DaveH1
FS: Emotiva XDA-1 DAC
Item: Emotiva XDA-1 DAC
Price: $400
Item Condition: Excellent
Reason for selling: Upgraded and no longer required
I purchased this new from Emotiva in around 2012 for my daughter's system.
It's an excellent DAC and pairs well with the XSP-1 which is also for sale at the moment.
Happy to ship at buyer's expense.
Thanks for looking.
Pm sent with offer
Edited by Phil sydney
Its a really nice DAC, I love mine. Has a volume control too so can be used as a digital preamp. GLWS.
I love mine too it sounds especially sweet now that it’s connected to your old XPA-1’s 😉
    • By Famo
      Item: jamo sub for repair or spares
      Price: $25
      Item Condition: Jamo sub needs a new plate amp
      Reason for selling:
      Extra Info: jamo sub, box in very god condition. Plate amp needs repair or replacement
      Photos
    • By caleb
      Item: Mad Scientist Audio BlackPod Mini Tungsten Carbide Audio Footers 3pcs set
      Price: $100 plus $10 post
      Item Condition:7/10(has some scratches and wears on one of the tc ball but works fine)
      Reason for selling:no longer required
      Mad blackpod mini tungsten Carbide for sale in great working condition.I found it great  under sources.
      Exactly the same quality built compared to the standard tc version but in smaller fraction.
      Here's more info and reviews
      http://www.madscientist-audio.com/blackpodmini.html
      http://www.hifi-advice.com/blog/review/accessories-reviews/mad-scientist-audio-blackpods/
    • By SoundGuy
      Price: $12,000 $10,500 $9700
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By mtan002
      Item: Music Appreciation Appreciation 8th Edition + Multimedia Companion V4.5
      Price: $40 + Actual postage
      Item Condition: Used
      Payment Method: Paypal or cash on pickup
      This book is in fair condition with cover and all pages intact.
      The Multimedia Companion is in good condition.
      You pay actual postage based on your location.
    • By Sarenda
      Item:Dali Speakers
      Price: $250
      Item Condition: Working and in OK condition.
      Reason for selling: Too many speakers!!
      Extra Info: I believe these Dali speakers along with magnificent sounding centre channel speaker  were selling for around $1500 plus in it's day.
      A bargain at $250
      Pick up only.
      Cheers.
