Sound Gallery Posted August 9, 2019 Share Posted August 9, 2019 (edited) SOLD Item: Denon Flagship AV Receiver AVR-X7200WA Location: Melbourne Price: SOLD including freight anywhere in Australia. RRP $5499 Item Condition: perfect condition, comes with original remote, manual, power cord, unused mic, unused mic stand and antenna. Don't have original box be will be well packed for delivery if needed. Reason for selling: NLR Payment Method: Pickup or deliver at cost - Direct Deposit, Cash or Paypal + charges. Extra Info: Below info taken from Denon Website: Note this is the AVR-X7200WA and not the AVR-X7200W. AVR-X7200WA 9x 210W Full 4K Ultra HD Network A/V Receiver with Wi-Fi, Bluetooth and unique D.D.S.C.-HD32 Features - AVR-X7200WA Welcome the new leader of the 2014-2015 Denon AVR range. Featuring ultimate build quality with a left/right-separated monolithic amplifier design and custom made DHCT (Denon High Current Transistors), the AVR-X7200WA guarantees best-in-class sound quality with minimum interferences. Thanks to built-in Wi-Fi and Bluetooth, it is perfectly set for all network services including Spotify Connect, AirPlay, Network Music Streaming and Internet Radio. Via its 8 HDMI inputs (including one on the front panel) it handles 4k 60Hz pass through playfully, and even upscales video to 1080p and 4k 60Hz. All HDMI feature full HDCP 2.2 compatibility with HDR – High Dynamic Range – and extended colour space BT.2020. Now add brandnew Dolby Atmos, triple HDMI outputs with multi-source/multizone functionality and integrated Audyssey MultEQ XT32/Sub EQ HT/LFC to guarantee the ideal calibration of your setup. The unique Denon Link HD function, guaranteeing the ultimate in entertainment pleasure works in combination with AL32 Processing Multi Channel and DDSC-HD32 for higher resolution audio playback. All sums up to the most comprehensive AVR experience we are pleased to offer. Multiroom / Multisource The AVR-X7200WA lets you enjoy a program source in the Main Zone (the room where the AVR-X7200WA is located) and in Zone 2 and Zone 3. The source can be the same for all zones, or you can enjoy different sources in those zones if you prefer. The sources for the zones can be either analogue or 2 channel digital PCM sources (incl. optical, coaxial, HDMI and network). Easy To Setup, Easy To Use Denon’s exclusive Setup Assistant, along with our Quick Start guide, will have your system properly connected and configured quickly and easily, so you can start enjoying superb home theater surround sound with a minimum of fuss and bother. The Setup Assistant features clear on-screen graphics and text that quickly and easily guide you through the setup process, optimizing critical system settings for the best possible sound quality. Powerful 9 Channel Discrete Amplifier with Eco Mode With each channel rated at a maximum power of 210 watts, the AVR-X7200WA features a left/right-separated monolithic power amplifier design with Denon custom made transistors and identical circuit topology on all 9 channels. Our new Eco Mode provides the ability to reduce overall power consumption and features an on-screen Eco Meter that lets you see the power consumption reduction effect. The Auto Eco mode automatically switches between normal and Eco modes, depending on the volume level chosen, and the power amplifier block is rated to drive low impedance speaker loads, down to 4 ohms, for compatibility and stability with virtually any loudspeaker model. Audyssey MultEQ-XT32 / LFC It is the most accurate room correction solution with more than ten thousand individual control points allowing finer details of the room’s problems to be captured and corrected. The ultra high resolution filters are applied to all channels including the two independent subwoofers, with the most obvious benefit being heard in the low frequency range where correction is needed the most. Audyssey LFC uses psychoacoustic algorithms to prevent bass from passing your walls and disturbing your neighbours while maintaining the bass performance in the listening room. The AVR-X7200WA is also Audyssey Pro ready for the most advanced professional room correction. Dolby Atmos With Dolby Atmos, sound comes alive from all directions, including overhead, to fill the home theater with astonishing clarity, power, detail, and depth. The AVR-X7200WA has the processing power to run a more enveloping, Audyssey MultEQ XT32 calibrated 7, 9 or 11 channel Dolby Atmos layout using 5.1.2, 5.1.4, 7.1.2, 7.1.4* or 9.1.2* configurations utilizing ceiling mounted, or Dolby Atmos-enabled speakers. A 5.1.2 speaker configuration is based upon a traditional 5.1 speaker layout complemented by 2 overhead or Dolby Atmos-enabled speakers. A 5.1.4 configuration is based on a 5.1 speaker layout with 4 overhead, or Dolby Atmos-enabled speakers. A 7.1.2 or 7.1.4 configuration is based on a 7.1 speaker layout with 4 overhead, or Dolby Atmos-enabled speakers. A 9.1.2 configuration is based on a 9.1 speaker layout with 2 overhead speakers. (* with additional power