The Puffin DSP phono pre-amp
I remember bookmarking this groundbreaking piece of gear some months ago and finally decided to check out user comments. - the only ones worthwhile. Initial reaction was overwhelmingly - I don't want anything digital in the analogue signal path. However actual use brought completely different and positive responses.
Some years ago I bought a Talk Electronics  MC3 phono stage. It's S/S, loads of settings to cater for virtually any cartridge, the only change of components I can think of - to replace the RIAA  smd 1% resistors with Z foil ones.
When I looked carefully at just what it can do and not just for vinyl but for any source it became obvious that  Shannon Parks the creator could if he was minded make a remarkable ADC simply by omitting the final conversion from digital to analogue and replacing RCA outs to a digital out. I have been looking to make a digital library of my LPs and CDs. Nowhere have I seen anything as simple as tweaking a couple of knobs and without introducing any artifacts.
I use a Kenwood KD 990/AT 33EV (maybe an ART 9 or Soundsmith Zephyr in the future) into my MC3 phono stage. Most if not all the reviews on the Puffin don't feature this level of vinyl replay. It would be good to hear from anyone that does.
Certainly in the near future the Puffin will trigger responses from others that might well result in even better phono/ADC creations. Worth anyone with vinyl checking out the many useful features.
  • Replies 96
Popular Posts
I'm the chap to whom @Bell Ringer very kindly loaned the puffin. He is a very generous fella and I'm most grateful that the spirit of SNA is alive and well.   My thoughts on the unit are tha
The manufacturer would know best but this doesn't happen often enough. I have great respect for any manufacturer that is this open about the details and isn't vague and skirt around the issue letting
He was right IMHO.   I would expect noise from the DSP (computer) section of the circuit, which is in the box with the analogue parts, would be MUCH higher than any residual noise from a switching sup
I have the puffin and also had the budgie (which I sold). The puffin is quite a versatile unit. It is very easy to configure. I had set it up with a DL-103 which it easily had enough gain for. Easy to adjust the sound for those records that are less than stellar and you can save up to 4 user settings.
With the puffin I have also hooked it up to my laptop and phone playing Spotify.
I'm thinking of putting the puffin up for sale, send me a pm if interested.
I have one. I purchased it for the non RIAA curves for playing my 78s. It’s pretty good as a standard phono and the adjustability on the fly is really useful and fun.
Is it better than an entry level Cambridge or Project, in my experience yes, a lot better. Is a better than an iFi Phono? Maybe not. Is it a hundred times more convenient and tweakable than the iFi Phono? Yes.
A @Iain_r mentioned it is convenient, especially for crappy recordings. Lots of loading and tone options to get what you want. It’s a tweaker’s delight.
I have 3 phono amps at the moment, I was thinking of offering it up for sale as the puffin was part of a second system upstairs, but it never got much use so I dismantled the system and the puffin gets swapped in and out on my main system now and again with the other two phono amps
  • 1 month later...
On 14/08/2019 at 10:48 AM, Falcon 500 said:
Hi
be good to hear your impressions as it gets more use
Over 10 LPs now played with the Puffin
Must admit that it’s overall performance is pretty good across all genres
Played about with the settings and found that in my system the small changes made tiny differences
A nice feature is the onboard volume control
I have started following the Parks Audio Facebook page to keep up with any updates
As a result I have found that a new software update has been released about 3 weeks ago, so when time allows I will need to do update the Puffin and see how the new software performs against the previous
I read the technical review and the unit's manual and it seems pretty good. The lack of a digital output seems an odd omission to me
As I noted above
I follow the Parks Audio Facebook page
On a recent update a DIY digital output has been released for anyone wanting to do it
So here is the link on how to do it
http://www.parksaudiollc.com/spdif/spdif.html?fbclid=IwAR25CELooLmdnrnq3HRRZdqBit_l2vapRMCMNuKYN5fIMyVhzS2nSzz8xKQ
Thanks. I missed your post as I quickly read through. It's an easy enough DIY mod for me, but it would still be nice if it came from the factory that way, even with a small surcharge. Other non-DIY types I'm sure would be happier with this approach. The ability to have 4 user presets won me over as the TT when it's rebuilt will have 3 arms, one with an MM, one MC and a Decca. Saves me building 3 analog phono pres and buying an ADC.
I hope they'll publish updates elsewhere as I won't have anything to do with f___book.
  • Haha 1
I agree - It seems that Mr Parks is proactive and may include it in new builds or as an added extra ?
But for owners now that want a digital out - the only option is the DIY method
Same with me
The presets are great as I have several carts and one is also a Decca
Overall the Puffin is a great little unit and performs well with plenty of tweaks to suit one’s preference
It punches well above its price point
Just need to do the software update as time permits
The updates are first published on the Parks website then repeated on Facebook with links back to Parks Audio
Hope that helps
So all updates are there
Hope that helps
Thank you.
