Rolland
FS: Mirage MM6 powered Subwoofer
Item: Mirage MM6 powered Subwoofer
Price: 150
Item Condition: Good
Reason for selling: upgraded
Payment Method: Pickup only
 This little Subwoofer is in good condition, punches well above it's weight, features a powerful 6.5" front firing Subwoofer driver with two 6.5" radiators to give that little bit of extra low extension. It also features proprietary "wa port" which allows you to use a Klipsch wireless kit "wa2 kit" with this subwoofer for wireless flexibility. Advertisements without photos of the actual item will not be approved.
Edited by Rolland
    • By Keith Raufer
      Item: 18” Subwoofers, Dayton UM18, Sealed Black Oak Enclosures.
      Price: $1400 each
      Item Condition: 6 months old
      Reason for selling: Need Room
      Extra Info: I have 2 Dayton Ultimax UM18 Subwoofers, (subs only, no amp). Finished in a custom 4 cubic feet enclosure, made from 25mm MDF and very heavily braced. The Subs weigh in at just over 50kg each and are wrapped in a black oak veneer. Connections are speakon for simple secure connections.
    • By kurof
      Item: svs pb12 plus subwoofer
      Price: 1100 ono
      Item Condition: great
      Reason for selling: downsizing, nlr
      Payment Method: Pickup - Cash, Paypal, +3% COD Only
      No introduction needed, this is a beast subwoofer, extremely well built and versatile it can work as ported or sealed, lots of power to shake the entire building.. Final subwoofer for many systems.
      Regretful sale as I need space and I'm not using it much these days.
      Works perfectly, small blemish  on front and rear corner, details will be provided, (barely noticeable with grill off only) .
      I can consider trade it with a smaller sealed sub, svs, jl rel etc of similar performances/ conditions , also with the following equipments:
      jlti 105, jlti mc100 b, paradigm S series speakers only. No silly offers...
      Local buyer preferred due to size and weight but I can help with packing and shipping if required.
      *interstate door to door shipping on crate via transdirect approx 100/150$ insured depending on location.
      Thanks for watching!
      Donation to S. N. will be provided.
    • By olegau
      Item:  Infinity Primus PS-8 Subwoofer
      Price: 180
      Item Condition: good working order
      Reason for selling: upgraded to bigger one
      Great sound and, besides a small dent in the speaker cone, great condition.
      Infinity PS-8 Subwoofer
      Features and Specs
      Enclosure  Bass Reflex
      Video Shielded   No
      Woofer Size (inches)   8
      Woofer Composition   M.M.D.
      Firing Direction   Front
      Wireless    No
      Preamp-Level Inputs   3
      Speaker-Level Inputs  Yes
      Speaker-Level Outputs        No
      Low-Pass Crossover Freq   50-150 Hz
      High-Pass Crossover Freq  None
      Phase Switch     Yes
      Amplifier Output (watts)        100
      Frequency Response 35-150 Hz
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
      Metal Matrix Diaphragm (M.M.D.): Derived from the C.M.M.D. material used in Infinity's flagship Prelude drivers, M.M.D. features a stiff aluminum core that provides exceptional strength and rigidity for clean, realistic low-frequency tones.
      Amplifier: The 8" M.M.D. front-firing cone woofer is powered by a 100-watt (RMS) amplifier.
      Surround: For a smoother response and improved durability, the woofer uses a rubber surround.
      Bass Ports: There are two rear-firing bass ports that allow deep bass with high acoustic efficiency and low distortion.
      Gain Control: The subwoofer has a rotary control on the rear panel for adjusting the level of the bass.
      Phase Switch: The subwoofer's phase switch allows you to control the phase of the subwoofer's output relative to the front speakers. If the bass sounds muddy or unclear, toggling the phase control can sometimes strengthen the bass "attack."
      Auto On/Off Circuit: The auto on/off circuit turns the power amp on when a signal is sensed and turns the amplifier off and into standby mode approximately 10 minutes after a signal is no longer received. An LED indicator on the rear panel glows green when the amplifier is on and red when the amp is in standby.
      Low-Pass Crossover: The subwoofer features a continuously variable 50Hz-150Hz low-pass crossover that determines the highest frequency at which the subwoofer reproduces sounds. The crossover has a 24dB/octave slope.
      Inputs and Outputs Notes
      Line-level Inputs: The subwoofer has a gold-plated LFE input and gold-plated stereo RCA inputs. If you have a Dolby Digital/DTS receiver or processor with a low-frequency-effects (LFE) output, you should use the LFE input on the subwoofer. If your receiver/processor does not contain a Dolby Digital or DTS processor but has a subwoofer output, you must use the stereo RCA inputs. If the receiver/processor has a mono subwoofer output, a "Y" adapter is recommended to maximize performance.
      Speaker-level Inputs: The left and right gold-plated 5-way binding posts allow you to connect the subwoofer to a receiver/amplifier using speaker wire.
    • By olegau
      Item: Infinity Primus PS-8 Subwoofer.
      Price: $180
      Reason for selling: Too many subs
      Features and Specs
      Video Shielded   No
      Wireless    No
      Phase Switch     Yes
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
    • By BIG DWIFTER
      Item: Behringer NEKKST K10S
      Price: $350
      Item Condition: Perfect
      Reason for selling: Upgrade
      Extra Info: Very solid subwoofer used sparingly with Yamaha HS8. Only selling due to a sidegrade.
      Perfect condition in every way. Never taken past 12 o'clock on the gain.
      Box and all accessories included. I still have the outer Behringer shipping box too.
      Pickup only as it's very heavy.
