Josh Ballard
Richter Wizards MK1
Item: Richter Wizards MK1 speakers
Price: 250
Item Condition: Used, Good 6/10
Reason for selling: Not Used
Awesome speakers if you like rock music. Decent condition. All drivers work flawlessly. A few cosmetic issues could possibly be cleaned up.
Would be perfect for someone who lives richters.
Brings back memories from long ago...
    • By Machina
      Item: 1
      Price: 400
      Item Condition: Very Good
      Reason for selling: Not using
      Grandview 16:9 115 inch Fixed wall screen with bracket Good condition no damage to screen. Black felt boarder has few marks. Easily assembled. Pick up only.
    • By Ewok209
      Item: xDuoo TA-01
      Price: $85 + $15 postage
      Item Condition: Good used condition
      I purchased this dac/amp to use with my Beyerdynamic DT990 but I'm heading back towards IEMs.  The blue LED power light no longer works but fully functional otherwise.  The sound is quite mature and detailed, has a nice vibe , separation, layering and soundstage are all impressive for its price point.  You can tube roll if you like (included tube is Electro Harmonics) it uses dual Wolfson DACs, the RCA  on the back doubles as an input/output when no USB cable is plugged in so you can use the unit as a DAC or stand alone headphone amp.
      Included is the dac/amp, power supply and USB cable.
      Specs:
      Aluminum chassis Dual Wolfson WM8470 DAC chips XMOS USB chip Supports up to 192 kHz/24-bit playback Asynchronous USB 2.0 transmission 12AU7 tube Transistors for class-A buffer Supports ASIO, KS, and WASAPI modes Inputs: USB 2.0, RCA (L, R) Output: ¼ in (6.3 mm) headphone jack, RCA (L, R) Operating voltage: DC 12 V Frequency response: AMP 10 Hz – 100 kHz +/- 0.5 dB; USB 20 Hz – 20 kHz +/- 0.5 dB USB sample rate: 16 – 24 bit; 44.1, 48, 88.2, 96, 176.4, 192 kHz Distortion: 0.03% (1 kHz) Output power: 2100 mW (32-ohm load) Gain: +6 / +17 dB Crosstalk: 110 dB Impedance: 16 – 600 ohm Dimensions: 5.5 x 3.2 x 3.2 in (14 x 8 x 8.2 cm) Weight: 14.5 oz (410 g)
    • By Bengineer
      Item: JDS Element Headphone DAC & Amp
      Price: $300 pu/pp
      Item Condition: Real good. 2 years old.
      Reason for selling: Upgraded
      Bought August 2017 direct from JDS. It has the Australian adapter, ring colour is red (thin part around the knob)
      Has USB in. RCA in. RCA out. High/Low Gain toggle. Accepts 6.5mm single ended.
    • By hugomac
      Item: Mark Levinson No.27 ***PRICE REDUCTION***
      Price: $3600
      Item Condition: Excellent
      Extra Info: Recently spent over $2000 fully restoring this superb ML Amplifier, work carried out by Sydney Mark Levinson dealer, over 20 Capacitors replaced. Sounds absolutely sublime better than current ML Amps. Upgraded to BAT VK655SE.
    • By audiodyna
      Item: (1) Purist Audio Maximus RCA interconnect, (2) Apogee Electronic A-110 XLR interconnect, (3) XLO Type 2 Reference XLR Interconnect
      Price: (1) $400.00 , (2) $350.00, (3) $350.00.00 (Postage not included)
      Item Condition: (1) 7/10, (2) 8/10, (3) 9/10
      Reason for selling: NLR
      Extra Info: All these cables are 1.5 meter in length, in good working condition as been shown in photos.
      (1) Purist Audio Maximus interconnect cable was originally filled with oil/fluid inside the shielded tube when new, but has dried up now.
      It will be sold as it is.
      (2) Apogee Electronic is famous for its digital equipment like DAC and cables which are normally used in recording studio, not the same company as the one manufacturing speaker.
      (3) XLO type 2 Reference Series XLR interconnect cable are very fast and dynamic, suitable for valve system.
      All these cable do not have original packing box but will be packed with extra care if transportation to other states is required.