It really does look like an impressive unit, and I was very sceptical until I read the tech reports and manual. Analog is not my priority at the moment, but will definitely get one next year.
I have updated the Puffin with the latest firmware V1.11 today
Tested it out on a couple of the Puffins onboard settings
Tube 2H and the MC cart for a couple of records
Still impressed
Now I need to reset or test and change the saved user settings
  • 6 months later...
Just a quick update for any Puffin owners
A new Beta firmware version is now available with some amazing features
Mr Parks has indicated that its just about finished and you can confidently download the firmware to try it out
Only a few tweaks here and there before release
I have just updated the new firmware now but have not tested it as yet
My update is to follow as time allows
I will paste some of the new features and link the download page
Puffin Firmware *BETA V1.20*
Changes:
  • Added Magic pop and click minimizer
  • Added Grade which is a record grading function
  • Added new clip alerts with asterisk * at Volume (output/DAC clip) & Gain (input/ADC clip)
  • Changed TF to fx. Think like "effects" or f(x)
  • Lowered 2H Tube distortion (7%THD at full signal)
  • Fixed 3H Tape distortion (3.5%THD at full signal)
  • Removed 2H&3H from fx
  • Moved Noise to fx (PinkNoise)
  • Added Out function & merged SPDIF code, though Out:SPDIF is disabled on non-modded Puffins
  • Added 25Hz to Low filter and made default
  • Magic: Removes a lot of crud from your vinyl. But doesn't whack it over the head with processing either. The goal is a simple control that is On or Off. I've tried to make it very gentle and non-digital sounding, and actually used an analogue-like technique. This is intended to be used all the time and makes your best LPs sound better. Like they're extra clean. Scratched up records will receive some help, but don't demo Magic using them - use the good stuff.
  • Grade: Use this to grade your records - either to sort out dupes or find which records may need to be upgraded. Turn Grade on after the music fades in and turn off just as the music fades out. This cuts out all the noise in the beginning and run out grooves which affect the grade. Uses the American Grading System: A+, A, A-, ... D-, F. So you grade each side.
    Clip detection: this is an asterisk that shows up at Volume and Gain. Definitely adjust Gain down if clipping as you are over-driving the input. Occasional clips at the DAC (Volume) are less of an issue as they are software handled.
    TF fixes: Wow - I really screwed up the harmonic functions in the previous release. I had a semi-bad bug in the harmonic code with versions 1.04 and earlier, but the fix in V1.11 I caused the 2H code to be much more aggressive and the 3H code to not work properly at all. Should be good now.
    The code is unified now, so this will work with either a regular Puffin or a SPDIF modded Puffin.
    My general thoughts: Magic is fantastic but reminds me of anti-lock brakes. You turn it on and forget about it. It's only when you turn it off that you cringe and turn it back on. Grading, on the other hand, is an active feature - even a game of sorts - that you interact with. I really, really, love grading my records. When it tells me that my copy of Led Zep III is an F (and I kind of assumed it was), it gives me permission to get a new copy. And you can use it to test your cleaning methods, too.
    This could very well be buggy, but I wanted to get V1.20 out there. You'll love the new functionality: Magic click minimizer, record grading, and enhanced clip monitoring. Using the supplied allen key and USB cable, the Puffin can be updated via an internal micro USB header with either a Windows or Mac OS system.
Download page
http://www.parksaudiollc.com/betafirmware.html
Edited by Full Range
On 27/09/2019 at 9:15 AM, Full Range said:
...On a recent update a DIY digital output has been released for anyone wanting to do it
So here is the link on how to do it http://www.parksaudiollc.com/spdif/spdif.html?fbclid=IwAR25CELooLmdnrnq3HRRZdqBit_l2vapRMCMNuKYN5fIMyVhzS2nSzz8xKQ
I've just had a look at this and I'm impressed.  It's a simple and cheap process for a DIY upgrade.  The detailed guide to the mod is excellently put together so someone with basic skills should be able to do it.  And a lesser company wouldn't have published this as a DIY, they would have just incorporated it into a new version of the product and expected anyone who wanted it to upgrade from the previous version.  Gives me confidence to buy from this company (mayb e in the future).
Both versions are now available direct from Parks Audio at different price points
But for people that have the first version and have the need for a digital output later on - then it’s easy to do for a DIYer
55 minutes ago, Bell Ringer said:
I haven’t updated the firmware since I bought mine last year. It will be a nice Easter holiday treat.
