the audible frequency range (20-20) but do not consider our ability to detect phase information that are far smaller. Or do I have this all wrong?
7 minutes ago, furtherpale said:
96khz is the sampling rate, not the frequency output.
Did you read my original post? I know the basics, as I indicated in my post the sampling rate is double of frequency. That wasn't my question.
Edited by Standards
They don't. They can only render whatever frequencies they're capable of rendering. I'm trying to understand exactly what it is you're worried about as they do not alter the phase of higher frequency information, it is usually just dramatically dropped in amplitude proportional to the frequency. Whether rendering ultrasonic frequencies at all alters human perception of sound is a point of great contention itself though, and that's up to you to decide.
Thanks @Ittaku that's the first concrete answer I've ever got, and makes sense to me. Is it also possible that phase information is conveyed differently in loudspeakers since they operate in the analog domain, so an activation (what's the right word here) of the driver diaphram may not line up with a single sample in the digital side, but could possibly activate on a sample above 25khz just because at that precise time, the analog signal is passed to the driver that contain that specific phase wave (if that makes sense).
I'm not talking about ultrasonic frequencies, I'm talking about the audio timing. I agree we cannot hear over 20khz, but we can detect phase information in the microseconds according to Barry Leshowitz. I'm not saying whether he's right or wrong, but iif we can, then what phase information are our speakers rendering or attenuating.
Edited by Standards
I'm not talking about ultrasonic frequencies, I'm talking about the audio timing. I agree we cannot hear over 20khz, but we can detect phase information in the microseconds according to Barry Leshowitz. I'm not saying whether / if we can hear phase information down to 10 microseconds, but iif we can, then what phase information are our speakers rendering or attenuating.
The phase information is all there in the electrical signal. Drivers do not substantially change phase information when rendering it except near their resonant frequency or according to the effects of a crossover. Tweeters especially tend to have almost no phase effect at all after the crossover frequency so they fairly accurately maintain phase. Note that crossovers change phase a minimum of 90 degrees at crossover points and often alternate drivers are connected out of phase completely. Psychoacoustic testing have shown we're not sensitive to the phase doing monstrous changes across the frequency response, except for whether the lowest frequencies are rendered in or out of phase - and even then it's not "better" in phase, we can just tell they're different somehow. Worrying about phase changes with speaker drivers is probably meaningless. Lining up phase between different drivers over the crossover points is very important, but the absolute phase appears not to be.
It seems I asked the question poorly. I'm mainly interested in the drop-off of phase information above 20khz, tweeter only, crossovers are irrelevant.
I think you've answered enough, and I've processed what you've said and I understand it better now. Thank you.
The short answer is "it doesn't".
Your speaker is a band-pass filter.... and so it distorts the audio waveform.
You add filters to the audio to undo that, and so have flat phase response (even though it has a bandpass frequency response) ... but this is not at all straightforward to do - and you will see lots of people over-simplifying the problem/solution.
In fact, if you correct the phase of a speaker incorrectly, it will make it worse..... even though the measurement you will get looks fantastic  (and this the problem in a nutshell, the measurement you used to base the correction on, was misleading).
Quote
The frequency components above 25khz are lost, and the phase is distorted.
As for "timing" (ie. where part of the signal begins/ends), you do not need high sampling rates to capture these.   Even 44.1khz is fine.
However it may be easier to preserve them (ie. not blur them once you've captured them) when using high sampling rates.
Quote
It depends on exactly what you mean by "phase".
You seem to mean where exactly a part of the signal (eg. a short click) occurs in time ..... as opposed to whether signal components at 20Hz, 200Hz, 2khz and 20khz are all in time with each other.
To get the click to occur at just the precise time.....  You do not need high sampling rates.    That is a myth.
However once you have the signal (with it's infinite timing precision) .... then you may damage that precision if you convert it from one rate to another  (and this conversion happens more often than you might expect .... eg. inside a DAC).    So it is often better to make (and keep) audio in high sample rate formats, simply to avoid this conversion.
Edited by davewantsmoore
Thank you for the informative response. I do understand the traditional terminology for phase is the degree of delay between the frequencies but didn't know how best to describe "short click", I generalised it to phase. Is "click" the correct terminology?
The part where you said it's a myth to require high sampling rates to get the click right on the mark, are you able to elaborate further or point me in the direction of reading material? Thank you.
No... I just used "click" to give the impression of a very short pulse, and where it falls in time.
Everything is interrelated... and just different views of the same thing (the signal waveform).
Not in a short post... and not without misleading you (and causing arguments from others who are mislead .... likely by my poor explanation, rather than "facts").
In short.... imagine an analogue signal.    You can have a "spike"  (what I called a "click") occur at any point in time.   Were does it begin in time?  Where does it end in time?    The "time resolution" is infinite, right.   It can start at time = x  .... and you could move the start back or forward in time infinitely small amounts.
Let's say you now captured this with a digital format ... with the sampling rate twice as high [NOTE] as the highest frequency you want to represent.   (eg. 44.1khz for audio frequencies up to ~22khz).
You can represent this infinite time resolution perfectly with your 44.1khz sampling rate.    If you adjust your analogue waveform to move the "click" backwards or forwards in time by one femtosecond .... or 0.0001 femtosecond, whatever....   You are still able to capture the waveform precisely.
People get confused about where the sampling points are (and their finite resolution) ... and the resulting waveform it represents (with it's resulting infinite resolution)
[NOTE]   This bit is important.    When you see people saying what I've said above is incorrect ... what they will do is violate this restriction.    What they're doing is mixing up the arguments about the SHAPE of the waveform ..... and the TIMING (where a part of the waveform begins/ends in time, and how accurately that can be represented).
We're just talking about the TIMING here.    The timing resolution of digital audio is infinite.
Heh.  That was the 'short version'....    ie. it missed out all the justification/explanation required to demonstrate what I said is true.
People will have to figure that out for themselves.
Perhaps you could just link to material that they can peruse.
I'm having trouble wrapping my head around this.
Let's say we are recording a 22.05khz tone, which is the highest frequency which 44.1khz can capture. So there is 22 microseconds per sample. If a click occurs 5 microseconds after a sample, and finishes in 15 microseconds, does this get captured in the digital recording? If so, how is this possible? A click at a duration of 15 microseconds is above the 22.05khz tone.
Even if you say your speakers are spec'd @ 25k, that is usually only 3 db down but your speakers may still be reproducing up to 30k and beyond at an ever reducing rate.
No... because this click is too short.   ie.  it contains higher frequencies than 22khz.   (and we can't hear that fast).
If you instead look at a click which is 22khz .... ie. at minimum (one cycle of 22khz) 45 microseconds long.
Where does it begin on the recording?   It can begin anywhere.... the resolution is infinite.   It could begin at X.... it could begin at X plus 1 microsecond ..... or where ever.
We CAN hear the difference in where the 45us long click occurs in time down to very fine precision..... especially when it is slightly difference between multiple channels.
..... but we cannot hear the high(er) frequency content of the "click".
People routinely mix up the difference.
So we come back to my original point, which was that assuming Leshowitz is correct and that we can indeed hear a 10 microsecond click (not in frequency, but in timing), then a loudspeaker capped at 25khz in frequency response won't be able to fully render the click? Regardless whether the digital side is fed 44.1khz or 96khz.
Again, I'm not saying I'm siding with Leshowiz, only that assuming he is correct in theory, and that I'm understanding his paper correctly.
