zakblue
Bryston Amp repair
Hi all,
A while back I managed to leave a Bryston 2blp on the floor of my listening room and as I walked past it
I stepped on one of the rca inputs in the rear. There was a nice snapping sound that followed and it left the
rca input hanging by a thread. Operationally the unit was fine before that.
It should be a fairly easy job to fix (i'm hoping)
Are there any recommendations for the repair in Melbourne?
Zak
call Busisoft in Melbourne, they are the distributor, they will point you in the right direction, if it's still in warranty.
if out of warranty, any decent repair shop should be okay
    • By Muzza71
      Price: $2250 Item Condition: Very Good Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Secret Harbour 6173 State: Western Australia Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: Raising Funds for Active ATC Speakers Further information:
       I have decided to sell my beautiful large Bryston Mini T 3 Way Standmount Speakers to fund an Active speaker upgrade.
      Finished in  Walnut veneer RRP $6700.00
      These are large Standmounts at 570mm in height and weigh 19kg each, true 3 way speakers.
      I will throw in the sand filled speaker stands for local buyers.
      I have all original Packaging/Cloth speaker covers so can ship Aus wide at buyers expense.
      Don't confuse these for the lower Model A speakers
      Frequency Response 33Hz to 20Khz (+/- 3dB) Impedance 4 Ohms (nominal) Sensitivity 86 dB SPL @ 1 meter with 1 watt (anechoic) Maximum SPL 112 dB SPL @ 1 meter Recommended Power 10 watts to 250 watts RMS Tweeter Single 1.0" Midrange Single 5.25" Mid-Woofer Single 8.0" Crossover 160 Hz & 2.3kHz Dimensions (HxWxD) 22.5" x 10.5" x 10.0" (571 x 267 x 250mm) Weight 42 lbs (19 kg) Finishes Black Ash
      Walnut
      Boston Cherry
      Custom Veneer available at additional cost   The Bryston Mini T Bookshelf was built to be exceptionally high quality and affordable while bringing superior design to the table. New driver designs, enclosure vibration analysis, crossover refinement, and anechoic chamber testing all went into creating an amazing product.
      Bookshelf as a category technically fits the Mini T form factor, but perhaps it is better described as a compact loudspeaker. At nearly two feet tall and 42 pounds, its heft may be out of place beside your collection of literature.
      Performance
      Size isn’t the point of pride with the Mini T, the smallest of the T Series. Unusually for a bookshelf or stand-mounted loudspeaker, this is a 3-way monitor featuring a high power 8-inch bass driver. Like it’s larger siblings, dynamics and low frequencies are reproduced with a realistic sense of scale typically sacrificed when purchasing small speakers.
      Drivers
      Even in a relatively small package, Bryston’s custom 8-inch woofer, midrange, and tweeter fit neatly on the front baffle. Bandwidth remains wide plunging to 33Hz in the bass region to 20kHz on top. Each driver is powered by FEA optimized motor systems and assembled in an ultra-rigid die-cast aluminum chassis which resists sympathetic vibrations that would otherwise feedback through the front of the drivers.
      Enclosure
      Though small, the Mini T espouses each of the cabinet construction principles found in all other models in the T Series. Heavy walls and a double-thick front baffle are anchored securely by a robust bracing lattice. Like other Bryston speakers, the Mini T is virtually uncolored by enclosure or port resonances.
      Features
      High levels of SPL without distortion or compression Unit to Unit matching Custom designed drivers with die-cast aluminium baskets, substantial magnet assemblies, and custom motor systems Wide dispersion design Engineered to prevent cabinet resonances
    • By Audionerd
      Item: Bryston B-60R Integrated Amplifier with remote handset
      Price: Reduced from $2450 to $1750!! RRP $7,999. Donation to SNA on sale
      Item Condition: Excellent apart from some rubbed off letters on front panel, but selections are still clear
      Reason for selling: NLR
      Payment Method: Cash, Bank Transfer or Paypal
      Extra Info: Superbly engineered Canadian amp with 20 year warranty when new. Close to the quietest I've heard, with neutral and non-fatiguing yet dynamic sound. Understated slimline construction is surprisingly heavy, with output of over 60W RMS @ 8 ohms and 100W RMS @ 4 ohms. Features 4 pairs of RCA inputs plus Tape Monitor Loop, Headphone socket and removable Pre Out/Main In links. All switches, contacts and connectors are gold plated.
      This unit in silver comes complete with manual, individual test report and motorised volume control via the optional handset. All original packaging means that safe postage at buyer's expense is available.
      Rare opportunity to secure a highly regarded amp at a ridiculously small fraction of new retail price, as this model hardly ever appears on the used market. A bargain for those who value quality over quantity. Many favourable reviews including MasterSwitch.
    • By Audionerd
      Price: Reduced from $2450 to $1850!! RRP $7,999. Donation to SNA on sale
      Item Condition: Excellent apart from some rubbed off letters on front panel. Selections still clear
      Extra Info: Superbly engineered Canadian amp with 20 year warranty when new. Close to the quietest I've heard, with neutral and non-fatiguing yet dynamic sound. Understated slimline construction is surprisingly heavy, with output over 60W RMS @ 8 ohms and 100W RMS @ 4 ohms. Features 4 pairs of RCA inputs plus Tape Monitor Loop, Headphone socket and removable Pre Out/Main In links. All switches, contacts and connectors are gold plated.
      This unit in silver comes complete with manual, individual test report and motorised volume control via the optional remote handset. All original packaging means that safe postage at buyer's expense is an option.
      This is a rare opportunity to secure a highly regarded amp at a small fraction of new retail price, as they hardly ever appear on the used market. Many favourable views including MasterSwitch.
    • By TTM
      Item: Bryston BDA-1 DAC in silver
      Location: Camberwell, Vic (I am also happy to post at your cost and risk; I do have the original packaging)
      Price: $1250
      Item Condition: Excellent, almost new condition.  I only purchased it about 6 months ago.
      Reason for selling: No longer required as I have changed my setup
      This is the best DAC I have ever owned and I'm sad to see it go!  IMO, it has wonderful detail and clarity without losing any of the warmth or musicality, especially when matched with the right components.  I have been constantly surprised over the last few months about the number of times it has revealed something new in my music that I had not noticed before.  However, I've changed my setup to Simaudio and I just can't justify keeping the Bryston DAC any longer.  It is in almost new condition and comes with all the original packaging and manuals too.  Any questions, please ask!
    • By Eagleeyes
      Item: Brand New Bryston BLP-1 Turntable and Power Supply
      Price: NOW only $3750 ono almost 50% off New price which is $6999
      Item Condition: Brand New Perfect, never used, no cart mounted.
      Reason for selling: Cash
      Payment Method: Pickup - Cash, Paypal, COD Only can ship anywhere in factory box.
      Extra Info: Very well reviewed new turntable from Bryston.
      https://www.theabsolutesound.com/articles/bryston-blp-1-turntable-and-tonearm/
      http://audiofi.net/2018/05/bryston-blp-1-turntable-the-ultimate-bry-master/