You are a good candidate for the almost completed Beta firmware
I am going to test out the Magic and Record Grading feature in the coming days
I am spinning a beautiful Space Prog album by Jon Anderson
Testing the main new firmware features of the Puffin phono amp
Lets start with
Grade - it is a vinyl grading system while playing the record
So the software takes in all variables and displays the result in real time
This album was rated at A but on occasion it fluctuated from B+ to A
On Discogs I rated it as VG+ — so I was pretty good on a visual and playback check
** Although you may get a lower rating on albums - it may just mean that the record needs a good deep clean
Magic - this is a pop and crackle minimiser that only activates when a pop is detected and reverts back to normal
This means that turning on the feature does not mute the record in it’s entirety
On this record I have very few pops and then only in between tracks
In my listening - the magic feature reduces the loudness of pops so it’s not distracting to the ear
So in that context - I found that it works as described by Parks Audio
34-DA22-A3-98-D6-41-C9-A1-A0-2-A1-F296-F
572675-C5-841-D-478-B-B96-E-F917-B679398
Just updated to the Beta version. Now to spin some records.
Now that I’ve got 4 days off work I can start configuring some settings for my monos. I’ve tended to do it on the fly because it’s fun, but some defaults for particular carts and types of pressings would be useful. I’ve got some very noisy microgrooves, so it will be interesting to see how good I can get them.
Can you use the ‘null’ setting to identify cart alignment issues? I’ll give it a go.
I need to update again as another feature has been added
Quote -
Beta C firmware has been released.
Changes:
-Added DeRumble function (200Hz/12dB)
-Added RoomEQ function (de-mud cut filter: -6dB Q=2.6 at preset frequencies)
-Doubled the Volume settings with finer adj resolution
-Updated Levels to include tenths dB resolution for azimuth adjustment
-Fixed 'Set?' preset loading noise pop (I think?)
http://www.parksaudiollc.com/V120betaC.zip
DeRumble is a true rumble filter using the Macaulay Method of summing the low bass to eliminate out-of-phase vertical rumble from the turntable.
http://www.parksaudiollc.com/macaulay.jpg
RoomEQ compensates for the room's main resonance that ends up muddying the bass. Just roll with 300Hz or use a free octave RTA on your phone and the Puffin's fx:PinkNoise to find where it is located in your listening space. The RTA apps usually have peak search on as default, so couldn't be easier. I staggered OFFs between the different frequencies (200Hz to 400Hz) so that you could switch back and forth (before and after).
Lots of changes, so be on the look out for bugs. I think the major changes/additions are over at this point.
51 minutes ago, Bell Ringer said:
Looks like I should have waited a day. I got one of my very noisy records sounding pretty good yesterday.
I thought the grading feature was spot on.
As we are house bound it’s a nice distraction to update and test
Easy way to pass away the home detention time
I think that’s why Shannon Parks is doing so many updates.
  • Haha 1
  • 2 months later...
Just ordered one from the US of A.  Shannon Parks responded to my email within 10 mins.  Hows that for service! :)   Question to @Bell Ringer, @Full Range - are you both using a linear psu with your Puffin's or just the bog standard one that came with it?  I'm thinking of getting a 12vdc to run it. ifi psu.
Edited by Porkbuns69
@Porkbuns69I'm just using the one supplied. Not sure if it's worth the extra $ in my case. It's not my main phono stage, just for my monos and 78s, and they tend to be in ordinary condition so I probably wouldn't hear any benefits of an upgraded power supply.
Probably people online that have.
Thanks @Bell Ringer - i'll get one to try it out with and without.  I dont think it will make much of a diff but who knows.
Why not buy Australian - Clay Gieseler makes excellent linear PSUs.
  • Like 3
I use the supplied power supply
When funds permit. Clay makes awesome linear psu's.
  • 2 weeks later...
Mine arrived yesterday from the USofA.  Well packed and felt and looked well built.  I didnt use the incl 12vdc smps psu, instead plugged in a spare ifi 12vdc psu along with the ifi DC purifier 2 at the end of it.  Had a good listen last night and compared it to my Schiit Mani in MM mode and at 44db gain out to my MC SUT (vintage sowther transformers).  As good as the Mani is at its price point, but the Puffin had more texture, warmth and tone to the sound over the Mani.  Mani had more bass depth.   Havent played around with the settings yet, so just running it as is.  The Puffin is quiet...very quiet, reminded me how similar it was to the ifi iPhono 2's noise floor that i had recently.   So far all good, looking forward to clocking in some hours on it with more albums played over the weekend.
Have a play around with the many settings and you will find a spot that suits your system and listening preferences
Try out the Magic setting and see how much quieter noisy records become
And post your spins in the vinyl spinning thread
try adding some 2H Tube warmth.   On my home made version of the Puffin, it REALLY sounds nice.