amplifier). Built-in Bluetooth, Built-in Wi-Fi and AirPlay, DLNA Many portable devices are equipped with Bluetooth wireless connectivity, and the AVR-X7200WA’s built-in Bluetooth wireless technology lets you stream your favourite audio tracks from up to 8 Bluetooth enabled devices, such as smartphones, portable audio players and tablets. With the built-in Wi-Fi wireless technology, the AVR-X7200WA connects to the internet through your home network, opening up a world of music from internet radio stations, as well as streaming subscription service Spotify via very latest Spotify Connect scheme. With AirPlay, you can enjoy listening to your tracks wirelessly from your portable iOS device, including iPhone, iPod touch, and iPad. DLNA 1.5 certification lets you connect to your PC or Mac via your home network wirelessly for additional streaming capabilities. Our Denon Remote App lets you easily control the AVR-X7200WA with your portable device, and is available for Apple and Android devices as well as the Kindle Fire. Dolby Atmos Built-In; DTS:X Ready Dolby's new Atmos surround sound technology dispenses with channel-based coding in favor of more advanced object-based coding, giving the sound designer the ability to precisely place sounds anywhere in the 3-dimensional space. Now, you can enjoy this same award-winning technology at home with the AVR-X7200WA, which features the ability to connect a 5.1 surround sound speaker system and 4 additional overhead speakers or 4 additional Dolby Atmos elevation speakers for the ultimate home theater experience. Thanks to the 11ch processing capability, you can just add an external 2-channel amplifier and even enjoy a thrilling 7.1.4 or 9.1.2 channel Atmos experience. Along with Dolby Atmos decoding and Dolby Surround Upmixing, the AVR-X7200WA also features Dolby TrueHD lossless decoding and other Dolby Digital technologies. The latest immersive surround sound system, DTS:X, features object-based audio coding that lets the sound designer place sonic elements anywhere in the 3D acoustic soundspace, and provides for overhead speakers to deliver a stunning surround sound experience, and the AVR-X7200WA also features DTS-HD Master Audio and other DTS technologies. DTS:X and DTS Neural:X Upmixer will be enabled through a future online firmware update. For more info, please visit www.denon.com/dtsx. Equipped with 7+1 input and 2+1 output with HDCP2.2 HDMI terminals that fully support next-generation 4K displays Eight systems are provided for the 4K video signal supporting HDMI input. One of these systems is located at the front so that you can easily enjoy video from a movie camcorder, game console, or smart phone. The HDMI output has a new terminal for zone output in addition to 2 systems capable of simultaneous output to allow the HDMI input video and audio to be output to a sub-zone. The AVR-X7200WA also features full HDCP 2.2 compatibility, a requirement for 4K Ultra HD copy-protected content. In addition HDR – High Dynamic Range – and extended colour space by standard BT.2020 are supported. General Spec Brand Denon RMS Power (watts) 150 Watts Frequency Response 10 Hz - 100 kHz Watts RMS per Channel (6 Ω) 210 Watts Watts RMS per Channel (8 Ω) 150 Watts AirPlay Yes App Remote Control Yes Bluetooth® Technology Yes On-Screen Display Yes HDMI Standby Pass-through Yes 4K Ultra HD Pass Through Yes Internet-ready Yes USB port for iPod/iPhone Yes Room Calibration & Speaker Optimisation Yes FM Yes AM Yes Digital to Analogue Converter 192 kHz / 32-bit Supported Cloud Services Spotify Connect, TuneIn Supported File Formats MP3, WMA, AAC, ALAC, FLAC, WAV, DSD, AIFF DLNA Certified Yes AV Receiver Speaker Channels 9.2 Channel Input Sensitivity 200 mV Input Impedance 47 kΩ Signal-to-Noise Ratio 102 dB Standby Power Consumption 0.1 Watts Warranty Australian Manufacturer Warranty Dimension Product Dimension (H×W×D) 196 x 434 x 427 mm Product Weight 17.8 Kg Edited August 12, 2019 by Sound Gallery Link to comment Share on other sites More sharing options...
Roo2 Posted August 10, 2019 Share Posted August 10, 2019 @Sound Gallery Hi, my name is Bob. Is the Denon receiver AVR-7200WA still available for sale? I live on the NSW Mid North Coast in Harrington 2427. Link to comment Share on other sites More sharing options...
JDab Posted August 11, 2019 Share Posted August 11, 2019 @Sound Gallery Hi, I'm also interested, if it's still available that is. Jake from Perth, WA Link to comment Share on other sites More sharing options...
wolster Posted August 11, 2019 Share Posted August 11, 2019 @Roo2 and @JDab Please note that I have removed your email addresses from your posts, as per our guidelines and to protect your privacy. I am sure that Sound Gallery will be in touch using our personal message (PM) system. Link to comment Share on other sites More sharing options...
Sound Gallery Posted August 11, 2019 Author Share Posted August 11, 2019 On hold for @Roo2 for now. Sorry @JDab Thanks @wolster Link to comment Share on other sites More sharing options...
