For the first time, I have a dedicated room for HT and Gaming and I have finally finished the acoustic treatment of the room. To create this space of 3.4 x 4.9 x 2.5 meter, I had to move the laundry, toilet and bathroom and knock some walls down. Yes…….. the missus really, really loves me.
I had a look at soundproofing the room but decided to not go through with that idea, because the room was rather smallish to begin with and the build a bit complicated, with all the different walls and joist intersecting with each other and with the rest of the house. The room has a double brick outer wall with an air gap in between it,  as the front and the right wall. The front wall also has a window in it behind the AT screen. The left wall is a solid double brick internal wall. The ceiling has a couple of 200mm exposed roof joist with some timber on top, 100mm insulation and a flat sheet metal roof. The back wall is newly constructed and is made out of 17mm plywood with 10mm gyprock on top, on both sides, with insulation in between. And the floor is a solid concrete slab.
This room is rather solid and therefor rather challenging regarding bass issues. All treatment is DIY, and the total material cost for acoustic treatment is around $1100 AUD.
The screen wall is a timber frame held up by corner (bass trapping) towers, resting on top of the floor boards, and locked into place by screwing it into the roof joists. It is sitting 550mm from the front wall and is basically functioning as one giant bass absorption trap with 50mm Autex High Density insulation. The wall around the screen has been finished with 6mm MDF sheets with a RPG binary pattern as a finish, and to bring some reflections back into the room. The area behind the AT screen is fully covered in insulation, except for the center speaker. The coverage of unexposed absorption of the front wall is roughly 60%.  This improved clarity and sound stage a lot. It also helped with decay rates in the bass frequency. Enough to improve bass clarity, but not enough to even out the decay rate over the full LF frequency range.
The bulk heads around the ceiling have been added on later and consist out of 10mm gyprock with more insulation behind them. The rest of the ceiling has been covered in a binary slat pattern that is hung from the 200mm exposed roof joist, and the space between the roof joist has been filled with more insulation again. The coverage of unexposed absorption on the ceiling is roughly 38% I found that this improved stage depth the most.
The back of the room has been treated with panels made from the same 6mm MDF binary pattern and Autex insulation and have been mounted at various distances from the wall, 50-100-150mm. I had the mount one on a hinge as it was covering the door. I found this to be a big improvement in clarity and precision of tracking in sound effects.
Thanks to clever placement of subwoofers and listen position I have been able to create a LF response for subs and full range front speakers,  without any nulls and only need to cut off peaks to receive a flat SPL response. The frequency response of the decay times is less than flat due to the rooms solid build, but doesn’t kick in for the first 20ms, which isn’t too bad.
All in all I am quite happy with the outcome, but isn’t my best work regarding finish, as I have favored speed instead of a quality finish.
Edited by Primare Knob
Floor rug?
No thanks?
Don't really need one as clarity is as good as it is, and decay times are short enough.
As a general rule you can treat opposite areas/walls with 25% absorbtion per area/wall or go 50% on one area/wall, without taking the live out of a room. Considering the sofa on the floor and the ceiling coverage I think I am pretty close to that.
I am using a bit of an unconventional setup, as I was being fed up with the devaluation of AV gear and it's SQ performance.
I am using a HT/Gaming PC with a Pro Audio multichannel AD/DA converter straight into a couple of 2 channel power amps. I found that by ditching the AV Pre Pro I could get the 2-8 channel SQ I was after in a multichannel setup.
It is not the most family friendly setup, and I miss out on Dolby Atmos or DTS-X as that isn't supported for the PC, but I don't really miss the extra channels at this point either, but whatever the future holds, I can easily upgrade the DA converter and add more channels, or add a cheap video card with the latest HDMI specs when needed.
All DSP and volume control is done at the source in the digital domain. The PC is setup for quiet performance with water cooling and passive/active components that only activate under high load, which is during gaming.
All movies (400+) are stored on a local media server as uncompressed full BD rips.
I am still planning to build a set of 15" subwoofers to replace the 12" that I use now.
Room looks great! good outcome with the ceiling 😉
Nice to see another hard floor without the need for a rug or carpet. So much better in my opinion. Presumably you get a bit of screen reflection though?
Edited by Peter the Greek
I can't really say, but probably. The black bars have become blacker, still not to the level of the screen surrounding. The walls are reflecting some as well.
Now thats a HT room I would love to replicate! Without doubt up there as one of the best I've seen in Australia over the journey, congrats on the planning and execution, not a hair out of place by the looks.
