olegau
FS: Audio Note OTO SE tube integrated amplifier
Item: Audio Note OTO SE tube integrated amplifier
Price:
1900
Item Condition:good working order
Reason for selling:
too many amps
The item is in good working order and condition.  The amp recently was Refurbished. All capacitors  were checked to meet requirements.
This is a Class A amplifier. Output tubes 4 x EL84 (6P14P,  etc), 10 watts per channel.
All four EL84 tubes of power amp are new.
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
    • By bdavis84
      Item: KRIX Concentrix Centre Speaker
      Price: $220
      Extra Info: Great Australian made centre speaker. Barely used over the past 5 years.
    • By bdavis84
      Price: $220
