Chazz
FS: B&W Nautilus HTM 2 centre channel with dedicated stand
Item:   B&W HTM 2 Centre Channel (B Stock) with dedicated stand
Price:  $500
Item Condition:  Good
Reason for selling:  No longer needed
I bought this a while ago thinking of setting up an all B&W Nautilus 5.1 system but alas that has proven too hard (and expensive to achieve).  So off loading this centre channel.  The tweeter has some creases from being poked and then restored but it still works fine.  This is B Stock so the seems are not absolutely perfect.  However, as you can see from the photos it's hard to tell.
With the dedicated stand this is a bargain price.    Excellent reviews can be found here.
Pick up in Sydney only as I don't have a dedicated box.
http://www.audioreview.com/product/speakers/center-channels/b-and-w/nautilus-htm2.html
    • By sir sanders zingmore
      Item:                          Line Magnetic LM-219IA Integrated Amplifier with upgraded valves (see below).
      Price:                         $4,300 - I think this is a good price given that it includes over $2k worth of valve upgrades and is not a grey import -  genuine Australian import version rated at 240v
      Item Condition:       Excellent
      Reason for selling:  Still too many amps
      Payment Method:  Pickup - Cash, Paypal (buyer pays fee), Bank Transfer
      Extra Info:                This is a genuine Australian 240v version that I bought new from Mcleans Audio in July 2018
      I have upgraded the 845 and the 12AX7 tubes. The originals are included and have very little use.
      The upgraded tubes included are:
      2 pairs of Psvane 845 Western Electric replicas (that's 4 tubes in total). One set has been unused since I bought it here from a fellow SNA member (the photo is from that advert). Two new pairs would set you back about A$2k 1 pair of Sylvania 5751 which I found to be significantly better than the stock 12AX7s
      This thing is a beast (about 70kg packed) so I'd prefer to sell locally.
      I do have the original packaging so if no local interest I will consider shipping at your cost (and risk)
    • By krusto
      Item: Paradigm Monitor 10 Sub
      Price: $600 obo with donation of course
      Item Condition: NR MINT/MINT
      Reason for selling: NLR offloading my subs
      Payment Method: Pickup - Cash, Paypal, Direct Deposit
      Extra Info:  Lightly used for music, very nice, smooth subwoofer. Incredibly small (sealed) cabinet. Not only awesome for musical applications, but deep and powerful enough for any home theatre enthusiast.
      Original box and accessories for safe delivery. Happy to courier if required.
      The amps and drivers in this Monitor range are made in Canada, assembled in China.
      DESIGN Single driver, acoustic suspension, built-in advanced Ultra-Class-D™ amplifier, USB port for PBK equalization, removable grille AMPLIFIER 900 watts Dynamic Peak; 300 watts RMS Sustained AMPLIFIER FEATURES Auto-on/off, soft clipping, thermal protection ROOM CORRECTION Anthem Room Correction (ARC®) (sold separately) LOW FREQUENCY DRIVER 254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex® spider, 4.5 lb ferrite magnet, AVS™ die-cast heatsink chassis FINISHES Black Ash WEIGHT 30 lbs. (13.6 kg) DIMENSIONS HXWXD 13" × 11.125" × 12.75" (33.0cm × 28.3cm × 32.4cm) LOW FREQUENCY EXTENSION 17 Hz (DIN) LOW PASS FILTER FREQUENCY Variable 35 Hz - 150 Hz; Bypass Option SUB / SAT PHASE ALIGNMENT Variable 0° - 180° INPUTS Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source COMPATIBLE PRODUCTS PT-2 Wireless Transmitter (sold separately)
    • By sfdoddsy
      Item: 2 x Paradigm PW Power amps, 1 x PW Link Preamp
      Price: $250 each, $200 for the PW Link
      Item Condition: PW AMPs mint, PW Link used
      Reason for selling: Drunk eBay bidding
    • By mpearce38
      Item: Devialet Expert 120 Integrated Amplifier (with preamp Board Installed)
      Price: $3100
      Item Condition: 8/10 - Fully functioning, Complete packaging, light swirls on surface hence rating 8/10
      Reason for selling: Insanity
      Extra Info: I bought this amp last week of fellow SNA member to power my PMCs. I really enjoy this amp but for multiple reasons have decided to let it go
      The Good
      - Sound quality Clarity and Detail - Wow believe all the reviews this amp is transparent and detailed. There is none of the "vailed" effect you get from other amps. Had me listening to all my old songs and hearing things i didn't notice before.
      -Power - Class A and Class D = SPL even though it is the baby of the range to drives my PMC 25.23 with ease. I suggest any stand-mount or small / medium floor stander would not be an issue.
      - Configurability -  Multiple set ups can be created and saved via the online configuration tool and loaded onto an SD card
      - Build quality and design- Seriously solid piece of kit, all hardware is highest quality and has plenty of wow factor
      The Bad
      -While the configurability is good, it does mean you need to tinker with this amp to get the best out of it, great if you have plenty of time but for me with 2 kids and a demanding job I don't really have the time to tinker with SAM settings, crossovers, firmware versions, power options etc.
      - Can only connect 1 analogue input. I use my amp for 50% music / 50% HT so need to have my AVR connected via HT bypass, this means I can't connect my external DAC or a turntable if I wanted. I have it installed in a AV cabinet so difficult to get round the back and pull out chords
      - Cant see the display when i have it sitting in a normal cabinet, not a big issue but a little annoying
      - Fingerprints - I have a teenage son who also loves music and while he is very respectful of my gear he has teenage fingers that are constantly leaving marks on the unit and remote
      So while I would love to keep this amp for its sound quality and wow factor it just is not the best fit for my lifestyle, Hoping I can recover what I paid and as this is the cheapest devialet in Australia right now and they don't come up very often price as firm.
       Happy to demo if your in Melbourne,  have all original packaging so happy to also post interstate at buyers cost.
      I may be interested in a trade to Bryston B135 SST2 / 3
    • By gwurb
      Item: ACOUSTIC ENERGY AE301 Bookshelf Speakers
      Price: $400 (price drop)
      Reason for selling: Too many bookshelf speakers
      I really enjoyed these speakers. Have had them for a couple of years. They are lovely to listen to and have good amount of bottom range for such a small speaker.
      Bookshelf speakers been replaced with floor standers and they are no longer needed. They have superficial scratches on the surfaces. They are only apparently with bright light, and up close. As you can see in the photos they they are not apparently from most angles.
      A review: https://www.whathifi.com/acoustic-energy/301/review
      Happy to post. I estimate it would be approximately $45, but would depend on location.
      Type: 2-way reflex slot-loaded
      HF Driver: 28mm custom AE design fabric dome
      LF/MF Driver: 110mm spun, hard-anodised aluminium cone
      Cabinet: Braced 18mm MDF carcass
      Frequency Response: 48Hz – 32kHz +/- 3dB
      Power Handling: 150 watts RMS
      Amplifier Compatibility: 25-150 watts into 8 Ohms (recommended)
      Nominal Impedance: 8 Ohms (6 Ohm minimum)
      Sensitivity: 87dB for 1 watt at 1 metre
      Dimensions: 300 x 185 x 250mm (HxWxD)
      Weight: 5.5kg (single speaker, unpacked)