Form and function nailed and the contrasting finishes looks superb!
Shame about the sub cables though, bet that does your head in!
not denying it looks great, like a show room theatre, but is it functional?
1,2 or 3 people on the couch with drinks..food... slouching as people do. how does it work out?
Thanks.
I am still planning on building new subs, that are externally powered by an amp. I should be able to run the speaker cable through some channels on top of the skirts, and with a bit of paint it should be fine.
If I can manage to deal with a 60Hz null by building some traps, I could hide the subs behind the soffit wall, which would be ideal.
8 hours ago, Peter the Greek said:
I agree!
Me too, enough room for you and your girl, time to lock out everyone else.
Looks great, happy watching.
Where did you get the binary mdf from. Looks the goods
I got it from Bunnings........., MDF, Drill, Paint, etc.[emoji12]
The panels are DIY and based upon the RPG binary pattern. If you google it, you will find some examples. Gearslutz has a lot of info as well.
https://www.google.com/search?q=rpg+binary+pattern&client=firefox-b-m&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi-rem6qLPkAhW58HMBHaYoBWgQ_AUIBigB&biw=360&bih=560
They are very good in controlling reflections and decay time.
They start to be effective around 800Hz, and are fully effective from 1kHz and upwards.
There are different variations on the market like the wavewood (slats), and the artisan panels.
Great effort that’s a lot of holes to drill, thought a CNC router would have been used.
again looks awesome! 👍🏼
again looks awesome! [emoji1360]
I don't have the setup for that and looked into using a hand held router, but I don't think that they are meant for drilling, and it can be a bit harder to find center looking from above.
CNC would have given a nicer cut out and a cleaner pattern, but if you need to pay an external party, there is a big chance, it will work out the same as buying the panels in store. I never got a quote back for them, but I got a quote for the ceiling strips, which came down to $1100, for cutting and supply.
As I favoured speed, I drilled up to 8 X 6mdf panels with a hand drill, but doing this by hand will never guarantee a straight angle. This is fine for the first 2 panels, up to 4 is still fine, but more than 4 and you will start to clearly see the offset created by a non straight drill angle.
You could make a guide panel, but it would need to be 25mm thick or more, and made out of hard wood, and pre drilled with straight angles, and then you're back where you started.
The good thing is, that there are so many holes that you don't notice the offset to much, but by paying a bit of attention you can definitely pick them out.
The good thing is, that there are so many holes that you don't notice the offset to much, but by paying a bit of attention and you can definitely pick them out.
Great going and agree outsourcing the CNC router work may have defeated the purpose unless you know a guy.
Looks great!! can you expand a bit more on whats behind the front wall or a picture before you added diffuser panels. I read your description 3 times and am still not clear on it:blush:
The red lines are a timber frame that is resting on the floor, and locked into place by screwing into the skirting boards, and the ceiling timber joist.
The empty spaces are filled up with a high density black polymer insulation sheets (50mm thick), which is stiff enough to keep itself up by just squeezing it in.
They are then covered with 6mm MDF panel sheets with the RPG dot pattern, screwed into the timber frame.
I did something similar to the ceiling, I jammed sheets of insulation, inbetween the ceiling timber joists, and covered it with slats, that I pre made into 8 panels to make life easier.sketch-1567505827122.jpeg.6d859a5ef6fde12897879e7c39888314.jpegsketch-1567505818933.jpeg.476b5ebe9dde8df16aa6a923be33de2f.jpegtapatalk_1567504025143.jpeg.f2d5434dfc4ea2364cc69641cc94211f.jpegtapatalk_1567504019341.jpeg.c8dd0d117ef75e12c1db3d08465e400e.jpeg
Ok, I think get it. one last dumb question , so its 50mm maximum thickness or multiple layers?
    • By krakatana
      Item: RJM Audio VSPS Moving Magnet DIY Phono Stage
      Price: $180 + $25 postage
      Item Condition: Working perfectly, some scratches on cases
      Reason for selling: Now using MC
      Extra Info: Excellent sounding phono, used for six months, built about two years ago. The cases are thin Aluminium, but have brass or Titanium plates at connector points.
      Materials used: RJM VSPS and Dual-Bridge Rectifier kits, Dueland wiring for signal paths, Arizona Blue Cactus 2.2uF 200VDC output capacitors (with bypass caps), Altronics transformer, Furutech Rhodium FI-03 IEC inlet with fuse, 2 x Aluminium cases, Stillpoint ERS tape around power cable (light blue) in phono case, Gold coated pure Copper RCA plugs, 2 cm slate pieces under circuit boards and transformer, brass (front) and Titanium plates (rear). Well over $200 of materials used.
      http://phonoclone.com/diy-pho5.html
      http://phonoclone.com/pcb.html
      http://phonoclone.com/diy-guide.html
      ELECTRICAL DISCLAIMER
      This product has not been manufactured by a qualified individual or company, therefore contains electrical circuits that do not necessarily comply with Australian Standards. I understand that as the seller, I may be liable to repercussions in the event of equipment failure. By advertising and selling this product, as the seller I also agree that I am solely liable, and the publisher of this website takes no responsibility for any injury or death resulting from, whether directly or indirectly, any accident that may happen as a result of the failure of the product being sold. If in doubt, seek the services of a qualified electrician to inspect the product to ensure it is safe for use.
    • By Liamt
      Can I preface this by saying I've never owned a television in my life...so please excuse my ignorance :)
      I'm building my own home as an owner builder in Brisbane.
      I have allowed for a dedicated home theatre / listening room. The steel frames are about to go up so I figured now was a good time to start planning.
      It will be approx 6m x 4.3m. I'm hoping for a row of 5 seats at the back on a raised platform and then two x two seats as per the attached image.
      I'm hoping for a 140" projector screen that I will make.
      I got a bit excited, and have been buying speakers and an AV receiver over the xmas break. So far, I've bought
      Denon AVC-X8500H receiver
      2 x PMC twenty.25 floorstanders
      2 x PMC twenty.23 floorstanders
      2 x ELAC BS244 bookshelf speakers
      1 x SVS PB3000 subwoofer
      I'm hoping for both a high quality music listening experience as well as full Dolby Atmos.
      I've been offered a good price on a pair of PMC twenty5.21 bookshelf speakers as well as a PMC Twenty5.C centre speaker.
      The floor of the cinema is 200mm thick concrete suspended about 2m in the air.
      The wall frames will be bluescope steel frames.
      I'm hoping for great accoustics in the room as well as great soundproofing so that very little noise escapes the room.
      I have a few general questions
      1. Soundproofing - Once the steel frames go in, I was going to green glue a layer of plasterboard onto them. I was then going to construct a new set of timber frames internally and green glue two layers of plasterboard onto this. This will give separation between the two walls. There is a floor to ceiling window, but it is triple glazed and thermally broken. I will then make some heavy curtains to hang floor to ceiling around the room. I will then have a drop ceiling with stary night lighting. Does this sound like it will be sufficient to keep the noise from escaping ? Any suggested improvements.
      2. Room size and shape - As I am building internal walls, I have great flexibilty over the shape and size of the room. It there a suggested size that I should make the room to minimise standing waves and improve the accoustics ?
      3. Speaker placement and dolby atmos choice - I've looked into the Dolby Atmos setup guides. I suspect the room is too small for 6 ceilings, so was going to go with Atmos 7.2.4. Is this the best choice for the room size ? I'm guessing the twenty.25 should be front left and right and the twenty.23 should be back left and right ? If I get a second subwoofer, will the PB1000 or 2000 suffice or should I get another 3000? Will mixing the ELAC speakers with the PMC be ok or should I buy the PMC bookshelves ? How important is it to get high quality ceiling speakers ? I'm assuming that the dont have to be PMC as they are really only used for limited sections of the movie sound ?
      4. Accoustic treatment - I have a company that produces stretched canvas prints for artists and photographers. I was thinking of printing movie style posters and then stretching them over 50mm deep frames and filling the back with accoustic foam. Is this likely to work ? The canvas is cotton.
      My post is long and there are a lots of questions. I would appreciate any input about anything that you have to offer. Thank you in advance.
    • By paulie83
      Item: 1 x Silver Centre, 2 x Silver 6 Floor standing speakers (L&R), 2 x Silver FX Surrounds (complete 5.0 system)
      Price: $2000 including donation to stereonet
      Item Condition: Excellent, pristine
      Reason for selling: Moved House decided to sell as complete package.
      Extra Info: This is an entire 5.0 speaker system at an excellent price. It includes the following:  silver 6 L/R floor standing speakers, Silver Centre and Silver FX Surrounds. This is the 5th generation silver series (i.e. the previous model to the current silver series). They are in a luxurious gloss black. They were purchased in 2016 and are in pristine condition (inspection welcome)- they have the balance of the 5 year warranty and I have all receipts. They are great sounding speakers for both music and movies. They have never even been misused or pushed hard. These speakers cost me around $5000 new. They are all tonally matched with matching 6 inch bass drivers and gold c cam tweeters. I am only selling because we have bought a new house and I made a deal with my wife. I would give up the 5.1 setup to fit better in the new house but I was allowed to get an upgraded 3.1 setup. Pickup will be from my address near Wollongong. I am happy to deliver for free though in the greater Sydney or even Canberra area just ask me and we can work something out.
      Buyer will not be disappointed! Happy to take further photos or accommodate an inspection.
    • By daro
      Item: 2 x Toroidal Transformers 160VA 2x20V Audio Grade
      Price: SOLD
      Item Condition: Made in 2013 but never used, mint
      Reason for selling: Abandoned DIY project
      I have for sale a pair of Toroidal Transformers. They are 160VA, 2 x 20V each. Made by Toroidy, great Polish manufacturer of high quality audio grade transformers.
      Selling both matched transformers together, so the price is for the pair. They could be perfect for a dual-mono or two monoblock amplifiers.
      I bought the transformers 6 years ago, for my DIY amp that I never finished. I did not even put those transformers in. Stored them packed in the box. So these are pretty much brand new.
      I did not have time to finish that project and do not need those two any more, so the sale.
      Some of the characteristics of the Audio Grade transformers by Toroidy:
      - additional magnetic and electrostatic screening
      - epoxy filled centre with M6 clearance hole in a potted centre for mounting
      - gum pads to eliminate transmission of vibrations
      - impregnated core and the windings
      - covered with a black Mylar tape
      - production process scrupulously controlled at every step
      - quiet performance and the highest electrical parameters
      - flex leads
      - GOSS band
      On top of that, my order had a couple of custom modifications:
      - doubled diameter of secondary windings
      - primary winded on secondaries
      Specs:
      Primary: 0-230V @ 50Hz
      Secondaries: 20-0-20V
      Estimated dimensions:  105mm diameter x 50mm high (plus 10-20mm for leadouts)
      Mounting: M6 clearance hole in a potted centre
      Leadouts: approx. 110mm long flexible (stranded)
      Weight: approx. 1.35kg each
      I’m happy to post anywhere in Australia. Pickup available from Lindfield (2070).
    • By rawcraftwood
      Item: SHERBOURN PA 2-250 POWER AMPLIFIER
      Price: $750
      Item Condition: VERY GOOD 8/10
      Reason for selling: NO LONGER REQUIRED - TOO MUCH GEAR
      Payment Method: Pickup - Cash, DEPOSIT
      Up for sale is my Sherbourn PA 2-250 power amplifier.
      For those who don't know, this was the predecessor of the very popular Emotiva XPA-2.
      2 x 250w @8 ohms, 2 x 500w @4 ohms
      XLR and balanced inputs
      Trigger inputs and outputs
      Huge torodial power supply
      Weighs in at 22kg
      I was using this amplifier with a set of magnepan mg12's I recently rebuilt the frames and crossovers for.
      I was previously using a Harmon Kardon citation 12 for the Maggies with no compliants, but after the recent
      modifications , the Maggies dug that much deeper into the bass region that the HK was having a hard time,
      and got quite a bit warmer than it normally did when a bit of Dire Straits was played......
      I found the Sherbourn had a very similar sonic signature to my lovely old HK, but boy could it dig lower without even a hint of breaking a sweat.
      So much so were the new crossovers, frames and amp working together that well that the lower register was at the point of being detrimental.
      I made the Maggies into a three way system, put the HK back into the system to cover the mid and top end, and run 2 x 12" sealed subs for the bottom end.
      And with that, the Sherbourn went back into the box.
      Would make a great home theatre front channel amplifier, stereo amplifier, or another Maggie owner wanting 500w x 2 @ 4ohms without breaking the budget ( or marriage ).
      Prefer local pick up as the weight is above some freight carriers limits, and once they know it's second hand audio gear, they won't cover for damage......
      been there and done it a few times in the past.......unless you're wanting to pay hundreds of dollars extra ( TNT won't cover for loss ??? only damage )
      My username on ebay is also rawcraftwood, so you can look on there for an indication of my feedback. I'm not a trader or seller of audio gear, I'm just like the rest of us,
      bitten by that darn upgradeitus bug......continually looking for that audio Nirvana.
      Fleabay is no longer what it used to be 5 years ago, too many crazy people......so I don't sell on there anymore.
      I have a few other amplifiers to list over the coming weeks....same thing, am happy with the current setup/s and no need to change anymore.
      I can put the funds to other projects.
