Krispy Audio
Shunyata power conditioner tested
An interesting test we just performed with our Shunyata AU-8 power conditioner! Remember not all power conditioners are equal, and some we have tested actually doubled the distortion on the mains! This is why we use and recommend Shunyata.
Not working mate.
works fine for me, if linking to Instagram is the purpose.
quite a difference on the measured noise
16 minutes ago, deafenears said:
What cable is being used? Is that one of the newer NR products?
It's not the cable here that's making the difference, it's the power conditioner.
If it's the NR cables with built-in filters in the IEC connectors, then it's also helping here...
Fair enough, and you're right, it looks like this guy in the picture:
https://krispyaudio.com.au/products/shunyata-research-delta-nr-noise-reducing-power-cable.html
Which guy?
Just now, Assisi said:
Which guy?
The cable...
Just now, Ittaku said:
The cable...
Understood.  I thought that you may have been talking about a person
John
D is right, the cable is helping here as well. I'm going to make a link cable so I can measure the noise reduction of the actual cables.
The entire Shunyata power cable range have NR (noise-reduction) built in (except the narrow-fit versions of them). So even if you already have a power conditioner you are happy with, a Shunyata feed cable could also be a consideration.
"The Delta NR in Shunyata Research’s NR Series power cables incorporates ‘on-board CCI™ filters’ that provide power conditioning to each individual component." https://shunyata.com/products/power-cables/nr-series-power-cables/delta-nr/
Regardless, that’s an extremely noisily power supply to start with, I’ve used one of those meters, never seen it max out like that.
I agree. But don't forget this is in our shop, a commercial premises. It's not nearly as bad at home :)
Do you have an isotek conditioner there for comparison?
Rather than having to make something up a simpler test might simply be to swap out the Shunyata for a kettle cord into the conditioner then the difference in measurement should be the Shunyata's contribution.
Then if you want you can then cut up the kettle cord... :ohmy: and show the punters exactly what's in or rather how little is in a kettle cord !! :D
How do you find the Shunyata Conditioner when used with power amps?
I know some conditioners and regenerators result in a loss of dynamics.
What would be your recommendation here?
I don't have an open IsoTek here to test but will do so when I get a chance.
I could do that with a kettle cable but if I make an adaptor cable I can also use a kettle cable for a baseline. The adaptor is handy because I can test just the cable itself. It's great to be able to see (as well as hear) the results for this stuff. Also the Shunyata has a C19 input.
One of Shunyata's long-standing point of difference has been the non-current limiting design, and because of that I've never experienced any loss of dynamics. Their current capabilities are not hindered by high impedance electronic filtering.
I've got access to multiple conditioning brands, but choose Shunyata for the reference system here.
Edited by Krispy Audio
18 hours ago, Sir Sanders Zingmore said:
The cable guy 😀
Well Trevor it wasn't obvious to me.  Silly silly me.  I am not good at things cryptic like you are maybe.
I will just have to do better.
John
John
I wasn’t having a go. Apologies if it came across that way
Hi Trevor,
To me you can come across sometimes as a bit cryptic or enigmatic which I can perceive as you having a subtle go.  It is difficult to then work out whether it is intentional or not so.
Mixing up cables and guys seemed to be about animate with the inanimate which was confusing for literal me.
Apologies accepted.
John
Trevor is one of the straightest shooters here.
Not the best choice of words I would suggest even if they were meant figuratively which I expect they were.
Would be nice to show how much of a reduction each one does - AU8 on it's own, the Delta NR cable on it's own.
I have been using the Shunyata AU-8 and 3 Shunyata Delta NR power cords for well over 12 months in my system. Fantastic products and at the cutting edge of power conditioning.
