Heifetz
loctite thread locker; Furutech nano-liquid orGraig G100
Can anyone suggest where I can get a loctite thread locker and Furutech nano-liquid (or Graig G100) or good alternatives?
Thx,
Thank you!
Happy Listening.
Wow!
That nano-liquid is expensive.
Is there an alternative?
2 hours ago, Heifetz said:
Thx,
Plenty of options for sourcing Caig DeOxit G100 including:
https://www.ebay.com.au/itm/DeoxIT-GOLD-G100L-Squeeze-Tube-100-solution-2-mL/401602406241?epid=12023992217&hash=item5d815e6761:g:xDkAAOxyCGNTLf9~&frcectupt=true
https://www.ebay.com.au/itm/DeoxIT-D100L-G100L-liquid-1-6ml-100-solution-Brush-Applicator/362440232812?epid=6024006342&hash=item54631f0f6c:g:GJAAAOSwFNZWxRiF
Depends how much you require quantity-wise, but I'd suggest that a few mLs will go a long way for a casual domestic user.
Most industrial supplies shops sell Loctite.
You could probably borrow someones' nail varnish which would do the same job!
Pretty much!
And I've used PVA glue when I've wanted to use this.  Don't know how it compares to Loctite; I'm just guessing that it would have an adhesive bond that would prevent loosening, but could be overpowered by a screwdriver if required.
Thank you for your suggestions.
I notice that the Craig Deoxit G100 is often described on Rbay as "Caig". It is misspelt.
Is this the same product or some devious way of trying to con us into buying something else?
Thx
Thx
“Caig” is the correct spelling.
Ok, then I am the mis-speller!
🙄Thx
Hey!
I found Caig DeOxit G100 at Jaycar!😁
Thx
🙄Thx
Not just Caig.... :na:
