Cybrarian
WTB: Gryphon Audio | Diablo 120
Item: Gryphon Audio Diablo 120
Price Range: $7K
Item Condition: New or Used
Extra Info: Diablo 120
    • By petng
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Keilor State: Victoria Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR Further information: Second owner. Comes with factory double box. No remote . I can obtain a remote control unit for $650
      There is a slight dent on righthand side.
      https://www.the-ear.net/review-hardware/spec-rsa-m3ex-integrated-amplifier#:~:text=I missed power%2C speed and,the midrange and thus voices.
      https://www.soundstageaustralia.com/index.php/reviews/83-spec-corporation-rsa-m3ex-integrated-amplifier
      http://www.positive-feedback.com/Issue78/spec_realsound.htm
      https://rognlien.wordpress.com/2019/02/04/spec-me-up/
    • By PKay
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Artarmon or Forestiville State: New South Wales Payment Method: cash or paypal Reason for selling: NLR Further information:  I am selling this amp for my brother - it is in excellent condition with very little use. Postage is available as my brother has the original boxes but local pick up is preferred.  See 3rd picture for little mark which is hardly visible.
       Review from TNT
      There has always been an inherent rightness about the idea of an integrated amplifier. The efficiencies are impressive, the compromises mostly imagined. With the modern additions of display and a properly implemented remote control the integrated becomes all the more appealing. Now there are integrated and then there are integrateds: The sometimes classic (Naim) and sometimes overrated (fill in the blank) British offerings are not what I have in mind. For some reason, the Brits just don't seem to get the fact that an integrated needs real world power to be of real world use. Rotel is a company that knows how build high powered amplifiers, so when I found out that their flagship RA-1070 was said to be happy driving a tough 4 ohm load, I was quick to request a sample.
      The RA-1070 is the latest in a spate of offerings wherein the product's look and performance really threaten a redefining of the high end. There was a time when such a product would have cost well over $2000. While the old guard high end companies have product lines that continually reach higher and higher, the larger mid-level companies seem willing and able to supply more music for the dollar. It may be time to ask why...
      This is a very attractive piece of gear. My review sample is silver and black, but the 1070 can also be had in the more traditional all black. The faceplate of the unit is cleverly designed to suggest a more hefty look through the use of substantial black aluminum handles. In fact, the silver center section of the face is quite thin (as is the top cover) yet the unit looks and feels quite solid. A large motor-driven volume pot dominates the face. When operational, there's an illuminated section that indicates its relative rotational position. In an interesting nod to the days of tone & loudness controls, there's a four position contour control which allows for accentuation and attenuation of bass and treble. I left that control in the off position for all of the evaluation period. The rear panel is well laid out with proper 5-way binding posts situated near the center of the panel making it easy to connect even the most unwieldy cables. The usual IEC 320 connector is used, but in an odd twist, this Rotel floats the ground: This is very likely of no concern in typical use, but could be an issue in systems requiring a specific grounding scheme or extensive use of truly balanced devices.
      The RA-1070 uses a relay as a turn-on/off stabilization device and also as a protection device in case of overheating or shorted cables. The relay can be clearly heard when powering the unit up and down. With the exception of the speaker and contour control switches, all of the RA-1070's functions can be controlled by the superb remote. This is truly a wonderful remote...it can readily learn the remote codes for all of your other gear and allows you to use the Rotel remote to control an entire system. It is also possible to customize the unit's display to indicate associated equipment by specific name rather than type. The only negative that I should mention is that while it is possible to turn the somewhat bright display off, the unit isn't designed to remember that setting. So, the very next time the Rotel is turned on the display again needs to be turned off. This is a real shame as the display off setting is very well implemented. With the display in the off position, the display momentarily illuminates whenever a control is changed. Once the change is complete the display goes out. On a teeny-tiny but slightly tacky note: The motorized volume pot indicates that the RA-1070 is in mute by flashing its position indicator. While effective, I find this solution better suited to products of a lesser pedigree than Rotel.
      Sound
      The Rotel RA-1070 is a very suave sounding piece of gear. Right out of box it has a sound that is relaxed and assured. There are absolutely no hi-fi dramatics to this amp just a competent and musical presentation. The unit looks like it sounds like it functions...sensibly, controlled and without fanfare. The essential test of tone and timber that I like to use first is the Byron Janis. The piano is clear and open with a slightly soft presentation. It is less than muted but less authoritative than it should be. Overall tonality is quite good bordering on excellent. At well over 100 watts into 8 and 4 ohm loads, it sounds even more powerful in use than the ratings would indicate.
      Iris DeMent's voice is possessed of its usual plaintive clarity if again just slightly softened. There was no aspect of the voice's fundamental or attack that was lacking but rather a subtle sense of shading toward the warm and dark. Now, on the period strings of the Corelli, the sound was quite open and pure with an excellent sense of space and air. The guitars of Krushevo were also recreated with an appropriate portrayal of acoustic speed and timbre.
      It is sometimes possible to go too far in one direction and I felt that the Rotel RA-1070 was less prone to this softening when used with my usual digital reference rather than the also excellent RCD1070. It may be that my system's overall resolution requires just a bit more raw musical information that the Rotel combination can create. More than anything, this is likely to be a matter of personal preference and perhaps most importantly the room/system interface. In any event, I appreciate the RA-1070 more when using my reference digital rig and analog.
      Ah, analog
      I will rue the day that there are no more phono stages. One of the most appealing qualities of the Rotel RA-1070 is its lovely phono stage. It is really quite excellent. The Sonny Landreth pressing quickly reveals the essence of a phono stage. First of all, it is dead silent. A noisy phono stage will overlay a hum over the blackness of the virgin vinyl. The phono stage of the 1070 is fully capable of differentiating a good pressing from one made from old combs. The Landreth LP has some wild dynamic swings from cut to cut. The Rotel really handles the range with aplomb. In contrast to the linestage's less assertive style, the phono stage of the 1070 is incisive and full of verve.
      As I got the Rotel RA-1070 ready for the return trip to Rotel, I had to make my system ready for some fairly large, typically high end separates. I was miserable. Not only was I going to miss the functional simplicity of the Rotel and its remote I was already missing the elegance of having all of the voltage gain and current swing in one box. Here I was on my hands and knees looking for interconnects and power cords while trying to fit the new separates into the swollen component rack. There, on the floor, the Rotel RA-1070 was staring at me as if to say, there is an easier way!
      There's just no arguing the fact that using an integrated amplifier makes for a more simple system. What the Rotel RA-1070 proves is that such convenience does not have to come with an unbearable loss of musicality. The 1070 is comfortable with tough loads and very easy to listen to and there is just no way to complain about its design and functionality. Maybe someday I will retire from reviewing. When I do, it will hopefully be an easier and simpler time...a time, I hope, of music. When that day comes it would be a pleasure to spend my time listening to the Rotel RA-1070, the bother and hassle of separate components just a distant memory. Until then, I trust that you'll get out and try to hear the 1070. You may find that the simple life of the Rotel RA-1070 is for you. Highly recommended.
      © Copyright 2003 M. L. Gneier - https://www.tnt-audio.com
      HTML by: Andrea De Marco
      SPECS
      AUDIO
      Response Bandwidth 4 - 100000 Hz Signal-To-Noise Ratio 102 dB Total Harmonic Distortion 0.03 % AUDIO SYSTEM
      Type amplifier Subcategory audio components Functions amplifier Sound Output Mode stereo Additional Features A/B/A+B speaker switch Tone Control Yes POWER DEVICE
      Power Consumption Operational 400 Watt HEADER
      Brand Rotel Product Line Rotel Model RA-1070 Packaged Quantity 1 BUILT-IN DISPLAY
      Type fluorescent MISCELLANEOUS
      Color black Color Category black AMPLIFIER
      Input Impedance 33 KOhm Input Sensitivity 1.5 V AMPLIFIER OUTPUT DETAILS
      Output Power / Channel 100 Watt Output Impedance / Channel 8 Ohm Frequency Response 20 - 20000 Hz Total Harmonic Distortion (THD) 0.03 % Channel Type main Channel Qty 2 INPUTS & OUTPUTS
      Headphone Jack Yes REMOTE CONTROL
      Type universal remote control Remote Control Technology infrared ACCESSORIES
      Remote Control Type Universal remote control - infrared Features LCD display, learning AUDIO SPECIFICATIONS
      Type Amplifier Frequency Response 4 - 100000 Hz Signal-To-Noise Ratio 102 dB POWER
      Form Factor internal BATTERY / POWER
      Type power supply CONNECTIONS
      Qty 1, 2, 3, 4, 7 Type audio line-in, audio line-out, headphones, network, phono input, preamplifier out, remote control, speakers output, trigger Connector Type RCA x 2, RJ-45, banana/spade x 2, phone stereo 6.3 mm Connector Location front, rear DIMENSIONS & WEIGHT
      Width 16.9 in Depth 14.2 in Height 4.8 in Weight 22.71 lbs GENERAL
      Manufacturer Rotel of America
    • By emulator
      Item Condition: Very Good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Inner West Sydney State: New South Wales Payment Method: Paypal, EFT, COD, Reason for selling: No longer needed / upgraded Plessis Audio S1 integrated amp in excellent condition. Bought new from Len Wallis Audio in 2017.
      The S1 came about as a joint effort between Charl Du Plessis and his manufacturing partner in China. The design brief was to come up with an amplifier that delivered great sound quality at a really good price.
      I recommend this amp as an introduction to audiophile grade hi-fi and in my own blind listening tests with various speakers in a listening room easily goes toe to toe with amps well over twice its RRP. Paired with a streaming solution like Yamaha's MusicCast boxes, it will do everything you need.
      Weighing in at 10kg, the result is a fantastic sounding minimalist amp that delivers 80 watts RMS into 8 ohms and 130 watts into a 4 ohm load. The only controls are a wonderfully smooth motorised volume control, input selection (from front panel only), mute. A baby remote and bonus headphone out. Lovely sounding and was enjoyed in my system. Has a slightly warm tone, excellent drive, and presents a nice amount of detail.
      Physically, there's a few light scratches and a slight bit of discolouration on the top of the case where the significant other placed something that stuck to the case, and she used some solvent to remove the residue.
      More info here:
      http://www.homeentertainment.com.au/plessis.html
      https://lenwallisaudio.com/products/hifi/amplifiers/s1-integrated-amplifier/
    • By stretch2002
      Item Condition: Excellent, a few small marks on top cover Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Canberra State: Australian Capital Territory Payment Method: Paypal, EFT Reason for selling: No longer required, getting into components. Further information: Price reduced.
      Great sounding British amp, 60W per channel into 8ohms.
      This model released in 2010. Recently serviced (this month), all tested OK.
      I love it, but am getting into separate components, and need to free up funds to upgrade!
    • By Marc
      Item Condition: As new, with all packaging. Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Sunbury State: Victoria Payment Method: Paypal (+fees), Cash on Pickup, EFT, Credit Card (+ fees) Reason for selling: Not a great match for JBL L100 Further information:  Selling my MA252 which has only been used for a few months, and then, maybe only half a dozen short times. It's as new, with all packaging and accessories.
      Although highly regarded, it just doesn't match up with the JBL L100 in my 2nd system. So I'm going try a few other amps to see what gels.
      Current RRP is $7,995. I can ship this via Couriers Please at buyers cost.
