atsq
FS: Atlas Navigator 1m XLR Cable - OCC Copper - 1 available (single not pair)
Item: Atlas Navigator 1m XLR Cable - OCC Copper - 3 1 single cable available (not pair)
Price: $95 $70
(RRP: $160-185 depending on exchange rate with the british pound)
Item Condition: Very Good
Reason for selling: No longer needed
Extra Info: This cable is known for being extremely detailed.
Edited by atsq
Sale pending. I have some Furutechs available in another listing if you've missed out.
1 single cable left.
    • By Gremrock
      Item: alpine pdx m12 sub amp
      Price: 400
      Item Condition: good used
      Reason for selling: no longer running sub
      bought a while ago and has had about 2 years  of use.
      top of the line model, Rrp $999.
      compact class D so runs cool and fits anywhere, will drive any sub.
      have a new baby so don't need a sub in the car now.
      good condition but some writing is rubbing off the Top, I used some sort of cleaning polish that stripped the printing a bit. Sorry. 😢
      Amp is about the size of a decent hardcover book by the way, so could be posted for $30 odd just about anywhere.
      also have a Type x subwoofer (driver only, box got damaged) I'd do for $250 with the amp (their best dual voice coil sub) or $300 separately. Currently have the driver in storage so can't take pictures of it at the moment. Here's a link for your perusal though.
      https://www.alpine.com.au/shop/subwoofers/x-series-subwoofers/x-w12d4/
    • By pauloch7
      Item: Plixir Elite BAC 1500 Mains Power Conditioner
      Price: $2950 (New AUD4400 )
      Item Condition: Used for 4- 5 months with original packaging box. Like new.
      Reason for selling: NLR . I have upgraded to a larger unit 4KVA
      1500 Watts of Pure Tone power. It is designed to naturally reduce the incoming AC mains noise while improving the current delivery to your system. Based on a custom single winding balanced power transformer from Noratel, ground loop current and noise is reduced to negligible level to equipment connected to it, making it suitable for sensitive equipment like turntable, phono stages, DAC and CD player. Pick up only due to its weight.
      Specification
      Total Power 1500W Max
      Number of outlet 5 Australian Socket
      Total Power Amp supported 250 watts into 4 ohm 2 channel class A/B
      Input 220~240Vac to output 220~240Vac balanced 50hz, 6.5Amps peak continuous current delivery.
      Dimension (mm) : 288 x 285 x 142 (including footers)
      Idle Power consumption :Less than 5W
      Casing finish Black anodized, sandblasted aluminium
      Vibration control Isolated by Bfly Audio
      Weight 24kg
      Made in Singapore
      For more information go to https://www.plixirpower.com/products/elite-bac-1500
    • By TONYCH31
      Item: Maverick Audio Tubemagic D2 DAC
      Price: 250  200  Price drop
      Item Condition: Very good.
      Reason for selling: Upgraded to Chord Qutest
       A dedicated quality DAC based on AD1955 DAC chip paired with BurrBrown OPA 2604 OpAmp.
       Upgraded with GE Tube.
      The TubeMagic D2 comes with a vacuum tube pre-amp output stage in addition to the normal solid-state audio output.
      Specs from the following link
      https://www.mav-audio.com/base/product/tubemagic_d2
      https://headfonics.com/2013/09/the-tubemagic-d2-dac-by-maverick-audio/
      Can post to interstate at buyers expense (normally will cost from $15 - $20 based on its weight).
    • By statman
      Item:  2 x LSR4312 15" Subs, 2 x LSR4326P monitors.
      Price: $1000 decreasing $200 per week till sold.
      Item Condition: Good
      Reason for selling: Not needed.
      Extra Info:  These were state of the art in studio monitoring some years ago. Fully active system with 6 inbuilt Class AB amps. Has all sorts of analog and digital inputs , RMC room bass equalisation , can be CAT5 networked to be controlled simultaneously .
      In "flat" mode they are true studio monitors, very accurate and detailed, but with a bit of inbuilt EQ they  sound very nice and very dynamic . Great sound-staging and imaging , excellent bass from the 2 x 15" active subs.
      Just add a good tube preamp and they sound REALLY GOOD . List price new was around $6000. Comes with manuals and all cables .
      A few negatives though- JBL put a protective film on front of speakers and it goes sticky over time. Its been removed, but some discoloration of the front panels has occurred.  One of the 4326P monitors has less output than the other. Fortunately they have independent level controls and adjustment can be made for equal level. It's about 5dB difference, but adjusted they sound perfect. I believe JBL have a pretty good service if buyer wanted to have fixed, but they work great as is.
      I've had them running for a few days as they were in storage, and no problem, but sold as is.
      Do your research on web - JBL LSR4312 and JBL LSR4326P - they have a good reputation for studio use, and maybe not appreciated for stereo, but they do sound excellent with a good preamp.  Keep an eye on them and the date, you could get a real bargain, must be sold.
    • By Galactic Soap
      Item: 64 Ears U18T
      Price: $3K + Fees + Shipping
      Item Condition: 9/10 - MINT
      I don't think I've seen a pair of U18T's for sale on Stereonet and for good reason. Just over a year old and purchased from Minidisc in mint condition. I've only used one pair of tips as per the picture.
      I didn't expect to purchase the U18T's I fully expected to walk away with either a pair of Empire Ear Legend X's or Tia Fourte's. Feeling a little dismayed at the Legend X's over the top bass (Í'm a bass head who loves his House and Techno but even I thought they were a bit over the top), and the Fourte's tipped up/hot treble which I found fatiguing within 5 minutes.
      I auditioned the U18T's as a bit of an after-thought, thinking I'd hear them purely for the sake of completeness. I expected them to be linear, transparent and that's about it. Well. Yes, they are all of those things...and more. The U18T's are incredibly musical and within 2 minutes I turned to Wing grinning from ear to ear. Since then I've been floored by the sound-stage, resolution and musicality. Incredibly resolving but never analytical, bombastic, beautifully defined bass. They really are the real deal.
      The only reason I'm selling them is because I have access to my own office since opening up my own business where I've gone rather over the top and put in place a desktop system with enough power to drive my Abyss TC's as per the picture below. Other wise nothing I've heard in the IEM space comes close to my tastes.
      Lastly I'll include the stock 64 ears cable (which is okay at best) as well as an ALO reference 8 3.5mm to 2pin which I found a material improvement.
