ray4410
FS: power cable
Item:power cable,aust plug
Price:$89.00+postage
Item Condition:new
Reason for selling:have enough
Payment Method: Pickup - Cash, Paypal, COD ,bank transfer
  fully shielded cable for hifi+av systems,braided cable made in Germany,eliminates rfi+emi from entering system also prevents contamination to nearby interconnects,very flexible,
1.5mtrs in length other lengths available,
cable rated 18amp current rating
450volts rating
od 10.3mm
tinned copper braid.
Hi, I am really intrigued by this cable being able to block out contaminants.
Can you please explain a bit more about this?
I don't see higher end cables costing tens of thousands of dollars offering this kind of feature?
 the shielding eliminates rfi+emi  from the cable,you can use an ac tester as used by electricians to find live cables,hold it over this cable(plugged in and turned on of course)you get no reading,move the tester to the power point and off it goes,so can be safely be installed alongside interconnects with no contamination.
Thanks for the reply.
Was just the wording the OP used, it looked like it had some other feature as they said "also prevents contamination" after the information about rfi + emi, which covers interconnects.
Maybe the op can shed some more light?
@ray4410 is the OP. This can be seen when the words "topic starter " appear above the avatar in an orange box.
Edited by rantan
2 minutes ago, BIG DWIFTER said:
Thank you, Still new to these forums and missed that.
No problem at all. Just pleased I could help.
Welcome to SNA.:welcome:
3 minutes ago, bertdoozer said:
How is the screen connected please.
stu
:blink:
I think they mean is it floating or not ... ie is the shield connected to the ground wire
Edited by petersv
screen connected to earth only at wall plug end not source (iec plug)end.
I have a few of these cables from Ray and they are simply excellent, well made and recommended. Great bloke to deal with as well.
    • By chimchimster
      Item: Magnepan Magneplanar MMG-C Center Channel Speaker
      Price: $450.00 - Price Reduced
      Item Condition: Used but Excellent Condition
      Reason for selling: No Longer Needed
      Payment Method: Cash, Paypal or Bank Transfer
      Extra Info: Shipping (I have the box) or Pickup - Cash, Paypal, Bank Transfer
      Excellent center channel from Magnepan. The Magneplanar MMG C employs a horizontal, curved planar tweeter/mid-range.  The MMG C is curved for better off-axis dispersion. It is is covered in black cloth with oak accents on the sides and a single set of binding posts centered on the rear.  I have the original box and packing material for shipping.
      Here are some specifics from Magnepan:
      MMGC
      Description    Planar Magnetic
      Freq. Resp.    100 Hz- 16 kHz ± 3 db
      Sensitivity    88 db 2.83 volts
      Impedance    5 ohms
      Dimensions    36x9x5.5 inches
      Comes with original box, manual
    • By super kermit
      Item: HiFi home theatre cabinet console entertainment unit
      Price: 195
      Item Condition: used
      Reason for selling: changing style
      LANE COVE NSW 2066
      You are ONLY buying the ENTERTAINMENT UNIT
      No TV, amplifiers, cables, speakers, receivers, cable trays or light strips etc are included.
      If in doubt, please ask.
      Custom modified
      SOLID
      Holds front and centre speakers
      On wheels, easy to move and get behind the complete unit for access
      Rear wall is NOT INCLUDED
      4 shelves for components (all glass)
      2 drawers
      2 sliding glass doors
      Off street undercover garage parking available
    • By super kermit
      Price: 195
      LANE COVE NSW 2066
      Custom modified
      SOLID
      2 drawers
    • By PKay
      Item: Aurealis 5-Pin Plug to RCA Tonearm Cable 75cm
      Price: $100 + postage if required
      Item Condition: Excellent
      Reason for selling: Upgraded up the Aurealis chain
      Payment Method: Pickup - Cash, Paypal + fees
      Interconnects for transferring the signal from a turntable or a moving coil step-up transformer need to be well-shielded and able to carry a weak signal with minimum interference. The Van Damme cable which is famous for its use in studio applications (e.g. Abbey Road) is also used as the external cable on the excellent Audio-Origami PU7 tonearm. Features include:
      Fine stranded copper and silver wire combined together to preserve precise detail and tone. Tinned copper high density shield Low capacitance at 50 pf per metre Cotton and rice paper damping ETI Nexus RCA - silver plated pure copper signal pin and body of tellurium copper - aluminium housing for RFI/EMI shielding and 5-pin plug with gold-plated copper tellurium contacts 22awg ground cable with mini spades at phono end
    • By Audionerd
      Item: Bryston B-60R Integrated Amplifier
      Price: Reduced from $2450 to $1850!! RRP $7,999. Donation to SNA on sale
      Item Condition: Excellent apart from some rubbed off letters on front panel. Selections still clear
      Reason for selling: NLR
      Payment Method: Cash, Bank Transfer or Paypal
      Extra Info: Superbly engineered Canadian amp with 20 year warranty when new. Close to the quietest I've heard, with neutral and non-fatiguing yet dynamic sound. Understated slimline construction is surprisingly heavy, with output over 60W RMS @ 8 ohms and 100W RMS @ 4 ohms. Features 4 pairs of RCA inputs plus Tape Monitor Loop, Headphone socket and removable Pre Out/Main In links. All switches, contacts and connectors are gold plated.
      This unit in silver comes complete with manual, individual test report and motorised volume control via the optional remote handset. All original packaging means that safe postage at buyer's expense is an option.
      This is a rare opportunity to secure a highly regarded amp at a small fraction of new retail price, as they hardly ever appear on the used market. Many favourable views including MasterSwitch.
